Question about Thermador Ovens
Have a Thermador model CT227NW-3 double oven. The digital display light for the lower oven works sometimes. Need a knob for the upper oven and it will not hold temperature all of the time. What do I need to replace?
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
SOURCE: THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Posted on Dec 08, 2008
  • 3 Answers
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Posted on Nov 27, 2009
I have a Jenn Air JJW9830DDP double oven electric, and the temperature in the oven is about 100' less than what it reads on the display. I tested the temp sensor and it ready 1073 ohms. Any s
Well, your temp sensors can still be bad. If not, there's always a new control board you buy!
However, I wouldn't drink water from that oasis without making ABSOLUTELY sure I'm not seeing a mirage.
The only common denominators between your upper and lower oven temp readings is the firmware and the oven thermometer you are using to visually check the temps.
What type of thermometer are you using to check your oven temperatures with?
If it's not a digital thermometer used specifically for testing ovens, you might just be leading leading yourself astray.
You need a calibrated thermometer. If I don't have a calibrated digital thermometer on me, I use two or three oven thermometers (the dial type) and average the readings.
It's the only way to be as close as possible with a digital probe.
If you have thoroughly verified that your oven is in fact not reading the correct temperature, then you can adjust it +/- 35 degrees F via your oven's control panel.
To adjust the oven temperature:
1 - Press Setup pad.
2 - Select the down arrow to scroll to the next screen.
3 - Select Temp Adjust using the Quickset pads.
4 - Select upper or lower oven (select models).
-"Set temperature offset using the Upper Set Knob" is displayed.
5 - Enter the desired temperature change using the Set knob.
The temperature can be increased or decreased up to 35 degrees.
The temp. change is displayed at the top of the window.
6 - Press the Set knob to accept the change.
Now, if you are still worried about the temp. reading being off, replace both the upper and lower temp sensors. That's all you can do besides replace the main board.
Oct 24, 2014 | Jenn-Air JJW9830D Electric Double Oven
Help!!! Need Replacement knob kit for my Thermador double oven!
these are NLA. No Longer Available.
Try to get something that is acceptable to you and fits by researching "oven Knobs" at repair clinic dot com and selecting by looks and size.
Nov 09, 2013 | Thermador SC302T Electric Double Oven
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
I want to use top and bottom ovens but at different temps - how do I do this
To Set a Cook T ime:
1. On double oven models only, press UPPER OVEN or LOWER
OVEN for the one you want to set.
2. Press BAKE or CONVECT UPPER (on some models).
Press the number pads to enter a temperature other than the
one displayed.
3. Press COOK TIME.
4. Press the HR and MIN "up" or "down" arrow pads to enter
the length of time to cook.
5. Press START/ENTER.
The start time and stop time countdown will appear on the
oven display.
On double oven models only, when both upper and lower
ovens are being used at the same time, touch UPPER OVEN
or LOWER OVEN to display the respective cook time.
When the stop time is reached, the oven will shut off
automatically and "End" will appear on the oven display.
If enabled, end-of-cycle tones will sound, then reminder
tones will sound every minute.
Repeat the process by choosing the other option of UPPER or LOWER OVEN
Sep 04, 2011 | Whirlpool RBD305PD Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Nov 27, 2009 | Thermador SC302T Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Ovens Logo
143 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
