Question about Mr. Coffee MRCTB Coffee Maker
Can i shut off the beeper on Mr. Coffee that indicates coffee done and again when warmer plate shuts off?
  • 17 Answers
SOURCE: disconnecting beeper
CJ, The only way to turn off the "beeper" is to remove the piezo transducer from the control board/ clock module. Not the easiest of operations to perform. Noise-canceling headphones for your dog might be a quick fix seeing as most municipalities have ordinances covering the discharge of firearms in the kitchen........ and you never know, Sunbeam might actually come through for you without you having to shoot the coffee maker!
Posted on Nov 03, 2007
SOURCE: Warming plate trips GFI.
Well, it's still a short to ground. But sounds like it's not simple. Needs to go to the shop, unless you want to try your hand at it.
Charlie
Posted on May 10, 2009
  • 199 Answers
SOURCE: Mr. Coffee TFTXC85
run 2 cups of vinegar through the coffee pot brew it do it twice. this will clean the calcium out. then rince out out and brew one batch of water to clean.
Posted on Jun 23, 2009
  • 447 Answers
SOURCE: Have a Mr. Coffee SKX12 - shuts off right after brew cycle
Sounds to me like you need to set the unit to the correct/actual time.
Posted on Apr 11, 2010
  • 189 Answers
SOURCE: I have a Bunn NHB
If you will call customer service at 800-352-2866 with the model and date code, we will be happy to assist you with this issue.
Posted on Jan 18, 2011
How long does the heat plate stay on after brewing?
It depends on your brewer. Most will stay on as long as power is applied. IE; the Bunn pour over brewers are always on as these are office machines that always have coffee on around the clock. The only way to turn them off is to unplug them (or on/off switch)
* Check your manual for the options of the main heating plate. Most brands will have a separate switch for each 'side' warmer plate. Turn them on or off as needed. Note; try not to leave a brewed coffee pot on heat longer than 45 mins. Transfer brewed coffee to an 'Air pump" pot or similar thermos decanter.
* Larger brewers (1 gal and up) don't use warmers and directly brew into a decanter. These decanters are replaced with each brew and moved to the serving location. Some of the larger decanters have built in warmers using warmer power stations.
* Most (older) home brewers stay on as long as power is applied or On/off brew switch is on.
* Some of the newer (last 5 years) have auto shut off. But you must check your model and manual if it has this function which may require the customer to set it up for auto shut off option.
* Final, check with your MFR or coffee vendor. Especially if your equipment is on loan from a vendor. Have the vendor check your brewer and maintenance. They should advise you of the proper brewing methods for this brewer.
Aloha, ukeboy57
Mar 12, 2018 | Coffee Makers & Espresso Machines
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
LOOKING WITH NOLUCK YET FOR A SMALL HOT PLATE TO KEEP COFFEE HOT/NOT HALF-*** WARM
Saw a coffee warmer at WALLMART in Montr?al Canada, look it up where you live.
Oct 29, 2014 | Coffee Makers & Espresso Machines
Apr 10, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
My stainless steel Mr. Coffee maker just quit perking coffee and the water does not run totally through. It has been perking slower and less quantity but today I cleaned it by running vinegar through it...
this is set up on a conventional mr coffee; if the hot plate is not as hot, it will not work, on the newer ones, a small chip could be getting hot, and like a car, it will either shut down or work part time. send it back to mr coffee, and they'll repair it, but it might be cheaper to replace it.
Jul 02, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee TFTXC85
May 22, 2008 | Mr. Coffee TFTX85 Coffee Maker
Bunn UPR warmer too hot
Try connecting two elements in series. See if this keeps it hot enough. (One switch controlling both burners.) See if another brand of burner will fit in the hole. Check to see if the wattage is lower.
Feb 06, 2008 | APW Wyott Mr. Frank Hot Dog Broiler & Bun...
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Disconnecting beeper
Sep 09, 2007 | Mr. Coffee FTX24 12-Cup Coffee Maker
Mr. Coffee MRCTB Coffee Maker Logo
87 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
