Question about Gilmour Telescoping Purpose 9Inch Hedge Shears 3549 ()
These shears were taken apart and put back together. The two blades do not close completely. The rubber stoppers do not meet at the flat portion . They block the blades from closing completely.
How do I free up the volume control that is sticking?
Take controller apart by undoing screw inside battery compartment and then prise apart starting at battery end using a flat head screwdriver. It is not glued together so with a little effort it will come apart. clean all components especially behind the rubber buttons and on top of the circuit board, then put back together. I had to cut the rubber buttons into sections removing a small slither because the rubber seemed tho have stretched and would not sit flat. Now controller works like new.
Apr 28, 2014 | Denon Televison & Video
Tip
B&D GS500 Parts Manual Download
Download Black and Decker GS500 Cordless Grass Shear Parts Manual
Have you misplaced your Black and Decker GS500 Cordless Grass Shear Parts Manual?
Have you taken your Black and Decker GS500 Cordless Grass Shear apart, and can't get it back together?
Would you like a digital, searchable, pdf version of the Black and Decker GS500 Cordless Grass Shear Parts Guide?
Follow this link (& click FREE) to download a pdf version of the Black and Decker GS500 Cordless Grass Shear Parts documentation.
I hope that helps.
__________________________________
B&D GS500 Manual Download
on May 08, 2010 | Garden
I can not open my "key fob" to replace the battery, does anyone know how to open it?
hey,, There are hidden clips inside you just need to pry it apart... some of them the back cover slides off, but most just pry apart. Look at the back and make sure there are no screws and no hidden screws (like those under rubber stoppers, the stoppers must be removed to expose them).. any way once thats verified, simply insert a flat head (blade) screw driver in between the seems and pry it apart.
Dec 28, 2012 | Cars & Trucks
737 mower enfine is turning over fine but not firing it is getting plenty of fuel
Did you hit something with your mower? Check to see if your blade is loose. If so tighten your blade, if not then your problem is a timing problem. Remove top cover to your engine and any attachments. You will see the flywheel. Between the flywheel and the crankshaft top is where the shear key is located. Remove the flywheel and inspect the shear key. If it's dented or completely broken replace. Put all back together and your mowing again. GOOD LUCK.
Jun 27, 2011 | John Deere Garden
Have a protron pltc-26 and the remote qiut working put in fresh batteries but will not turn on tv
The remote control is dead or the remote CPU chip that control all functions is dying and only some of functions buttons will work,some wouldn't anymore or the rubber insulater between the rubber buttons and the remote circuitry board are worn out and make no more contact.Can u take the remote aparts?Yes.Check all the rubber butttons insulater see if they're still good.Tries clean the remote PC circutries board with some rubbing alchahol also the battery - + connections too.Wait like about 20 mins for the rubbing alchahol to completely dries.Putting it back together again an putting in new batteries,the remote control might work again.If not have same result.Try website like Remotes.com to buy an original or very close compatible remote for a replacement.
Mar 23, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Missing rear axle. is there a way to replace? the company won't.
I had the same problem. I bought this scooter for my daughter at a flea market and the rear axle was gone, someone had tried to fix it with a bolt, but it was very unstable. Here is what I did and it has seemed to work well. This will cost you less that 10.00 at your nearest home improvement store.
You will need
1x - 5/16 x 8 hex bolt 1x - 5/16 nut 4x - 5/16 x 1 1/4 flat washers 2x - 1 1/4 hard rubber stoppers 1x - 3/8 drill bit & drill 1x - gorilla glue or lock tight
Ok... before we start let me tell you what all this is for and how it works. The way I assembled this was, hex bolt, 1 washer, wheel for scooter, 1 washer, 1 rubber stopper (Insert this into the metal tube on the back of the scooter, so that on the other side you will just have a bolt sticking thru) now, 1x rubber stopper, 1x washer, other scooter wheel, 1x washer, hex nut.
The rubber stoppers are the hardest part and the reason for them is to keep the bolt going thru the middle of the axle tube. This will help to eliminate the scooter from wobbling.
Now, if you have read this far here is how we did it in order.
1. Take both rubber stoppers and trim them with a kitchen knife so that they will fit into the metal tube on the back of the scooter securely. (do not push them all the way in yet)
2. Drill a hole thru the middle of both trimmed rubber stoppers with the drill and bit
3. Take your hex bolt and slide a washer on
4. Slide your 1st wheel on
5. Slide on a 2nd washer
6. push on the trimmed rubber stopper to where it meets the washer. (The wheel should be able to still spin pretty freely, If you think it is to tight just pull the rubber stopper up a bit)
7. Take this assembly and push it into one side of the metal tube on the back of the scooter (you want the rubber stopper to be and flush with the edge of the metal tube and you can)
8. Your hex bolt will be stick out of the other end of the tube, slide on the last rubber stopper try and work it into the tube as best you can.
9. slide on 3rd washer
10. Slide on last wheel
*At this point I put the scooter on its side and pushed down on the wheel to force the stopper into the tube
11. slide on 4th washer
12. screw on nut
*Now I found that if you put the nut on to tight the wheels would not turn, but if you left it loose it would fall off.
13. To fix the above issue we put some gorilla glue on the bolt threads and screwed the nut on, we would spin the back wheels until we were happy with the amount of tension on the wheel. We then put some more glue on the top of the nut to help hold it in place.
14. Let the glue dry
Thats how I fixed my daughters scooter. I am in NO WAY a professional or expert at this stuff. Just a dad trying to make his baby happy. Hope this works for you!
Jan 26, 2011 | Bravo Dora the Explorer 3 Wheel Scooter
I was cleaning the water tank and i accidently knocked out the spring, tiny black plastic stopper and the white rubber washer, please could you help me put it all back together again, hopefully this can be...
Hi!
I've got the same problem and I managed to solve it.
So you have to put the plastic stopper to the buttom of the water tank in way that the wider end is down. You must hang the spring on the plastic stoppers narrow end so it would be placed between the water tanks bottom and the plastic stopper. Then you have to place the rubber washer from inside the water tank on the plastic stoppers narrow end. So would look like the following: plastic stopper -> spring -> water tank -> rubber washer
Jul 08, 2010 | Gaggia Caffitaly K111 Coffee Maker
All of a sudden the main screen to my phone freezes and I cant go to any other main menu. Turning it off then on doesn't work. I didn't drop it nor was it exposed to extreme weather. I cant buy another...
The problem is from the flex of the phone.
The flex is the cable that connects the screen to the panel of the phone.
To fix this;
  1. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers.
  2. Remove the screws,
  3. Next remove the rubber stoppers & screws above the main screen,
  4. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  5. Unclip the ribbon, and replace it with a new ribbon,
  6. Then reverse the process to reassemble the phone back together.
Take care
Jun 22, 2010 | Motorola Mobility i776 Cell Phone
Dishwasher makes a loud grinding noise when running.
Start by pulling out the lower rack. Then pull the nut off the top of the lower spray arm. then remove all of the visible hex head screws. lift up on this section. this should expose another level of hex head screws, then they should be removed and this section should be lifted up. once you reach the chopper blade, remove the obstruction, and put back together.
Mar 13, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Gilmour Telescoping Purpose 9Inch Hedge Shears 3549 () Logo
76 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
