Question about NEC Lands Phones
I have a NEC XEN Phone that has a slow flashing green light on the visual ring indicator constantly. The manual states that is a "Message from Attendant" however I can't find any instructions on how to answer it or turn it off.
    Genius:
  • 3,422 Answers
Well this is what i can help you with:
Set Relocation
Ask the Attendant to turn on the Set Relocation Mode.
From the new location, press Speaker, then the LED lights.
Dial Set Relocation code________
Dial your station number.
Dial the Station Password (same as the Station Outgoing Lockout
[Password] code).
Hear the confirmation tone and then press Speaker.
Inform the Attendant to turn Set Relocation Mode off.
Goodluck,
Please don't forget to rate or accept the solution
Posted on May 15, 2008
    Genius:
  • 1,142 Answers
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
  • Maanita Chadha
    Maanita Chadha May 15, 2008
    Here is the instructions manual you can download it
    Nec
    I would like you to unplug the device from the power outlet if battery found then take it out and leave it turned off for 2 hrs then restart it then it should work fine
  • Maanita Chadha
    Give the exact model # of the product in details so that it can help me resolve the issue for you in a more prompt manner
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
How do I clear a flashing green light on my nec d term 80 phone?
It's most likely a line appearence of another phone. When that other phone is ringing it will flash on your phone. If the person is talking on the phone it will go to a solid state.
Mar 24, 2010 | NEC Dterm DTP 16D-1 Corded Phone
My message light is still on after erasing the voicemail message. What can I do to turn the light off?
is the nec dsx telephone voicemail light red or green...?
if it's green, it's not the voicemail light, rather, it's the caller id missed call indicator. just look through your missed calls and it will go out... or if you have the admin software, go to class of service, station, and disable the caller-id alert lamp.
free download of admin software at our website http://www.nec-dsx.com
Aug 03, 2009 | NEC DSX Systems NEC-780025 DTR-1HM-1 BLACK...
How do you turn the ringers off on the phone?
Do Not Disturb (Feature 01) will turn the ringing off of a phone, but it will also send any lines assigned to ring on that phone to voicemail (if applicable).
OR, to turn ringing off in system programming:
From ext. 10 or 11, press Feature button, 00, left intercom button twice, right intercom button once. Enter extension number of phone you wish to remove the ringing line from. Light indicators next to line keys show ringing status. Press line keys to desired ringing preference for each line-
steady green light- immediate ring
green fast flutter- no ring
green slow flash- delayed ring
Press "feature" 00 to exit
Mar 06, 2009 | AT&T Lucent MLS-12D Phone
Change ringer tone
Message/Ringer Lamp: The Message/
Ringer lamp informs you visually that you
have a message or a call.
When you receive a call, the lamp
flashes depending on the ringing pattern.
When the ringing pattern is set to Single
(Slow flash), Double (Moderate flash), or
Triple (Rapid flash) in your PBX, the lamp
flashes. When the other ringing patterns
are set in your PBX, the lamp may not
flash. (e.g., S-Double, Call Waiting
Tone1).
When someone has left you a message,
the lamp is lit continuously.
Please note that the above indicates that ring patterns are set in the the PBX. These are issues that require a real person to sit at the main system and program the features that users need. I hope you have an I.T. person that knows your phone system. If you don't, you'll have to find a communications company in your area that can program your system. Thanks for using Fixya.
Jan 19, 2009 | Panasonic KX-T7730 Corded Phone
I need to silence an extension on the lucent 18d telephone
From ext. 10 or 11, press Feature 00, left intercom (twice), right intercom (once), Dial ext. number of boss' phone. Lights on the line button will indicate ringing state for that line:
Green light - Immediate ring
Fast Flutter Green light - No ring
Slow Flashing Green light - Delayed ring
Press each line key until Fast Flutter Green light appears.
Press Feature 00 to exit programming.
Jan 05, 2009 | Lucent PARTNER18 Corded Phone
8310 blackberry curve
To answer your first question, the green flashing light is the coverage indicator. It will flash green when you have a wireless signal. If you want to disable that then go to Options > Screen/Keyboard and then set the LED Coverage Indicator option to Off.
Sep 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Nec dterm80 light flashing green
For the green light, you can turn it off from DSS. On the bottom left hand side of DSS, it is a message button. You can press the button and then your extension button. The green light will go away from the DSS and on your phone. I hope this helps.
Mar 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
NEC DTH16D-1 flashing light
I do not deal with your system but I see similar problems in other phone systems. This MAY be what is happening...
The message light can be a voice mail indicator OR someone on another phone in the building can leave you an intercom message (no voice system used or required). In those cases you need to return the message by pressing the MSG button, this should make the phone ring that left you the message in the first place. That phone needs to be answered to return the message and cause your light to stop flashing.
Oct 15, 2007 | NEC Electra Elite 32D-1 Corded Phone
NEC DTU-8-1 telephone system
Press Feature, 69, then feature again. The light will go off.
Aug 10, 2007 | NEC DTU 8-1 Corded Phone
Lands Phones Logo
287 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
