Question about Apple iPod nano
Apple ipod 8g model a1199, 2nd gen white screen tried menu+center button and restore no effect
  • 3,530 Answers
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thank you for using Fixya!
Posted on Jul 03, 2011
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
Tip
IPod Nano/Video/Touch Resetting
One day your using your iPod and all of a sudden, boom. It turns off and refuses to work or read by your computer.
You might get the apple logo, but thats where it ends. In this case, theres a few things that can probably bring you device back and kicking.
iPod Nano/Video(Classic)
6th Gen Nano
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
4th and 5th Gen Nano/Classic/Video (CLICK WHEEL VERSION)
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
In case the reset does not work, the alternative is to connect the device in disk mode and restoring it.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. zero77cool.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
This will enable a black/white display. Restore it using iTunes.
If the above doesnt work, then Im afraid its time to repair your device.
Note: images and part of help copyright © 2011 Apple Inc. All rights reserved
on Mar 13, 2011 | Electronics - Others
I Have a 3rd gen ipod and its stuck on the lanuage
Try reseting it. If that does not resolve the issue, put it into disc mode and restore again. If these steps do not help please let me know.
Learning how to reset or restart your iPod:
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Putting iPods with a Click Wheel into disk mode Before placing the iPod into disk mode, you should verify that it is charged. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
May 05, 2009 | Apple iPod nano 3rd Generation
My 1st gen ipod has a blank screen
If your ipod has a white screen reset your ipod. You can do this by pressing and holding the menu button and the center button in your ipod. Keep pressing both until the apple logo appears this should reset your ipod. If it does not work try again. This worked for mine good luck :)
Apr 15, 2009 | Apple iPod nano
Ipod frozed
Press and hold the center button while holding down on the menu button. This will reboot the Ipod.
Next load the ipod into the computer. When Itunes loads up, select your Ipod and press the restore button on the screen of Itunes.
Jul 10, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod nano 3rd gen 4gb
this seems like a hardware problem, most likely you have to send the ipod in for repairs.
you can try another reset and even attempt a restore from this page
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
reset on the top, restore in the bottom.
heres the apple service assistant
https://selfsolve.apple.com/GetWarranty.do
heres also another place that might be helpful in repairs
http://store.ifixipodsfast.com/
Jun 13, 2008 | Apple iPod nano 3rd Generation
Ipod Nano 3rd Gen - Screen is white and frozen
start with this
if it doesnt fix it then you most likely have a broken screen.
May 02, 2008 | Apple iPod nano
I can't view my Photo's...
Try resetting it. Hold down the Menu and center button until the screen is dark.
If that doesn't work,Restore it. Plug it into the computer and click "restore" when it pops up in itunes.
Dec 30, 2007 | Apple iPod nano
Frozen screen on 5th Gen Video ipod
Stuck or frozen
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Dec 19, 2007 | Apple iPod MA446LL/A MP3 Player
Frozen Ipod Nano
  1. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  2. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  3. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  4. Connect it to your computer.
  5. In iTunes, select Restore to Restore the iPod firmware. This erase everything on the iPod.
Dec 04, 2007 | Apple iPod nano
Apple iPod nano Logo
519 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
