Question about Singer 2732 Mechanical Sewing Machine
How to wind the bobbin in a singer model 2732
    Genius:
  • 1,788 Answers
Go to singerco.com and download a manual for free. It will tell you how to wind the bobbin
Posted on Sep 13, 2010
  • Mary Dunn Sep 27, 2010
    Why are you unhappy with my answer? I just told you how to get free manual, which will tell you all about your machine.
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
SOURCE: I have a singer 2732
Hi, I hope this helps. It's kind of hard without pictures, but I'll do my best:
1)With the spool of thread affixed in it's normal spot, take the thread and wind it through that weird hooky thing (like normal) at the 'back' of the machine.
2)Then bring the thread towards the front of the machine and around the metal 'button' on the top of the machine. Do not loop around this, merely guide the thread on on the side closest to you, towards the right hand side of the machine.
3)Thread your bobbin.
4)Put the bobbin on the metal arm and push to the right (gently).
5)Push the 'button' in the hand wheel in so one end of it will pop out (this will stop the needle from going up & down while you're winding the bobbin)
6)Start pressing the foot pedal slowly and things should start to work.
Posted on Jan 11, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
SOURCE: I have a singer Model #6234. The bobbin is wound
I have a singer Model 6234. and i wont the book to see how the operad
Posted on Oct 26, 2010
carmin77
  • 113 Answers
SOURCE: how do you thread the
Sewing machines. All the manufactures copyright their manual. They know that you need a picture. It'll cost ya $12.
:o).
Posted on Jun 04, 2011
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
My singer 2732 sewing machine will not pick up bobbin thread
There are three causes. Make sure your needle is all the way up in the needle clamp, and the flat side it on the back (if your bobbin is in the front of the needle).
If it is, then your timing is out of synch, and you will need to get a technician to fix it.
Jul 26, 2014 | Singer 2732 Mechanical Sewing Machine
Singer 2732 manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 2732 ) & click search
if search comes up with nothing contact singer customer service
Mar 10, 2012 | Singer Sewing Machines
How do you thread the machine and bobbin on this singer model 2732
:o).
Jun 04, 2011 | Singer 2732 Mechanical Sewing Machine
If the bobbin case is defective this can cause the problem. However, this can be a difficult problem to repair, take it in and ask for an estimate to repair.
Feb 26, 2010 | Sewing Machines
Problems with Singer 2732
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jan 02, 2009 | Singer 2732 Mechanical Sewing Machine
I have a singer 2732 and have misplaced the manual. I'm trying to wind thread on a new bobbin but I must have forgot some part of the process. Can anyone offer instructions? Thanks!
Jul 29, 2008 | Singer 2732 Mechanical Sewing Machine
Singer model 2732
It is either inserted incorrectly or the bobbin case needs replacing. Check the bobbin case by running finger tip around the outside of case, if rough spot needs replace. There is a ltch that is spring loaded you must hold back with small bladed screwdriver while inserting case for proper placement
Oct 25, 2007 | Singer 2732 Mechanical Sewing Machine
Singer 2732 Mechanical Sewing Machine Logo
275 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
