Question about Kenmore Elite HE3 Steam 8674 Dryer
How do i install a 4 wire plug - Kenmore Elite HE3 Steam 8674 Dryer
  • 670 Answers
Open up the back of the dryer where the cable attaches. Attach the cable thru the hole it is designed to fit thru.
The red and black wires in the cord go to the outside terminals on the block. The jumper from the center to the frame is removed. Connect the green wire to the screw where the jumper connected on the frame and the white to the center of the terminal strip. Replace the cover.
Posted on Sep 12, 2010
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Spark plugs
Check this SPARK PLUG REPLACEMENT - REMOVAL PROCEDURE
1. Remove the ignition coils (lines at end this document), then return here once you have gotten the Coil
Packs off and precede with step 2 from here.
2. Clean the spark plug recesses with low pressure air. CAUTION: Wear safety glasses
when using compressed air, as flying dirt particles may cause eye injury. NOTE:
Clean the spark plug recess area before removing the spark plug. Failure to do so could
result in engine damage because of dirt or foreign material entering the cylinder head, or
by the contamination of the cylinder head threads. The contaminated threads may prevent
the proper seating of the new plug. Use a thread chaser to clean the threads of any
contamination.
3. Remove the spark plugs from the cylinder head. NOTE: Allow the engine to cool before
removing the spark plugs. Attempting to remove the spark plugs from a hot engine may
cause the plug threads to seize, causing damage to cylinder head threads.
4. Inspect the spark plugs.
INSTALLATION PROCEDURE
1. Measure the spark plug gap on the spark plugs to be installed. Compare the measurement
to the gap specifications. NOTE:
• Use only the spark plugs specified for use in the vehicle. Do not install spark
plugs that are either hotter or colder than those specified for the vehicle. Installing
spark plugs of another type can severely damage the engine.
• Check the gap of all new and reconditioned spark plugs before installation. The
pre-set gaps may have changed during handling. Use a round feeler gage to ensure
an accurate check. Installing the spark plugs with the wrong gap can cause poor
engine performance and may even damage the engine.
2. Install the spark plugs to the cylinder head. NOTE:
• Be sure that the spark plug threads smoothly into the cylinder head and the spark
plug is fully seated. Use a thread chaser, if necessary, to clean threads in the
cylinder head. Cross-threading or failing to fully seat the spark plug can cause
overheating of the plug, exhaust blow-by, or thread damage.
• Refer to Component Fastener Tightening Notice in Service Precautions.
Tighten the spark plugs to 18 N.m (13 lb ft).
3. Install the ignition coils.
IGNITION COIL(S) REPLACEMENT
REMOVAL PROCEDURE
1. Remove the air cleaner resonator and outlet duct.
2. Disconnect the engine wiring harness electrical connector (1) from the oil pressure sensor (2).
3. Disconnect the engine wiring harness retainers (1) from the power steering pump (2).
4. Disconnect the engine wiring harness electrical connectors (1, 4) from the following:
• The exhaust camshaft position (CMP) sensor (5)
• The camshaft position (CMP) actuator solenoid valve (6)
5. Disconnect the engine wiring harness retainer (2) from the camshaft cover (3).
6. Disconnect the engine wiring harness electrical connectors from the following:
• The engine coolant temperature (ECT) sensor (1)
• The fuel injector harness (2)
• The ignition coils (4)
• The heated oxygen sensor (HO2S) (5)
7. Disconnect the engine wiring harness electrical connector from the intake camshaft position (CMP) sensor.
8. Carefully disengage the engine wiring harness conduit from the camshaft cover, and position aside.
9. Remove the ignition coil bolts.
10. Remove the ignition coils from the camshaft cover.
1. Install the ignition coils into the camshaft cover. IMPORTANT: Ensure the ignition coil seals are properly seated to the camshaft cover.
2. Install the ignition coil bolts. NOTE: Refer to Fastener Notice in Service Precautions. Tighten the ignition coil bolts to 10 N.m (89 lb in).
3. Attach the engine wiring harness conduit to the camshaft cover.
4. Connect the engine wiring harness electrical connector to the intake CMP sensor.
5. Connect the engine wiring harness electrical connectors to the following:
• The ECT sensor (1)
• The HO2S (5)
6. Connect the engine wiring harness electrical connectors (1, 4) to the following:
• The exhaust CMP sensor (5)
• The CMP actuator solenoid valve (6)
7. Connect the engine wiring harness retainer (2) to the camshaft cover (3).
8. Connect the engine wiring harness retainers (1) to the power steering pump (2).
9. Connect the engine wiring harness electrical connector (1) to the oil pressure sensor (2).
10. Install the air cleaner resonator and outlet duct.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 23, 2012 | Cars & Trucks
How to change spark plugs in a 2005 chev colorado
contamination.
REMOVAL PROCEDURE
• The HO2S (5)
Replacing spark plugs
Not exactly sure what you need?
Standard Rules:
Use a Spark Plug Socket to remove and install Spark Plugs.
Replace (remove) one Wire at a time from one Spark Plug.
Replace One Spark Plug at a time. Use Anti-Seize Grease applied moderately to the threads on the new Spark Plug.
Using a Socket (with a extension) START all installations using your hands. This prevents cross-threading and stripping of the threads inside the Heads.
Standard Torque 15-20 ft-lbs.
Replace the One Wire connection to that One Spark Plug.
Replace that One Wire connection to the Ignition Coil.
Go onto the next Spark Plug using the above Rules.
Repeat.
For the 3.4L V6:
Firing Order:
1-2-3-4-5-6
Cylinders:
......(back)
1.......3.......5
2.......4.......6
......(front)
Ignition Coil Connections:
............(back)
.|.5..2.|..|.3..6.|..|.4..1.|
............(front)
Mar 21, 2010 | 1997 Chevrolet Venture
I have a 2009 Ford Escape. I can install a 4 wire plug but what/where do I plug the 2 way into? That is the plug that is red/black. Do in need to cut this off and wire it to the battery? Do I need to...
Did you install the wire harness for the lift? It goes from your battery to the lift With out that harness you cant plug in the lifts 2way the 4 wire is for the lifts lic. plate light,is your escape a new car and lift was used on your old car if so you need to get a new lift harness
Feb 23, 2010 | Harmar AL100 Universal Scooter Lift
Changed plugs and wires now it has no power and
You didn't post your engine size so please pick the applicable motor:
Firing order and spark plug wire installation for the 2.5L engine
Firing order and spark plug wire installation for the 2.0L engine
Jan 10, 2010 | 1999 Mercury Mystique
I need to change the 3 wire plug on my whirlpool model LE5790XS dryer to a 4 wire plug...old one is not color coded and I dont want to hook it up wrong...whats the correct way to connect this plug?
To install your 4 wire plug ,the white wire goes to the center wiring terminal on the dryer. The green ground wire attaches to the terminal cover screw outside the dryer. The red and black wires go right and left on the dryer terminal.
Nov 12, 2009 | Dryers
Need diagram of firing oreder for a 2000 olds silhouette
I can't upload the diagram but the firing order appears to be 1,4,6,3,2,5
Install the spark plug wire(s) (1, 3 and 5) to the engine right side spark plug(s).
Install the spark plug wire(s) to the retaining clips.
Install the spark plug wire(s) (2, 4 and 6) to the engine left side spark plug(s).
You can get a copy of the service manual from Promanuals.net for cheap.
Sep 26, 2009 | 2000 Oldsmobile Silhouette
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
Sep 23, 2009 | 2003 Chevrolet Malibu
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
43 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
