Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon MP6oo paper tray empty
My mp600 keeps telling me there is no paper in the tray.
I have put paper in and taken it out, several times.
there is paper in the tray.
the paper is good,
the paper is in square and all the tabs are lined up properly in the tray,
the tray is pushed into the printer and is locked in place,
and still my display says no paper in the tray when I try to print.
Is there a sensor or a faulty switch some where in this unit that is a typical problem with this unit?
I have used it very little. Maybe 2 trays of paper in all.
the printer is only 6 wks old.
I can take it back but if there is some quick solution for this problem I would like to know.
Can u help?
skiier@live.ca
  • Maddi Marie Jun 05, 2008
    Yesterday my Canon MP600 printer stopped working everytime I try to print it comes with error: cassete, there is no paper, load paper and press ok. I have done this many times and I need the printer because I am a year 9 student and if I dont get my assignments done, I won't get my school certificate. I have already done that thing where you go into the printer settings to change it so i can print larger paper sizes and it did not work. I need an easy,low cost or free way to fix it myself.
    Genius:
  • 1,224 Answers
Issue: "The selected paper size is not supported by your printer..." appears after selecting the Paper Size in the printer driver.
Solution: Use Fit-to-Page Printing (Windows)
Use Fit-to-Page Printing (Windows) The Fit-to-Page function automatically resizes the image to fit the size of the page being used. Letter size image data, for example, will automatically be printed on 4" x 6" size paper. Paper sizes larger than the printer can handle will be available on the Page Setup of the printer driver but will not print unless the Fit-to-Page function is enabled. Note: The Fit-to-Page Printing function is not available when Borderless Printing is selected.
  1. Access the printing preferences by opening the printer Properties / Preferences:
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click the Page Setup tab.
  3. Specify the 'Fit-to-Page Printing' settings.
    (1) Select Fit-to-Page Printing.
    (2) Select the size of original document created in application program. Paper sizes larger than the printer can handle will be available.
    (3) Select the actual size of print media.
  4. Click 'OK'.
Posted on May 21, 2008
Does not sense lower feeding tray as full
One suggestion is to check if there is paper behind the tray which is stopping the paper lift mechanism from functioning properly. The paper senso rcould be dirty or broken and will need to be serviced. Or, the papersize dial could be set to the wrong paper size.
Nov 10, 2011 | Canon imageRUNNER 2200
Canon MP600 paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Paper won't feed. Message says paper tray empty but it isn't
Hi
Please press the button above HOME and it should change the tray in which you are printing from .
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Office Equipment & Supplies
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
that is correct..this puppy still under warranty?
Aug 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Envelope printing
there is a slider for paper on the paper tray the envelope runs long ways usually on the right hand side of the paper tray
if the slider isnt there it probably broke off this helps keeps alignment of envelope and different size papers in line
May 21, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Pink tinge to colored photos
Canon has a number of things you can check in their knowledgebase. Go here. Type "pink tint" in the search box and click Search. If you select the first item "tinted printing" you will get at least 21 things you can try (only 10 show up per screen).
Apr 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
I recently had the same problem and was very bummed, because I like the printer, having received it as part of an Apple bundle promotion.
The problem I was having is that I had paper in the rear (auto sheet feeder) area and when I'd try to print, all I heard was clicking and then I'd get a message that there was no paper installed.
Here's what to do.
On the panel, on the left side, there's a button called "Feed Switch."
You'll notice that there's a graphic of the printer to the left of the button with 2 lights. Push the Feed Switch button to toggle the light from the front tray (cassette) to the rear tray (auto sheet feeder)... and when the light is on the rear try (vs. the front tray) you're all set.
This will fix the problem.
Jan 25, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Toner replacement
When this happens it is usually because the paper has misfeed remove paper from cassette tray replace it then reseat toner.
Jan 03, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
335 people viewed this question
old marine
old marine
