Question about Toshiba Computers & Internet
Getting flashed screen with no windows starting what is the cause?
    Guru:
  • 277 Answers
May be windows got currupted. get it reinstalled
Posted on Sep 12, 2010
My Samsung Syncmaster 2033SN LCD Display flashes after every 5 seconds
Get in touch with Samsung support: http://www.samsung.com/us/support/contact
May 19, 2015 | Samsung Computers & Internet
Black screen Laptop. Flickers once on start. External Monitor works
Look for your computer's monitor settings, then adjust its refresh rate.
To modify a refresh rate on Windows, right-click anywhere on the Windows desktop.
Select "Properties," then choose the "Display Properties" tab on the window that appears.
Click the "Settings" option, then select "Advanced" from the window that appears.
Choose the "Monitor" tab, which lets you access a drop-down menu with the options for refresh settings adjustments. As a basic guide, use a setting of at least 75 hertz.
Confirm the change by clicking "Apply." Reboot the PC to ensure the new settings on the screen take effect.
Check your screen if the blinking problem is resolved. If not, try a higher refresh setting. If there is no change on the flickering of the screen, this means the problem is not caused by the screen's refresh rate. If your computer is not running on a battery or surge protector, shut it down to safely transfer the plug to another outlet Hope this helps.
Jan 15, 2013 | Computers & Internet
Desk top screen keeps flashing wont start up
THE IDEA OF THE SCREEN FLASHING COULD BE EITHER A WINDOWS PROBLEM OR A VIRUS,THE BEST WOULD BE TO GET A HOLD OF A WINDOWS INSTALLATION CD AND JUST UPGRADE THE CURRENT SOFTWARE THAT YOU ARE RUNNING ON THE PC.
Oct 03, 2009 | Compaq Presario Notebook
Toshiba satellite a105-s1014
try the computer with an external monitor, if it works correctly then it's the monitor that has broke and you need it replaced.
otherwise, if it does the same things on the external monitor...
I would check in order:
1)RAM memory
2)Motherboard
if the problem is only after windows boot, try changing the video driver, the problem might be caused by overheating video Chip, but that should freeze the system too...try also to remove the dust from all the heatsinks with canned air...
Jan 18, 2009 | Toshiba Satellite A105 Notebook
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Blue screen when I turn computer on
Not neccesarilt. Blue screens from windows usually are caused by hardware issues.
I got one once and thought " ah **** "
I looked up the codes ( took forever) and found out it was caused by a dirty disk in my CD drive.
You may not be that lucky though so try this.
Any hardware you have added or made major changes too can cause this.
Some times devices fight for port addresses and cause the blue screen
If you have several devices, try striping it down to the bare minimum you need to boot windows, then once its working, add one device at a time and start it up, If you get one that causes the issue again, then thats the culprit, Remove it and try finding updated drivers or using another port.
Video card can cause this as well. Especially the ATI catalysrt program.
let me know how it goes and if you still need more help. Good luck
Dec 04, 2008 | Acer Aspire 5002WLMi Notebook
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
Screen flashes and goes black when you move mouse
some virus or spyware would have been the cause for tat...
go to start and then run,
there, type msconfig n press enter
in tat msconfig window, try clicking startup tab, there, try to remove tat virus startup, which would have been the cause for ur problem..
after tat restart and check, if it is solved
Jul 20, 2008 | IBM ThinkPad 770 Notebook
My laptop does not work
Since you cant get anywhere from the compaq logo.. well try to press TAB button in the startup, try a few times (start it again if you dont get anything)
You should get the diagnostic screen.
If the bios needs to be flashed .. then the chip needs to be removed from the motherboard, difficult operation contact a local pc shop for help if you are not experienced in takeing laptops apart and useing a soldering iron the remove the bios chip from the motherboard and then flashing it in another pc motherboard.. well difficult it is.
I wont go into more detail.
Apr 15, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
15 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
