Question about Samsung DVD-V1000 DVD Player/VCR
DVD player will not open..is there an override button to open tray?
  • 4,102 Answers
Hi no im afraid their isnt if it was a pc or laptop then their is a little hole you can poke a pin in just below the drive but they never fitted them on dvd players.
the problem you are having is due to the plastic runners inside the player wearing down and this causes them to stick, now the only way you can get it open is to get a knife or strong flat bladed screwdriver and then when you press the open button get it in one of the sides and pry it open once its open you should find it may keep working for a month or so but eventually you will have the same problem.
now as for getting it repaired the problem with this is that the parts and labour would cost more than its worth so the chance of anyone fixing it for you is slim, its best if you pry it open it may be hard to do but it will come open and you might find you will have no more problems with it, some people never have another problem and it may work for as long as you need it to but most the time it will only last a month or two before it gets stuck again.
let me know if you need further assistance ok.
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 12, 2010
Testimonial: "Thanks bunches I will try that...tried prying it before but I will use a little more muscle this time."
How do I get a stuck DVD out of a Samsung #bd-d7500/. The tray won't open
Try switching off from wall then hold the eject button and switch on machine.do not release eject button , if tray fails to open check for a small pinhole on the front underneath tray bottom.this is an access point that you can push a paper clip in to override the mechanism.if still not opening then you will have to open case and manually remove but be aware the case screws usually have security tabs to void warranty if damaged.
Jan 31, 2015 | Samsung Televison & Video
Tip
Matsui DVD-110 VCD Fix
Matsui DVD-110 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-110 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-110 DVD Player:
  1. Press the Open button on your remote control to open the drive tray
  2. Place an audio CD in the drive tray
  3. Press the Open button on your remote control to close the drive tray
  4. Press the Menu button on your remote control
  5. Press the 1 button on your remote control
  6. Press the Index (1-All) button on your remote control
  7. Press the Open button on your remote control
  8. Press the 1 button on your remote control
Your Matsui DVD-110 DVD Player can now play VCD's.
I hope that helps.
___________________________________________
Matsui DVD-110 Region Free Fix
on Apr 25, 2010 | Televison & Video
Tip
Matsui DVD-122 VCD Fix
Matsui DVD-122 DVD Player VCD Playback Fix
Would you like to unlock your Matsui DVD-122 DVD Player to play VCD's?
Follow these steps to unlock your Matsui DVD-122 DVD Player:
Your Matsui DVD-122 DVD Player can now play VCD's.
I hope that helps.
Matsui DVD-122 Region Free Fix
The dvd player will not open
Usually there is a small hole in the front of the DVD tray which you can push a needle into to override the gear to gain access.if not power off the machine then holddown the eject button without releasing whilst switching on.this will usually override the lock.
Oct 19, 2014 | RCA RTD317W Theater System
Brand new phillips hd dvd player, door will not open to allow dvd to be loaded
First of all check that there's no "travel lock" wedge or safety catch anywhere; some players will be so equipped for transport, and you won't be able to open it until the wedge has been removed or unscrewed.
Assuming this is not the case, a defect must be contemplated. If the device is brand new, I'd bring it back to the shop and get another.
Otherwise, there should be a tiny hole in the front, near the eject button. Place an opened paperclip inside, and push against the resistance. The internal lock override will allow the tray to be manually ejected.
If afterwards the device works, the tray was just jammed - it happens. Nothing to worry about.
If it continues to not operate properly, e.g. it won't close, or once closed, it won't open again, the tray drive is probably defective. Even if it's only out of kilter, it's not worth it to try to repair it - just bring it back.
Jun 07, 2010 | Philips Phillips 16X External DVD 2XRW...
Tip
Tevion DVD-200 VCD Fix
Tevion DVD-200 DVD Player VCD Playback Fix
Would you like to unlock your Tevion DVD-200 DVD Player to play VCD's?
Follow these steps to unlock your Tevion DVD-200 DVD Player:
Your Tevion DVD-200 DVD Player can now play VCD's.
I hope that helps.
Tevion DVD-200 Region Free Fix
DV2140 DVD player door will not open.
Most manual overrides involved pressing and holding either the eject button or the power button on the machine itself (not the remote). Try those first.
If that doesn't work reply with the following info:
Will your system turn on/off?
Are you able to play the disk that's in the drawer?
Jul 09, 2009 | GoVideo DV2140 DVD Player/VCR
Locked dvd tray
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Mar 29, 2009 | Televison & Video
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Lost manual for Sanyo DVD player equipped with TVG
Hi.
I dont know your particular sanyo dvd but this may work try it.
PUT UNIT IN STANDBY. HOLD EJECT BUTTON IN AND PRESS POWER BUTTON.
Or try this.
PRESS AND HOLD OPEN TRAY BUTTON ON FRONT OF UNIT.
If these work great.
If not im sorry I will try & find more info for you.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | Sanyo DVD-SL20 DVD Player
Samsung DVD-V1000 DVD Player/VCR Logo
260 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
