Question about Singer 2263 Mechanical Sewing Machine
Does this machine need oil and where. the machine makes winding sound
  • 161 Answers
Uselss all the parts are teflon, it will need oil; try the manual
http://www.sewingmanuals.com/
Posted on Sep 13, 2010
My machine makes a terrible squeaking sound at the handwheel?when I wind the bobbin. What is squeaking and can I fix it myself?
Depends on the make & model...
Some older mechanical sewing machines need regular cleaning & oiling. Check your user manual.
Apr 20, 2015 | Sewing Machines
How do I oil singer 6230?
This has the self winding bobbin. You need to be careful when oiling. Take the top, left side, and bottom off the machine. Do not oil the gears. They need clear, synthetic grease only. Place one drop of oil where ever metal rubs together. Only use sewing machine oil. NEVER use 3-in-1 oil, or anything else. It turns to a sticky residue, and will freeze your machine. Note, these models have a plastic gear on the lower main shaft that loves to shred. They're great machines, but I would take it to the repair shop, have the gear replaced; the old lubricants removed; and check the bobbin winding mechanism. You may end up spending $150, but will end up with a great machine.
Mar 03, 2015 | Singer Sewing Machines
Hello, I have an older Janome model Harmony 2049, it stopped sewing in the middle of the project. The machine makes the noise like it needs a little push to start sewing, but that is all it does. I took it...
Sounds like the lubricants may have "seized". Has this been in for a COA (clean/oil/adjust, aka sewing machine tuneup) in the last year or so?
Jun 02, 2014 | Sewing Machines
Grinding shaft
Possibly the top of the shaft near the balance wheel needs a drop of oil it is always overlooked, if you do not have an oil hole near the balance wheel either you have to take the top off the machine or separate the body to get to it if you have a two part body machine
Oct 06, 2013 | Singer Sewing Machines
Bobbin won't wind on singer 5500 just makes motor noise
the machine probably needs to be serviced
Apr 13, 2012 | Sewing Machines
The motor runs but the needle won't go up and down. When I turn the wheel it will turn and that moves the needle up and down but makes a clicking sound. I've taken it apart and cleaned it even oiled it and...
It sounds like the bobbin winder is engaged. On the top of the machine on the right hand side is a spindle that you can put your bobbin on to wind it. Make sure this spindle is pushed to the left when you want to sew and pushed to the right when you want to wind a bobbin.
Oct 04, 2009 | Singer 3116 Simple
BOBBIN WINDER WON'T WIND
bobbin wont wind on sewing machine
Apr 03, 2009 | Kenmore Sewing Machines
Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Jan 22, 2009 | Kenmore Sewing Machines
Singer 2263 Mechanical Sewing Machine Logo
67 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
