Question about PowerBright Power Bright PW2300-12 12 Volt Power Inverter
No ac output - PowerBright Power Bright PW2300-12 12 Volt Power Inverter
  • 1,339 Answers
A few checks 4 ya.. check and test fuse or replace must have a hot battery ! nothing ? dig inside of it(only if not in warranty) use volt meter to see if it is getting 12 volts inside of the unit.. thats about all you can do.. buy a new one return this bad one...
hey if i was of help please tell me/// thanks jay
Posted on Sep 12, 2010
My gilera seems to have voltage drop and cause my engine to cut off when i press my brake.
Hi, Herman the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator
Start motorcycle and change Voltmeter to AC volts.
Probe both stator wires with your meter lead.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale.
Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator IB test or Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire.
The reading should be Infinite.
With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.jetav8r.com/Vision/Stator/fault_finding_by_www.electrosport.com.pdf
Feb 21, 2017 | Gilera Motorcycles
Transceiver signal interference
The FT-840 uses a die-cast RF power amp with thermally switched fan to ensure full power output (up to 100 watts). The digitally synthesized local signals ensure clean, low-noise transmitter output on all HF amateur band. There might be no AC line interference. it has strong Rf output. any AC line intersect does not affect its radio performance. Check and adjust RF power so to maintain proper output. some times more RF power generated at the output may cause interference. adjust Rf power..Even some unfiltered Noise getting the other end of the end may calso cause interference. Check for any Ripple voltages present at the output. Contact authorised service station for further Rectification. thank you shanth
Dec 23, 2007 | Computers & Internet
2005 vl 1500 charging system system not charging checked generator 3 wires giving pluss 80v at 5000rpm instaled new rectifier voltage across battery under 13 volts could faulty battery be problem
Hi, Anonymous the following is a comprehensive charging system test that I found on a Rider Groups website
1. Battery Test: The battery needs to be a fully charged battery that has been load tested to ensure proper readings. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Most places like Auto Zone, Advance Auto, and Pep Boys will charge and test motorcycle batteries for free. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, Measure DC Volts across the battery terminals (you should have a reading of approximately 13.2-15 DC Volts).
4. Stator Checks/Rotor Check: Each of the following tests isolate the stator & Rotor, If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
AC Output Check:
Probe both stator wires with your meter leads.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. (Reading will vary depending on system, check service manual specification)
Generic Specs:
Resistance should be in the range of 0.1-0.5 Ohms. (Reading will vary depending on system, check service manual for specification)
Generic Specs:
Identifying Wires:
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.crowitis.com/images/VL1500_Charging_System_Wiring_Upgrades.pdf
stator output voltage
Suzuki VL1500 Service Manual
OEM parts for Suzuki
Suzuki VZ1500 Owner Manual
Jan 16, 2017 | Motorcycles
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
My yamaha virago 1100 will not charge battery while running
Hi, Anonymous the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
5. AC Output Check:
Generic Specs:
Generic Specs:
Identifying Wires:
ViragoTechForum com
http://www.sloneservices.com/SilverBack/Other-Stuff/VS-1100-chagre-syst.pdf
Yamaha Virago XV535 1100 1981 1994 Service Manual
OEM parts for Yamaha
Yamaha Virago XV1100K Owner Manual
Jun 16, 2012 | Yamaha Motorcycles
Xantrex Inverter/Charger has no AC output
HI
Checking AC Output
1. After the battery voltage and connections have been checked, disconnect the inverter.s AC output wires from
the power distribution system and connect a light to the AC output of the inverter/charger.
2. Disconnect the remote panel to eliminate it as a possible problem.
3. Turn the inverter ON using the power switch on the front panel of the inverter. The 100-watt light should
illuminate. Measure the voltage at the AC output wires using the multimeter. The reading should be 114.126
VAC or approximately 230 VAC if the unit is an international model. If the light does not illuminate, there is
a problem with the inverter. Contact Xantrex technical support.
May 21, 2010 | Kitchen Ranges
Vgn fs 980 adapter how to tell if it is not working
AC adapter? Test the output voltage.
Use a multimeter.
Stores like Radio Shack, Walmart, and auto parts stores, for a few examples have cheap one's you can buy.
About $12.
Set the multimeter knob to DC volts, and the 0 to 50 Volts scale.
The middle hole of the AC adapter plug is the Positive connection. This is where the Red lead goes.
The outer shield of the plug is the Negative connection. This is where the Black lead goes.
Look on the AC adapter for the OUTPUT VOLTAGE
(Not shouting)
Example:
I'm looking at an AC adapter for an IBM Thinkpad 370, right now.
INPUT: 100V 50-60Hz 130A
OUTPUT: 18V ~~~3.36A
The Output voltage is 18 Volts
The Output Voltage of your AC adapter should be close to this.
Dec 20, 2009 | Sony VAIO VGN-FS980 Notebook
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
PowerBright Power Bright PW2300-12 12 Volt Power Inverter Logo
138 people viewed this question
Top PowerBright Electronics - Others Experts
Jay Finke
Jay Finke
ray gallant
Are you a PowerBright Electronics - Other Expert? Answer questions, earn points and help others
