Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
My 37" Panasonic Viera LCD TV won't recognize my Xbox 360 when it's connected via component wires. I've made sure that all of the wires are connected correctly, but the television doesn't receive a signal. The component connection with my Xbox has worked on other televisions in the past. My Xbox doesn't have an HDMI port (it's both old and referbished), so that's out of the question. How do I get my TV to recognize the component signal?
  • 3 Answers
SOURCE: 37"LCD television FLM-373B we have had our tv alittle over a year and now
It seems that the manufacturer of the Polaroid FLM-373b HDTV either used the wrong parts or there is a design problem. I found someone on the internet who said they replaced two capacitors on the power board and it started working just fine. I took the power board out of mine and sure enough the two caps with the 10v markings were swelled. I replaced them with two 25v caps and it is working just fine. All the other caps on the power board were 16v and above. So, I would assume they were shipped the wrong parts or they just put the wrong caps in to begin with. If you want to send me your power board I will fix it for $50.00 plus shipping.
send inquires to:
mott414@@yahoo.com (remove second @)
Posted on Jul 08, 2008
nick_helpap
  • 334 Answers
SOURCE: can't get xbox 360 to work on tv
u must use 480 p out put on xbox 360 wqith xcounpunt vcable only 720 p with hdmi on this ok boss thx nick so get xbox on reg tv so u can see pic with yellow cable came with then turn back to 480 p mode ok thx nick
Posted on Oct 12, 2008
SOURCE: installing wii to panasonic viera 50'' plasma
I could resolve the issue. First of all, the wire supplied with the wii is not compatible with your TV. This 3 point connector, will end up giving you b/w screen. So you need to buy the 5 pin connector. I bought from Frys for $19.99. The box says "High Performance Component HD A / V Cable" (like this one: http://www.bizrate.com/wii-accessories/oid875654433.html )
In any case, do below
1> find the 5 point input row (vertical) on the back of your TV.
2> Insert the connector, in the sequence of Red pin being the bottom most. If its 5 pin connector, then start from the lowest point on the back of TV. If its 3 pin connector, use the top 3 points, on back of your TV. Red always being the bottom most in sequence.
Once again, buy the 5 pin connector, as inserting these pins on the back of your TV when the TV is already mounted on wall, is the hardest part to do...so why to waste your enerty in doing again and again. I am sure you would not like the black & white screen coming with 3 pin connector.
Posted on Dec 27, 2008
  • 4 Answers
SOURCE: panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Posted on Dec 30, 2008
SOURCE: Panasonic Viera TH-37PX70 Pedestal Stand
i need the instrucation how to install the pedestal stand
Posted on Mar 10, 2009
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
CONNECTING XBOX 360 TO A LCD PANASONIC VIERA TV
You need to Connect via, the Component Video, the xables are Blue, Red, Green, ALL Video, and go color to color, from, Xbox to TV, and you Select EXTERNAL INPUT, on TV. OR You must use the Composite, Video, which is Yellow, for Video, again, cables go color to color. The Audio, as you have discovered, is Red & White. Now, if using HDMI, you do not usually need the Red 7 White audio, as it's all in the one signal, though the HDMI. Again, you select the relevant, INPUT On the TV, And also select the output on the Xbox, and you should be all OK.
Apr 30, 2010 | Microsoft Xbox 360 Console
Can't connect XBOX 360 please help!
How many video ports does it have? You may have to search through video 1, 2, 3, or switch the TV itself to component/HDMI depending, with the remote. Should be with an 'input' button.
My tv has a list with HDMI, SVIDEO, COMPONENT, PC, ect. and its a 1080p one, im just assuming all HDTV's have a list
Feb 05, 2009 | JVC LT-47X788 47 in. LCD HDTV
Staggard movement
you need to check the wire its self and make sure the connection is done correctly a simple misconducted wire can cause stupidity.
Jan 12, 2009 | LG 37LG30 37 in. LCD HDTV
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
SET UP VIERA LINK PANASONIC PT960
Can you explain a bit more please. What exactly is the problem? Are you getting any picture or audio through to the TV? Are you getting any picture or audio through to the home theatre? Have you got the home theatre setup via HDMI? Have you connected the audio from the cable to the home theatre via optical or phono? What model is your LG LCD HDTV?
I already have the manual in front of me for your home theatre system. If you can give me some more information I can help you out.
Thanks.
Nov 30, 2008 | Panasonic Home Theater System System
Can't get xbox 360 to work on tv
What here happened is that the GPU (graphics proccessing unit) has overheated and melted the VGA card (Video game array) card.
And this takes away the video/picture.
But you can still hear sound because the SPU is much much smaller and has a tiny chance of overheating.
So now the vga can't connect with the the CPU (motherboard) and the AV section.
You have to get it fixed, because this has caused or will cause the Ring of Death.
Call up Xbox at
australia: 1800-555-741
usa: 1800-469-9269
It'll get fixed for free because the xbox has a hardware failure.
Oct 12, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
XBox 360 and Other Game Connections
How are you connecting the XBOX 360?
Component? HDMI?
Make sure all connections are plugged in snug.
If you use HDMI then audio should work without seperate cable.
For component make sure red and white cables are also plugged into right spot on back of TV.
Hope this helps!
Thanks.
Mar 24, 2008 | Sony KDE-37XS955 37 in. Plasma HDTV
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
618 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
