Question about LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium
The water and ice works but not dipense from the door front. The mother board works , it is lit and we can stil control the tempature. I feel it may be the plastic swith that is underneath the push pad may be broken. Let latch that drops the ice seems to be functioning as well. We are frustrted whlie this problem occured just aftre our onr warrenty expired. Can you please help. We did inquire by telephone with the LG service department and the gave us an estimate of $380.00 to trouble shoot and do the repair. We paid $1900. for the refrigerator new so we felt that was extremely high.
  • 3,083 Answers
You might be right about the plastic switch, and can test it with a voltmeter (on the ohms range). Go to the following site and enter your model number, and if they have it, diagrams and parts lists will come up for your unit, and it will help you troubleshoot it. Here's the site:
http://www.appliancepartspros.com/
Here's another site that will help you troubleshoot the icemaker:
http://repair2000.com/icemkr.html
This site is for LG icemakers- it might or might not help you:
http://www.ehow.com/how_6196231_troubleshoot-lg-refrigerator-ice-maker.html
Good luck with this, and hope this helps you.
Posted on Sep 13, 2010
GE Profile refrigerator pss26sgrcss isn't dispensing water, and 2 days control panel isn't working either. Not running and not cold at all, what are possible problems and solutions?
check for power at the display if power is present then you need a new interface (display) if no power is there then you need a new mother board located on the back of the unit square panel..mother board part#- WR55X10942--interface (display)-part#WR55X10390
Mar 27, 2012 | Refrigerators
Will not release ice and makes crushed ice, even when on cubed.
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
The Kenmore Ice maker makes no ice. This is a side by side unit. The freezer is very cold. The water solenoid is not faulty, but is not turning on so the problem must be in the electronic ice level...
Good chance the water line near the ice maker motor is frozen. Thaw out the freezer for about 6 hours - move your frozen stuff to the refrig - ot should be OK - then back again after thawing. This alnost always works.
Aug 10, 2009 | Refrigerators
Ice dispenser will not dispense ice when selecting either crushed ice or whole ice. I replaced the motor but it still will not work.
Your door switch may be the problem, it is a double pole single throw switch. When the door is closed the switch directs power to the dispenser. It also could be the control module in the dispenser panel. Not knowing your model number I must assume you also have a mother control board on the back of refrigerator. Send the model number found on the bottom of the fresh food section door frame and behind the door seal. Hope this helps, feel free to ask me more questions and please rate me! Thanks, Sea Breeze
Jul 29, 2009 | GE Refrigerators
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Water/ice dipenser
Sorry, these become dirty after a period of time. Try spraying up with soap and water, clean as best you can, let dry. And then spray with a canned lubricant. Silicone type, (as opposed to WD-40 type) may work best. But OK to try either.
Feb 07, 2008 | Maytag MZD2766GES Side by Side...
Whirlpool Side by Side Refrigerator Model # ED2FHEXNQOO
POSSIBLE YOU HAVE 2 SEPERATE WATER SOLENOIDS. THE SOLENOID FOR THE ICE MACHINE HAS A STRAINER AND ORFICE JUST INSIDE THE INLET SIDE OF THE WATER CONNECTION. CAREFULLY REMOVE THE ASSEMBLY AND CLEAN-IT. YOU CAN CHECK IF ICE MACHINE SOLENOID HAS POWER BY TAKING A METAL BUTTER KNIFE AND HOLDING IT JUST ABOVE THE COIL ... THE MAGNETIC FORCE SHOULD BE FELT TUGGING THE BLADE DOWN. LOSSEN THE NUT ON THE OUT-LRT SIDE OF THE ICE MACH. SOLENOID AND SEE IF YOU HAVE WATER ...
Apr 26, 2007 | Whirlpool GD2SHGX Refrigerator
LG 26.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Titanium Logo
94 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
