Question about Nokia N70 Cellular Phone
Low batt problem
Phone will not put a good charge on battery. If I charge in another phone the battery is fine but if I charge in the n70 it only gets a charge that shows low batt within a few hours.
  • 1 more comment
  • ufone May 20, 2008
    phone will not put a good charge on battery. If I charge in another phone the battery is fine but if I charge in the n70 it only gets a charge that shows low batt within a few hours.
  • mohammedraha May 21, 2008
    I too had the same problem. My Nokia N70 switch off if I dont use the mobile for an hour. Any solution for this problem.
  • Anonymous May 22, 2008
    same ******* problem with my n70 which is only two months old... battery dries up in 3-4 hours !!!
    Habit-Forming:
  • 55 Answers
So if its not a battery issue, than sounds like its software issue so I would recommend backing up your phone and doing a Factory Data Reset.
Posted on Jan 12, 2017
    Master:
  • Nokia Master
  • 478 Answers
I know a great app with fast charging screen feature, which can boost your charging speed by 30%! It's totally free-LEO Privacy. it has many other features LEO Privacy Applock Hide Safe Android Apps on Google Play
Put it into the water
Posted on May 29, 2008
My phone was working fine, I put it to charge the next day I realized was not charged
probably your fone batt is extrem low. you need to find 5volt dc source to "recharge" your batt to the minimum state so you can recharge it again using your daily charger.
Sep 23, 2015 | ZTE Boost Max Black Boost Mobile
My nokia 5200 has a battery charging problem.it shows its charging but the battery is still low when i remove from charging.and it gets switched off
Once i had the same problem like yours. I thought that my charger or my handphone were the problem. I borrow my friends batt, then i put it in my nokia, then it was working!! it means the problem is in my batt. I went to the service center, then they said my batt is broken. i tried to find another sources afterwards, then they said the same. I had no choice, i should buy new one. uufftt!!!
May 10, 2011 | Nokia 5200 Cellular Phone
When making a call or answering a call the mobile battery level comes down and showing battery low and get switched off. i have changed orginal battery and formated after that also same problem occurs.
maybe your did not reformat your mem card?
if you just replaced the battery with a brand new genuine one from a reputable dealer then we have no prob with the batt except you get a factory defect if your lucky. hehehe...
some that they call it viruses can also drain a new battery even at full charge in just minutes.
try to remove your memory card and format it in your pc or other non-nokia phones.
reformat again your phone by typing *#7370# and wait until your phone boots again.
don't insert back your mem card until you're certain they are clean and being reformatted again. cause some viruses goes to your mem card.
try it.
Dec 29, 2010 | Nokia N70 Cellular Phone
My Xog GPS will not hold a charge. With low batt it keeps turning on then shutting off --- until the batt is totally dead what do i do
Get a new battery at Batteries Plus. Take the GPS in and they have to switch the connecter end from the old battery with the one on the new battery (part # PDA-192LI) and put the unit back together and everything will work fine. I just did it today. The cost was $25.19 :)
Aug 12, 2010 | Lowrance XOG GPS Receiver
Ho how to speed my n70?
remove unwanted startup programs and make sure ur phone memory is not full to speed up just self format by pressing *,call< and power on make sure ur phone batt is full charged
May 24, 2010 | Nokia N70 Cellular Phone
Battery light stays on.
If you disconnect the battery for 20 min it should kill all memory and reset everything.If not you charge is still low charge up your batt. with a charger.and test your alt. output 13.9-13.7 you have to check the book.I'm not to sure on that.You might have a voltage regulator problem bad batt. Or somthing is hooked up wrong. Mabey the old alt was fine. Have the batt. tested. All alt. well most are rebuilts so you might have a bad one it happens.Make sure that it's putting out a charge.
Loose alternator drive belt or loose or corroded battery cables. The battery itself may also be bad.
Sep 22, 2009 | 1998 Chevrolet C2500
How can i solve the problem of low usage of battery packup?
Friend, since it appears that way eventhough the batt is new. As a mobile phone technician i diagnose base from my experience that the problem of your phone is not the battery but the power supply I.C. called CCONT. It is needed to be replaced or resolder especialy if it is shorted.You need mobile technicians to solve this problem. good luck
Apr 29, 2009 | Nokia N70 Cellular Phone
Nokia1100 not charging
Battery needs replacing?
Feb 25, 2009 | Nokia N70 Cellular Phone
Phone won't start
Did you turn the phone off before removing the battery? I sure hope so. If not, you may have to junk it. My father has done that to several phones now. He pops the battery out to put the charged on in, but forgot to turn the phone off. I just recently bought him a phone that sets itself to power off when the battery cover is popped off.
Dec 23, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Nokia N70 Cellular Phone Logo
188 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
