Question about Amana NDE2335AY Electric Dryer
Replaced the heating element. Had to wait 8 days and all the wires were off of the heating element. I need to find out where the wires need to go.
  • Jeff Rosten
    Jeff Rosten Sep 16, 2010
    I have an Amana Dryer ALE866SAW model. I took out the heating coil to test it. That was ok but the Thermal Fuse was bad. Every thing was unhooked for 4 days befor I could get a new part and put it in. I put it all back together and pluged it in. The motor now sounds like it is working harder and after about 15min the dryer shuts down. I think that I have one or more wires that are in the wrong spot. Can you help me with this? I need a good pitcher so that I can see where the wires go.
  • Jeff Rosten
    Need to know what wires and where the wires go on the heater box. It has two connections for the heating element, two for the thermal fuse and three for what I think is the Thermostat cycling. Can you help me? I have an Amana Electric Dryer Model number is ALE866SAW.
  • Amana Master
  • 3,740 Answers
There should be a tech sheet / wiring diagram inside the upper console. However, The is a manual that you can refer to is here:
http://www.servicematters.com/maytag_library/docs/16026315.pdf
It is one of the worst service manuals ever published. It even states to check the unit Tech sheet in the console for wiring diagrams.
Heating elements either have 2 or 3 wires on them. Single one piece elements only have 2 wires. It does not matter which terminal you connect them to unless the terminals are different sizes so that you can not hook it up incorrectly. The 3 wire elements have one wire that goes to the lower temp cycle thermostat and operate a smaller / shorter element of the double element type heaters. Single element heater wires will have 220V - 230V across them with the motor running.
Kelly
Posted on Sep 17, 2010
  • Amana Master
  • 3,361 Answers
Copy and paste this Factory Service manual link for your dryer.
http://servicematters.com/maytag_library/docs/16023020.pdf
The wiring diagram is included in the manual.
Posted on Sep 16, 2010
    President:
  • 3,773 Answers
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
Tip
Diagnosis Electric Hot Water Tank Problems and Repair It
I understand that you electric hot water tank is not producing hot water. To diagnosis the problem we will need a few tools. Here is a list of the tools you will need.
Multi-meter
Screw driver (Flat and Philips)
¼ inch nut driver or ratchet and socket
5/16 inch nut driver or ratchet and socket
Diagnosis Electric Hot water tank problems:
1. First you will need to remove the service panels on the side of the hot water tank to expose the thermostat and heating elements. Careful as power is still on to the unit. Now that you have removed the service panels we need to proceed to the next step.
2. On the thermostat there are two wires coming into the top two screws these are line one and line two they are the main power feed. Take your probes from the multi-meter and touch to each screw and you should receive a reading of 220 volts. If you receive this reading then move to the next step. If you do not get a 220 reading then your breaker is tripped or bad.
3. Got the proper power then you will want to check the thermostat reset button. In the middle of the thermostat is a red button press it in and see if it clicks. If the button clicks it means that the thermostat has tripped do to over heating. Wait an hour and see how your hot water is doing. If still the same replace the thermostat.
4. Use your multi meter to check for power to the heating elements. The heating elements have two screws with wires on them. You will want to take one probe to each screw and see what the VAC reading is (if power is present you should receive 220 volts) if you do not get the correct reading then the thermostat needs replaced. You will need to do the same thing to the lower element.
5. To check the heating elements turn off the power to the unit at the breaker. Check to make sure the power is off by using your meter at the thermostat. Remove the wires off of the element and check it for continuity if not continuity then the element is bad and needs replaced.
Replacing the Thermostat
1. Turn off the power.
2. Label and remove all wires from the thermostat
3. Pull clips forward on sides and pull thermostat upward to remove
4. Install new thermostat in reverse
Replacing the Element(s)
1. Turn off power to the unit
2. Turn off water to hot water tank and drain
3. Remove element from tank
4. Slide new element in tank
5. Turn water supply on and check for leaks
6. Reconnect wires
7. Turn on hot water faucet some where in the house to allow air to escape from tank.
8. Turn power on once hot water tank is full.
Thank you for choosing FixYa.Com
Justin
on May 08, 2011 | Plumbing
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
My Frigidaire model FDB1050 will not heat the water. The heating element checked out at bout 14 ohms but the approximately 8" wire from the heating element to what I think is a thermostat is slightl
Hello preslncon - The black button that you are referring to is more than likely the Hi-Limit Thermostat. The Hi-Limit Thermostat will open and stop power from reaching the heating element. The Hi-Limit is not resettable, and if it is open, it would need replacing. As far as the burnt wire on the Thermostat, more than likely a loose connection to the Thermostat could have possibly caused the wire to overheat. This is not a typical do it yourself job. Personally, I would recommend reaching out to a qualified appliance repair person to proceed further. I hope this information helps to some degree.
Apr 14, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Does not heat up
what type of dryer rate these
Open The Cabinet
  • Unplug the dryer's power cord from the electrical outlet. Remove the toe panel by inserting a putty knife between the toe panel and the front panel. There are retaining clips 4 in. from each corner. Slide the putty knife blade over each retaining clip and pull the toe panel away from the dryer.
Test the Heating Element
  • If you own an electric Whirlpool dryer, locate the heating element. The heating element is the workhorse of the heating operation. The heating element is most often inside a can. The thermostat mounts to the side of the heating element can in most Whirlpool dryers. The thermostat looks like a small oval part with two wires connecting to each side.
    Pull the two wires that connect to the heating element terminals. Set a volt-ohm meter to the RX1 scale to check the continuity of the heating element. Clip each probe from the volt-ohm to each of the heating element terminals. A good element will give you a reading between 8 ohms and 12 ohms. If you get no ohm reading, the heating element is faulty and you will need to replace this part.
Jan 15, 2013 | Dryers
Tip
How to Change the Heating Element in a Electric Dryer?
1) When the clothes are not getting dried but dryeris running. That means the heating element needs to be replaced.
2) First of all unplug the dryer from wall outlet.
3) The heating element is located in the cabinet. Insome models the cabinet is located in rear or in some models its located infront.
4) Remove the screws on the heating element cabinetto reach the heating element.
5) You will see wires connected to the heatingelement terminals.
6) Remove the wires from element using needle noseplier.
7) Then remove the object blocking the heatingelement with the screw driver. But in some models the heating element can be removeddirectly.
8) After removing the object remove the screwsholding the heating element.
9) Theheating will have to be moved a bit to come out easily. Before removing theheating element out. Please note down the position of old heating element. Sowhile placing the new heating element you don’t face any problem.
10) Refit all the parts removed while removing theold heating element properly.
This will help. Thanks.
After clening the kettle it blows breakers
You got the Heat element and or thermostat wet. Open the kettle to expose the electronics and let it dry for days. try again it might dry out.
Or you will need to replace the heat element, thermostat, and probably the wires. if it hasn't dried out by now.
Dec 26, 2012 | Paragon 1911-8 Popcorn Maker
Maytag Dryer MDE3706AYW has a burnt black wire, did the wire just have a bad day or do I need to replace the heating element and the wire?
All should be good. I think the element had run on due to a bad hi-limit thermostat that you said you replaced.
Oct 17, 2012 | Maytag MDE3706 Electric Dryer
Need instructions for replacing the heating element
First UNPLUG UNIT remove the 7 or 8 screws securing the back to the dryer,the heating element is on the lower right ride where the wires are going. 2 screws hold the element in position. You will need to transfer the high limit thermostat to the new element, reinstall and reconnect all wiring, reinstall back ...Now enjoy the fact that you fixed it yourself and saved some cash as well... Good luck
Aug 15, 2010 | Whirlpool WED5300S Electric Dryer
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Amana NDE2335AY Electric Dryer Logo
132 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
