I have an hp computer its 5 years old its a 1223w i belive the problem i have is it shutting down for no reason then it takes me about 15 minutes to get it to work again could you give me any idea what it could be
    Guru:
  • 277 Answers
Windows got currupt. may be antivirus has deleted some system file. reinstall the windows
Posted on Sep 12, 2010
HP Stop code CRITICAL PROCESS DIED how do I sort this out
NO COMPUTER STATED of the 1000 made in 36 years.
or 1984 to now HP.
no OS stated, of 14 by Microsoft, or linux, or freedos or OS/2
wow only the word DIED is clear.
no screen photo's presented.
The process is complex, after all its computer not a toaster.
3billtion transistors at least there.
that's billion with a B.
my guess, (par for here)
is OLD HP PC< like 20 years old>
running what, XP? the virus magnet and loves to BSOD>?
my guess is windows, BSODs with a blue screen of *****
as even GILL BATES did on stage long ago?
top reasons are
1: bad power, if laptop take out the big battery.
2: bad RAM. try them 1 by 1. to find which one is bad. if have 2 easy
3: XP is corrupted, as all are, or will soon be, read the news lately?
XP is now Dead for 3 years, and is a virus magnet.
VISTA was shut down this spring.
4: bad video card or its driver bad is super common way to get BSOD.
5: loading PC chip drivers not for you old PC, = BSOD.
BSOD the blue screen if *****, that millions get ?
Aug 17, 2017 | HP Computers & Internet
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
Shutdown takes 3-5 minutes. Hp pavilion dx7-1245dx vista 64-bit now takes anywhere between 3-5 minutes to fully shut down or restart. I have all updates from windows and hp and have checked numerous sites...
hi there is a few things u can do which might help
if you use internet alot /goto tools top right hand corner /internet options/ /go to deleat/then click deleat
this will take a while this deleats rubish
which takes up hard drive space
next /go to start-all programs-accsessires-system tools/ disk clean up
these are just a few things you can do might help a little
Sep 03, 2009 | Computers & Internet
Pc will not turn on
I would be willing to bet your Power Supply has failed. A new supply should cost you less than 80 dollars and take no more than 15 minutes to install. Take out your old supply and take it to a Computer Shop to make sure you get the right style.
Feb 15, 2009 | HP Pavilion dv9000z Notebook
Laptop overheating and shutting down
CPU IS OVERHEATING AND OVERWORKING MIGHT BE A VIRUS OR A HANING PROGRAM
Jan 20, 2009 | HP Pavilion dv8000z Notebook
KV-27TH70 SONY TV Shuts Down for no Reason
hi there, normally bad/broken connections in the horizontal or on the flyback. hjope this helps.
Aug 04, 2008 | Televison & Video
My computer runs for 2 seconds then shuts down.
First off all download the manual
> Make sure that motherboard is placed correctly
> Front panel connection plugs are there on the manual (4plugs POWERLED,HDD LED,reset switch,power switch) LED plug has positive negative...be careful
May 14, 2008 | Computers & Internet
Monitor has shadows from left to right
Try changing the cable that connects the monitor to the computer, that might improve things slightly, but because you said that it works for the first 15 minutes I'm skeptical that the cable has anything to do with it.
The monitor is near the end of it's life. There's not much that can be done.
Jan 24, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Computer Keeps Shuting Off/Battery is Useless
Try running a good malware program like AdAware. Often these spyware programs can driver your processor to 100%, causing it to heat up too much and shutting things down. Once you have the anit-spyware loaded, bring your system up in safe mode. This will allow the spyware to search the hidden partitions on your fd, along with the rest of the disk.
R-.
Oct 18, 2007 | Toshiba Satellite M45-S355 Notebook
Computers & Internet Logo
David Payne
David Payne
