My remote stopped working. I have tryed several univeral remotes but none work. I wondered if the infared device isn't working. No red light turns on for the remote to work with.
  • dianelind355 May 15, 2008
    This is for a Toshiba CF20C40 TV.
    It is not a projection TV.
  • 2,326 Answers
We need to know the brand and model number of your TV.
Posted on May 15, 2008
  • Jaime Hernandez May 15, 2008
    If you've have tried different universal remote control and none work, I would say that the infrared sensor is defective on your TV and will need to be replace.
    Master:
  • 555 Answers
What is the maker and model of your projection television?
Universal codes sylvania need tv
Universal codes are in ur tv univeral remote manual already.None of those codes work for ur tv brand.None of the codes people give u will work either.Return the universal remote where u bought it.Try website like Remotes.com to buy the tv original remote.
Jun 11, 2011 | Sylvania LC370SS8 Television
Tip
How to test an infared remote control device
How can I tell if my remote is working? You could invest in an infared detector pen or device that will detect the infared signal or you could use a common cellphone with camera mode. Place the phone in camera mode and hold the remote up to the camera lens. By depressing the buttons on the remote now you can actually see the emitted infared light slowed down to a visable light, thereby determining that any or all buttons of the remote are functioning properly.
on Dec 01, 2009 | Televison & Video
I have a jumbo remote, lost my manual. I would like to program it to operate a sanyo tv. I need instructions please.
First, make sure the device you want to connect with your remote is turned on, whether that's the television, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV, DVD, etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
If your device code isn't listed, try the Code Search function:
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
The codes to various devices are listed at:
www.remotecentral.com
Please note that there are often several codes for one particular device. It may take several programming attempts until you find the code that works with your device.
May 20, 2011 | Innovage Jumbo Remote Control
I need the code for a Innovage Jumbo Remote for a Magnavox TV, and a Scientific Atlantic Explorer 3100 cable box?
Magnavox TV codes for your remote are:
004, 008, 009, 062, 068, 069,
074, 075, 077, 089, 163, 165
Try each one until you find the one that works best - some codes may work but the button configuaration will be wrong and other codes may only control a small number of functions. If none of the codes work, then the remote may not work with your TV, but you can still try the code search (detailed below). Some Magnavox TVs are made by Funai, so it's also worth trying Funai codes if none of the above work.
Funai TV codes:
042, 051, 053, 155, 189, 198
Codes for Scientific Atlanta cable boxes:
006, 036, 037, 038, 075, 136, 147
Do the same as for the TV codes until you find the one that works best. If none work, try the code search feature for the cable box as well (see below). Please note the code search can take up to an hour to complete.
Finally, you should note that not all universal remotes will work with all TVs and/or cable boxes. If you've tried all of the above codes and it still wont work, then your remote probably isn't going to work with your device/s.
Regards,
BElectric
INNOVAGE "JUMBO" CODE SEARCH:
This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device.
1. Turn on the device that you want to set.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
Dec 01, 2010 | Innovage Jumbo Remote Control
Im trying t0 program a Phillips TV with a RCA niteglo universal remote.
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
Codes:
0154,1174,0062,0204,0004,0184,0208,0205,0206,0207,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0140
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | RCA Universal Remote 3 Device Remote...
Remote Control does not work
well probally not dust sounds like a bad reciver i just fixed one about a month ago
Apr 03, 2009 | Sylvania SRC22134 13 in. TV/VCR Combo
Comcst remote control code not working
look on the label on the back of your Emerson TV. Read the small print and see if there is a possible different manufacturer that actually made the Emerson TV. Just because it says emerson doesn't mean emerson made it. Also if no luck there try the UL listing code and search that code to the UL listing website. That may help also.
C-Dog
Feb 12, 2008 | Emerson EWF2703 27" TV
Emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 14, 2007 | One For All URC-3021 Remote Control
RCA RCR3273 3 DEVICE SNOWBOARD UNIVERSAL REMOTE
Answer for how to program the RCA RCR3273 3-DEVICE SNOWBOARD UNIVERSAL REMOTE:
Make sure the device is on. Hold down the tv (or whichever device you're trying to program) button and the power button simultaneously until the red light stays on solid. Then press the power button, it will flash one time, and keep pressing slowly, letting it flash until the device turns off. Then press the stop button...and it is programmed.
phoenixx100@hotmail.com
http://www.angelfire.com/journal/archer/index.html
Oct 12, 2007 | Televison & Video
Receiver not taking commands from the remote
Point the remote at a digital video camera to see if you can see the small blue infared light comming from the end of the remote when you aim it at the camera and press a button. if you do see the light then your receiver has a system control problem I'm afraid. You see your eyes cannot see the infared light but the camera optics can. Good Luck
Jun 07, 2007 | Onkyo TX-DS989 Receiver
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
