Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
DCE33PA-1SB will not make ice. Runs but does not make or retain ice when it drops.
When I press the activation lever to dispense ice I get a sound of something turning but the ice does not drop out and the arm in the ice ben does not turn
On most dispenser systems, there is a motor in the back of the bin that turns the auger to pull the ice up to the dispensing hole. You say you hear the motor. On the motor end is usually a fork type prong attached to it that slides into the back of the auger. It may have come loose and is not driving the auger. Possibly a bad retainer clip or a nut came loose.
Mar 06, 2015 | Whirlpool Refrigerators
Have a scottsmanicemachine doesnt drop ice compressor on water on water runs on coils goes to harvest but makes no ice coil usualy have a ice buildup before it harves
The water runs over the evaporator coil(plate) until the ice gets thick enough, than when the ices touches a switch for the thickness you have it set for, it to go into harvest and the hot gas from the liquid line goes through the evaporator making the ice fall. If you are not making ice, it is the refrigeration system not working, so check the refrigerant, compressor etc like you would on any refrigerator or freezer
Dec 09, 2014 | Coffee Makers & Espresso Machines
Icemaker starts then stops
The drop sensor is faulty, fooling the machine that the ice has harvested so it restarts. Eventually you will just have a solid block of ice. Replace sensor (magnetic reed switch)
Mar 08, 2014 | U-Line Icemaker
Scotsman ice maker wiring diagram dce33pa
Service manual
I worked on one recently and wrote about it HERE
Below that is a list of ice machine links to service manuals.
Jun 30, 2011 | Scotsman DCE33PA1BC 15in Built-in...
My Scotsman undercounter icemaker is not producing much ice and the little it does produce is watery. How do I fix? The model # is DCE33PA-1WB. Is this model discontinued?
Wow! That the first time I saw one of these! Never even knew they made it under
counter types.Anyway I'll give it a shot,Let's see here It's not producing ice as it should huh? I Googled it for complaints and found this for you,Linda go to
(http://www.retrevo.com) and once you get there type in (Scotsman DCE33)
into site search engine and it'll list service manuals for your model to seek a fix.
It stated how to make maintenence adjustmments ok now good day!
Jan 02, 2011 | Scotsman 15" Luxury Consumer Ice Machine
Making and dropping ice, but not retaining ice...evidently melting...feels cold, but no accumulation. Is the white tube hanging down supposed to be connected to the drain line in the bottom?
yes to drain line. Clean the condensor and evaporator first. Check the spray jets to see it they are clogged. There is a screen on the inlet water valve as well. Check door seals and cabinet tight.
All else fails look for oil around the hot gas valve.
Jul 06, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman Ice maker DCE33PA
check the condenser coil it maybe plugged up use a hand brush to clean out coils and if you can use a air compressor to blow out coils this is the best way and this coil is used to remove heat from the system if it looks clean you can shine a flash light on the opposite side to see the light though the coils to check deep inside other then that the water vale may have a slight leak allowing warm water to seep though prolonging the freeze time or  you may have a compressor with weak valves or low ref. start with the maintenance thats the first thing people usually over look the dirty coil that you should clean once to twice a year that can over heat the compressor and cause it go out.
Dec 05, 2007 | Freezers
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
298 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
