Question about Compaq Armada M700 Notebook
1 my system is very very slow. 2 It takes one to two minites to open a file 3 It shortens the amount of RAMs i had initially from 256M to 64M.ie,i have 256M of RAM but the system displays only 64M. THANKS.
    President:
  • 2,291 Answers
Clean Windows Registry :
Defragment your PC to increase computer speed: Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reg in out The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Posted on Oct 05, 2010
It is running so slow!! It pauses and screen fades to light color! I cannont do my work!! Help!!
This could be for a couple of reasons, 1) you have a virus causing your laptop to crash or 2) you have a faulty Hard Drive.
Try downloading and running Hit Man Pro (an anti-virus software) that should clean up any viruses you have, download it here:
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2239_4-10895604&ontId=2239_4&spi=50fbf8256fc023103cca4ba60e4a71b1&lop=link&tag=tdw_dltext<ype=dl_dlnow&pid=11754089&mfgId=6302975&merId=6302975&pguid=CyZLHAoOYI4AAAxmYBAAAABD&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-2239_4-10895604.html%3Fspi%3D50fbf8256fc023103cca4ba60e4a71b1
Run the scan and remove and viruses it finds and reboot the computer...see if this makes any difference, if not, try booting up in the recovery partition and repairing Windows.
Let me know if this helps
Mar 21, 2011 | HP Pavilion dv2310us Notebook
My computer runs slow. It takes a long time to boot up. Occasionally I get a message that virtual memory is low. Is there something I can do myself?
Hello
Yes, this is a very common problem for computers which does not have the sufficient amount of ram installed for the software the machine runs.
At the link below you will be able to read a couple of tips on how to improve your computer speed.
Click HERE.
Kind regards
Andrea
Sep 19, 2010 | Dell Microsoft Windows XP Home Edition
Hi MY laptop is running very slow
For the better performance delete cookies,temp files from the computer.
Uninstall all the unwanted softwares from the computer.
Run disk clean up
  1. Open Disk Cleanup by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, clicking Accessories, clicking System Tools, and then clicking Disk Cleanup.
  2. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. If the Disk Cleanup: Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
  4. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
  5. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer.
.To run disk defragmentation.
1. Open the Start Menu. A) In the white line (Start Search) area, type dfrgui and press Enter.
OR
B) Click on All Programs, Accessories, System Tools, and then on Disk Defragmenter.
Increase the virtual memory of the computer.
How to increase Virtual Memory?
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
This will improve the performance of the computer.
Thanks.
Aug 20, 2010 | Computers & Internet
Runnng very slow. Could this be a hardware or software problem? When I click on the start it takes several seconds for the window to open and about 2 minites for all the info to display in the window. Also...
For the most part i sounds like the machine need to be cleaned. Go to Iobit.com and download advance system care , go into my computer drive C: or your HD and get into windows . Go to Prefetch and create a shortcut . once on desktop Click it open and in edit /select all / now go to file open select /delete/ and empty it . Go to malwareBytes.com download malwaqreBytes .Run it .Empty trash Bin / Defrag/Also when at Iobitwebsite download Iobit360. All are free.
Nov 18, 2009 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Upgrading memory
hi If you go to www.crucial.com they will scan your pc & tell you what rams youhave & what you need. then buy from wherever. hope this helps blue51
Apr 14, 2009 | Dell Dimension 4600 PC Desktop
Slow start...
Hello there...
Keep in mind this
1) OS ?
2) How you format your HD. FAT32? or NTFS? how many times?
perhaps you got a bad sector on your HD.
3) verify your CMOS, if you enable 32 enhance mode.
4) Check if you do a quick format? or regular format (takes long)
example: on C: Format C:
5) Antivirus you got? Norton 360? Avg? this could sometimes slow down a bit the systems, and resourses.
6) Memory problems? check
7) Your pagefile? on advance setting in SYSTEM, control panel. put in ( let windows decide...)
thats it
happy nice time
Open Sky
Jan 23, 2009 | Microsoft Computers & Internet
3 minite and above take for laptop booting © problem
Here are some things you can do that will boost your performance back to normal.
First, go into Start>All programs>system tools and run Disk Cleanup. This will get rid of all of the junk like *.tmp files that has built up. Second, in the same place after you run DiskCleanup run Defrag. This will take care of all the gaps on your hard drive so data can be found more easily. Finally you need some more RAM. 1GB these days with all the intensive programs is minimal especially if you have a 250GB HDD. Means if you load that puppy up your access time will be very slow with only 1GB. All programs load into RAM when they run, so with only 1GB your system has to constantly keep going back and forth to your hard drive to get code and that makes it very slow. Hope this helps and thanks for using FixYa. If you have any problems let me know.
Dec 30, 2008 | Toshiba Satellite L25-S119 Notebook
Slow starting Dell Inspiron 2650
The first thing I would look at is hard drive free space. Almost universally, critically slow systems have a hard drive with no free space. What most people don't seem to understand is that Windows requires a minimum of 10% of the hard drive to be free space to allow the operating system room for swap files and other temporary files needed to run the OS efficiently. This can be made worst by the fact that Windows only reports the size of a file on the hard drive, not the amount of space actually allotted to the file (This has to do with cluster size and the fact that only one file is written to any part of a cluster and in this case it is small files that waste a lot of space)
Things you can do.
1. Run disk cleanup, and get rid all temporary files.
2. If you use an email client like Outlook/Outlook express, delete unwanted emails, then empty the deleted items folder.
3. Open Internet Explorer, Tools, Internet Options, delete all cookies and temporaty internet files.
4. Go to add/remove programs in control panel, uninstall any programs or applications you do not use.
5. If you have a large amount of pictures or music files on the system, burn them to CDs or DVDs and free up that space.
6. Go to System Properties, Advanced Tab, performance section, settings button, select Adjust for Best Performance, Click Apply, Click Advanced TAB, Virtual Memory, Change Button, Select System Managed Size, Click Apply close then reboot.
7. Go to MY Computer, right click C:, Click Properties, Tools Tab, Defragment the Hard Drive
8. Adjust power management to Maximum perofrmance.
Nov 07, 2008 | Dell Inspiron 2650 Notebook
Problem upgrading RAM on a Sate Pro 4600
Just a few questions first, get back to me (before rating me), and I'll see if I can get you through this. You have tried each 256 chip individually in each slot with the same error, correct? Are the 256 chip the same make? What operating system are you running? And finally, at least for now, have you done any drive, utilities, or bios firmware updates lately?
Aug 01, 2008 | Toshiba Satellite Pro 4600 Notebook
Can I use 256M in Axim
Not sure about the SD but I don't see why not, as for CF I'm positive it'll support ANY size cf card out there...
Sep 13, 2005 | Dell Axim X5 Pocket PC
Compaq Armada M700 Notebook Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
