Question about HP 4570C Flatbed Scanner
I've lost my transformer for the scanner. What is the voltage and amperage needed to drive the scanner?
24 volts at approx 1.2 Amps
Posted on Jul 17, 2011
What is the input and output amperage of 15G fender guitar amp.trandformer?
Transformers change the voltage and not the amperage. The input would be 110-120 volts. The output voltage would be stamped on the transformer or the circuit board where the transformer is mounted. It either steps it up or down. Make sure to disconnect it before investigating. Good luck!
Mar 13, 2016 | Fender Music
I've lost the charger to it and I don't know what charger to use or amp so I can't use it unit its charged?
Sometimes the voltage is printed or cast into the plastic near where you plug in the power plug, look carefully it may be there. Once you know the voltage you can estimate the amperage. You can go as high (but not lower) as you like on the amperage since transformers are self regulating and only supply the amount the unit needs, not necessarily the maximum amount its rated for.
Mar 11, 2015 | Heating & Cooling
Need more power
No advantage; no more power. P= I x E
Amperage times the voltage. If you increase the voltage the amperage will just go down .
Jan 02, 2014 | Dent Fix Fix Dnt-595ii Shark 2 Spot Weld...
Sanyo sound system built-in transformer amp usage
If no one has the specs on this transformer but you know the power rating, apply this formula: Power/Voltage= Amperage. It might not be a big help but it sure will put you in the right range. The other solution would be to obtain a schematic or parts list for the unit. Hope this helps!
Nov 30, 2013 | Sanyo Audio Players & Recorders
I lost the power adapter and I need to know the output voltage
I believe it is 12V 1.25A (you can use 12V 1.5A or 2A) Probably centre +ve, but look carefully at the scanner where the power lead plugs in, it may show the polarity and voltage on the plastic near the hole. Please report back? regards
Jan 17, 2011 | BenQ Scan to Web 4300U Flatbed Scanner
Astra 20000U lost the power supply where to get replacement transformer?
if you can see the voltage and amp requirements either on the machine near where it would plug in or a manual then I have picked up the transformer at radio shack and they have a set of different ends to plug in on the DC side
Oct 01, 2010 | Umax Astra 2000U Flatbed Scanner
Power connector
Usually, devices will have the voltage/amperage embossed on the plastic near where the power cord will connect. If not there, recommend looking online at website or contacting BenQ support for spec.
Also, note that polarity is important when buying replacement power connectors and there is also usually an embossing that shows if it is pos/neg.
Feb 10, 2010 | BenQ Scan to Web 4300U Flatbed Scanner
Transformer problem
HI amperage is1.25A Have the same problem myself. only one that I can see avaible is from the Xerox UK website @ £15.00.
Mar 05, 2009 | Xerox One Touch 2400 Flatbed Scanner
HP 4570C Flatbed Scanner Logo
46 people viewed this question
Seeker5211
Seeker5211
