Question about Cycling
User manual for v-fit mc2 - Cycling
By starting up "something" is asking permission to install mc2. What is the the meaning of this and what does this mc2 does to the functioning of my desktop?
Perhaps the install is trying to open a file with an mc2 file extension. Has this prompt at startup just started happening or has it always been happening? If it has just started did you recently download something? MC2 files are Misc Files primarily associated with Mastercook File (Sierra). There could be other programs which also use files with this file extension. It sounds like your system is trying to open a file with an mc2 file extension and does not have the proper program installed to do so. It is asking you whether you will allow it to install the file for you.
Mar 10, 2015 | Asrock Computers & Internet
What games can I play with the Mad Catz MC2 Racing Wheel
you can play need for speed carbon, need for speed underground and underground 2,gran turismo
Sep 02, 2012 | Mad Catz MC2 Racing Wheel for PlayStation...
Why won't my universal mc2 wheel work with my xbox 360, are these not compatible. None of the output leads would fit into the xbox 360, so I actually got an adapter lead that fits into one of the 3...
There should be a USB cable that came with the wheel that connects directly to the Xbox 360. Are referring to the Madcatz MC2? If so then you might be missing the USB cable connector? You can't modify the other inputs to feed into the Xbox 360. You need to use the cable that comes with the wheel.
Also, some games are not compatible with the wheel.
Jul 19, 2011 | Video Game Consoles & Games
I have just received a Madcatz MC2 wheel for the XBOX360 that I purchaced on ebay. However I cannot find out how to connect it as the lead from the wheel has a round plug and I can only assume that I need...
you have to go to amazon and type in "XBOX Controller to PC / MAC USB Cable Adapter" it only cost $4 plus shipping i had to do it to get my Mad Catz wheel to work with xbox 360. I paid $10 for mine rather then a hundered and works fine with all games.
Aug 20, 2010 | Mad Catz MC2 Universal (6320) Wheel And...
Lost manual to set my madcatz mc2 item# 6320 between systems can
http://www.madcatz.com/Default.asp?Page=43 for mad catz manuals
Jun 28, 2009 | Mad Catz MC2 Universal (6320) Wheel And...
Someone gave me the xbox mc2 race wheel so I
XBox games don't play on Personal Computers, from what I've read.
Stick it in your XBox and see if it comes up.
Jun 18, 2009 | Mad Catz MC2 Universal (6320) Wheel And...
How to connect mc2 racing wheel to ps2
The MC2 wheel should have a wire with several connectors on the end. One of the connectors should be identical to a PS2 controller connector. Use this instead of the controller.
My MC2 did not work at first. It is not the wheels fault! PS2 steering wheels are powered, a fuse often goes out in the PS2. Regular controllers will work, but anything powered will not.
Controller rumble requires power as well. If the rumble no longer works on the controller then the wheel will not work either.
Jan 19, 2009 | Video Game Consoles & Games
Mad cats mc2 with pedals
The easiest way to do this is to go online and order a PS2 controller to PC adapter on amazon.com or some other site. I have a Madcatz MC2 and a Ps2 controller to PC adapter (a cheap one -_-") and it works okay (I'm having a lot of trouble with the pedals though).
May 28, 2008 | Mad Catz MC2 Universal (6320) Wheel And...
Cycling Logo
94 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
