Question about Kenmore 95822 / 95824 / 95829 Electric Kitchen Range
Sears (Kenmore) drop-in unit, Model 911.4698815. Ran the self-cleaning cycle - now it's showing Error Code F3 and neither the bake element nor the broil element will work. Any help would be appreciated. Thank you.
  • 15,935 Answers
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Posted on Sep 26, 2010
Have a Kenmore Electric Range Model- 790.4671. Ran the self cleaning program. Error occurred at the end of cycle. F10 and F30. Oven will not unlock. Show oven locked and a picture of a lock. Oven is...
Sorry to read about your problem
Your F10 code means Runaway Temperature and f30 means open probe connection. try this and see problem comes back.
1. Unplug the unit or turn the circuit breaker off for 60 seconds.
2. Now, restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
3. Check to see if the error code is still displayed on the range.
Note: General information for resolution to this problem, is based on information provided in question. Contact certified technician if problem persist. Sears Repair 1-800-469-4663
I have tried to help you.Pleas help me by Vote/Rate my response. Thanks.
If you are in the Denver,Co area I can help you out.
Dec 20, 2010 | Kenmore 46713 Stainless Steel Electric...
We are using self clean feature. continuous beep about 20 minutes into cleaning screen shows F# locked door and beeps nonstop. what can we do to stop beeping but still proced with self cleaning?
F3 is a bad oven temp sensor. The sensor fail F3 code will appear if during self clean that it senses temps above 915F, or there is an open / short in the temp sensor. The only thing you can do is replace the sensor. Just getting the oven door open can be a real pain as you have unlatch the oven door lock to get to the screws that are in the top lip above the oven door so that you can change the sensor. Depending on model you may have to reach through a burner to manually unlatch the oven door lock or remove the side panel of the oven to manually unlatch the door lock. On most units It will not continue to self clean with an F3 code detected. Once an F3 code is detected the ERC shuts off power to the bake and broil elements so that it does not catch fire from a run away temperature condition.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Ovens
Error code E3 - F3 on Whirlpool oven, RBS275PDB12
Error E3-F3 says that the Oven temperature is too high(Clean mode).You might have to replace the Oven Temperature Sensor(RTD).
Apr 19, 2009 | Ovens
Control screen flashes F2 and F3; now oven element won't heat.
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
We have a Kenmore glasstop self cleaning electric range (super capacity w/ ultrabake)- not sure of the model # or year. We were baking and the heat suddenly went up on its own and we have a message EZ F3...
Sounds like bad control if it ran when it should have been off. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Kitchen Ranges
Oven over heats and gives a 1D11 fault
I have a similar unit with a similar problem, and found the Maytag troubleshooting manual online. Code 1d11 means the the unit reached 600 degrees (not supposed to get that hot). Basically, it had a runaway temperature. The computer does not know why it happened, so it just tells you that it happened by showing code 1d11. But you can tell what went wrong by your description of the problem: the broiler element was turned on without any command from you. Which means the swithc/relay in the electronic control unit is bad. I am guessing it was fried when you ran the oven through the self-cleaning phase (should not get fried with this little of heat--it was defective to begin with). Mine just went bad after 4 years of use. You can get an electronic control unit for this unit for around $170 at Sears online parts store. Notice that Maytag has replaced the old part number for this electronic control unit with a new one, which probably means they had a design flaw and have fixed it.
Oct 23, 2008 | Jenn-Air JES9800BAS Electric Kitchen Range
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Frigidiare electric range time bake and self cleaning
Usually f3 means a faulty oven temp. sensor. If you give me the complete model # from the sticker on the oven I can tell you for sure.
Nov 06, 2007 | Frigidare FEF336EC Stainless Steel...
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore 95822 / 95824 / 95829 Electric Kitchen Range Logo
190 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
