Question about Dell Dimension 8200 PC Desktop
Motherboard blew up
My Dell stopped working todat. After an hour with Dell support, they said the motherboard blew. So, I'm looking for solutions. Is is possible to buy another computer, and just install my existing hard drive as the master and re-configure the new hard drive as slave?
    Scholar:
  • 143 Answers
Yes, it is possible to buy another Dell Dimension 8200 pc and hook up your drive as the master and the new one as the slave. You cannot just drop in another motherboard from a different manufacturer because Dell is famous for proprietary boards. And even if you did get one to fit, Windows may not load because of the different resources that the new board will have. Yes, its possible, but I am sure that the Dell case will not allow a third-party motherboard. Perhaps someone knows better and can illuminate us both!
Posted on May 15, 2008
  • 98 Answers
Unless you purchase a used PC will exact same chip set, you idea will not work as you think. The chipset is like the heart of the system. A new PC will have a newer chipset.
If you choose to go with an older motherboard, look for "Intel 850 or 850E" as the chipset. This is what a Dimension 8200 has.
If you choose a new PC, I would install the old harddrive as a 2ndary and copy any personal files over. Any programs will have to be reinstalled, as you cannot just copy them over and have them work.
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
Restarts unexpectedly
It can be one of three culprits with this unit -- first, try running it without the front panel plugged into the motherboard (the one with the front USB ports) and set the BIOS to auto power-on. If it keeps running after about 2-3 hours, then it's a bad cable. If not, swap out the PSU. A Thermaltake TR2 430W from Frys or MicroCenter works perfectly. If that doesn't stop it, take a good hard look at the capacitors near your memory on the motherboard. If they are even slightly 'popped,' then the board / memory controller may very well be bad. Swap the motherboard.
May 04, 2012 | Dell Dimension E510 PC Desktop
The motherboard 27HRF can work with my dell
You should replace this board it may an internal issue such as a shorted trace of surface mounted component. Not worth the effort to do board level troubleshooting and there are replacement board that will fit the Dell cabinet you have. Call Dell support to make sure that you can use a #rd party board substitution.
I hope this helps. Have a great holiday weekend.
May 29, 2010 | Dell (27HRF) Motherboard
My Dell E510 desktop won't start. No lights on the front
You have problem with motherboard if you’re PC in warranty then call them from u buy your PC.
And Thanks.
Apr 08, 2010 | Dell Dimension E510 PC Desktop
D610 Dell Laptop
it seems to be a problem with motherboard as you said you have replaced power supply and ac adaptor , try disconnecting external pheripherals do a flea power it doesnot start then you will have to replace motherboard
Jan 09, 2010 | Dell (F2273) Motherboard
Dell Dimension 9200 PC will not power on
Well, either way it sounds like something in your motherboard or your system got fried. Either a surge occurred frying some if not all components (yes, voltage can still flow through them even when they're dead allowing things such as the LED on the motherboard to glow) within the computer, or your PSU blew out taking some components with it.
Due to what you're describing, I'm more inclined to believe your PSU blew out due to some form of an overload taking your motherboard (if not more components) with it. An overdraw of power on the PSU or just a cheaply constructed PSU will easily blow taking some of the components with it (essentially killing the components).
Sorry if this is not the solution you were after. However, everything you described matches with either a power surge or a blown PSU. Always sad when perfectly good electronics get fried. Let me know if I can help you with anything else.
Mar 22, 2009 | Dell Dimension 9200 PC Desktop
Dell Optiplex GX280 won't start. Fan sounds like a Boeing 757
If the processor is ok, you can just change the motherboard. Then look for a compatible motherboard that can accept your processor.
Nov 28, 2008 | Dell Optiplex GX280 (99301) Motherboard
Dell Inspiron 1525 Laptop Motherboard Replacement
Dell Inspiron 1525 mother board may be replaced
New cost approxmatly 18000/0
refernished cost 8500/-ca5ef9a.jpg
Apr 19, 2008 | Intel Motherboard
Dell gx260
You have 500mA on usb port. If you cause a short on usb connectors, this can damage the motherboard.
Disconnect usb port on motherboard (work with power unplugged ), remove all ide and floppy cable,eventually remove and put back in place bios battery and Ram.
Restart Motherboard only with 1 module Ram (bios battery back in place), CPU and Fan (ensure cpu and fan are well in place), do not plug anything else than switch on button.
If it still does not work there is a good chance you blew the Motherboard.
Regards
Apr 18, 2008 | Dell OptiPlex GX260 PC Desktop
Pc keeps blowing ac adapters
hi!
the motherboard on your laptop is shorted to the ground. It happens when you unplug the ac adapter cord from the back of the computer a lot. Call Dell's reknowned tech support and ask for the motherboard to be replaced.
Karlox
Dec 12, 2007 | Dell Inspiron B130 Notebook
Dell Dimension 8200 PC Desktop Logo
136 people viewed this question
Alun Cox
