Question about BenQ FP731 - 17" LCD Monitor
My benq monitor worked for a couple of years then one day it just stopped. FP731 17". I get the green power light but nothing on the screen. Hooked up a different monitor to the computer and it works fine. Tried the Benq on another computer, but same problem.
  • 11,361 Answers
It is almost the same as DELL monitor (BenQ makes monitors for Dell and HP), so look for shorted transistors, cold solder joint, fuse.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 13, 2010
I received a benq t905 from my parents the other day and i just hooked it up to my computer and it won't work. everytime i press the on button it blinks green and makes a quiet beeping noise and then...
On rereading that post, I note that it shut itself off; perhaps it is time to open it up and fix it (if you're up on your electronics safety) per the _stinks_ note, below; you get to resolder some stuff running the backlight and replace a couple of standard capacitors and transistors, from what I can tell.
Things sound sort of normal for a driver being finicky about DVI modes; did the monitor driver not install, or just not bring visible results? You set your OS to 1280x1024 having booted to VESA (safe mode,) right? Normally when the resolution/sync is out of range, the status light is green constantly and you get a little note; maybe it's just too far out of the 56-76Hz video rate for that.
It's also possible that your backlight is failing (they fail short, as in too few ohms) or the monitor settings are set incompatibly...DMI or VGA cable? Does it stink?
Jul 25, 2011 | BenQ T905 (Black, Silver) 19 inch LCD...
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
May 30, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Benq 937s monitor stopped working. Green light on but blank scree
this is caused by the transistors that drive the backlight transformers, they are not expensive check out ebay for the parts & tutorial on how to fix it yourself
Mar 17, 2009 | BenQ FP937s+ (Silver) 19" LCD Monitor
BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Jul 07, 2008 | BenQ FP767 17" LCD Monitor
Can repairs be made to BenQ FP731 17 inch Flat Screen.
The power and Inverter board has a problem.Check Inverter transistors and the related fuse.
Jan 30, 2008 | BenQ FP731 17" LCD Monitor
Benq FP71G+S NOt starting.
Hello
I have had this problem twice once at my school and once with my BenQ FP71G Monitor. At my school the monitor ( HP ) just stopped working and smelt like burnt popcorn.(though is think this is due to some kids chucking a soccer(football) ball at it! With my BenQ it has the same problem though i nownthink it is because of the monitor has been on for excessive hours ( 3-4 ) and just shut down because of overheating. I will see in a couple of hours if it works !
Copper_R
Dec 30, 2007 | BenQ FP71G 17" LCD Monitor
My ben t705 moniteur.... problem
I DID REPAIR A MONITOR WITH THE SAME PROBLEM. IT TURNED OUT, THAT ONE OF THE TWO HIGH TENSION GENERATORS FOR THE 2 LIGHTTUBES WAS BURNED OUT. BY REPLACING THE POWER TRANSISTORS AND THE 3 AMP. FUSE ON THE MAINBOARD THE MONITOR IS RUNNING AGAIN VERY WELL.
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Blank scren, led stays green for only one second
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
May 24, 2007 | BenQ FP737S-D 17" LCD Monitor
Benq monitor powers off immediately
Try sending monitor back as most Benq monitors come with at least a two years silver warranty. Benq are very helpful and their repairers are quick and polite. You will find their no.s on their website www.benq.com my monitor was experiencing the same and for $10 postage and a one week wait is repaired and working fine.
Apr 07, 2007 | BenQ FP71G 17" LCD Monitor
BenQ FP731 - 17" LCD Monitor Logo
154 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
