Question about Frigidaire FDL60P1 Dehumidifier
Frigidaire FDL60P11 power light flashing - Frigidaire FDL60P1 Dehumidifier
  • kjhfrost Sep 13, 2010
    no other error codes...just the flashing power light...thank you
    blinking at a constant rate, no sequence
  • 10,515 Answers
Do you see any error codes or only power light is flashing?
Thanks!!
Posted on Sep 12, 2010
  • taran_2005
    taran_2005 Sep 13, 2010
    Thanks for your response!!
    Is there any sequence or it is blinking continuously without any sequence?
    Thanks!!
    President:
  • 4,070 Answers
HI! You may want to check the link I provided where you can check all the fault codes of your frigidaire. Please download the manual. Hope this helps and thank you for using FixYa! Click here http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Sep 13, 2010
I plug it up display shows 8.8. and goes blank. Power light on top and side is green ON. Full bucket light and alarm works, timer button works, nothing else works.
Hello Ethan, thanks for your submission!
Based off what you have described your Frigidaire dehumidifier is displaying 8.78 after being plugged in. This could be an internal issue with a sensor or panel. You may need to contact your manufacturer for additional assistance. Good luck! -Matt
Apr 27, 2016 | Frigidaire Fdl50s1 Air Purifier &...
I e got a frigidaire energy star dehumidifier. Only the green power light cuts on. How can I get this appliance running?
Thank you for your inquiry, friend!
I see that you have a Frigidaire dehumidifier and the green power light stays on except it is not working. Typically, you have to set the dehumidifier in order to operate. What does your display say? If you can provide me with any additional information I would be happy to assist you. -Matt
May 06, 2015 | Frigidaire Dehumidifiers
I have a Frigidaire Dehumidifier, Model FAD704. the Clean Filter lights keeps coming on and the unit stops running. The filter is not dirty. I take it out and put it back in and unit runs for awhile and...
Hello Winl, thank you for your inquiry!
I see that you are having issues with your clean filter light coming on in your Frigidaire dehumidifier. From what you are describing it sounds like a possible issue with a sensor within your dehumidifier. I would recommend consulting with your manufacturer to see if they can provide any additional assistance towards a resolution. Best of luck! -OOS
Dec 12, 2014 | Frigidaire Dehumidifiers
I have a FAD 704 DWD, does it not have a power on light? I called for a question regarding a different issue and the service tech said it was very bad to not have the on light "on".
Thank you for your inquiry, Lisa Cooper!
I understand that the power light on your Frigidaire dehumidifier is not showing you the power light is on. It sounds like you could have an issue with your control panel. If your dehumidifier is running it could be that the light has failed. If you have a current warranty I would reach out to your manufacturer to see if they have a resolution for such an issue. Hopefully this helps. -Matt
Nov 17, 2014 | Frigidaire FAD704DWD 70 Pint/Day Energy...
Frigidaire dehumidifier just died shows no power no lights coming checked and made sure outlet was fine
Hey friend, I appreciate your inquiry!
If your Frigidaire dehumidifier is not powering on it could be an issue within the control panel or power cord. I see you checked the outlet it was plugged into, I would test your appliance in another outlet. If you still receive the same response it sounds like it could be a problem within the panel or power cord. Is your appliance under warranty? If so, I would advise you to reach out to the manufacturer to determine any potential remedy. -Matt
Aug 28, 2014 | Frigidaire Dehumidifiers
FDK45P11
Hi! Same thing just happened to me. There's a black plug in the back that just pulls off. It's no bigger than a dime. Once I pulled that off some water came out, not that much but enough to get my machine working. Hope that helps!
May 11, 2012 | Frigidaire FDL45P1 Dehumidifier
My frigidaire dehumidifier power light is just flashing in not working
Try checking for plugged drain ,also check wire connections
Mar 17, 2012 | Frigidaire Dehumidifiers
My dehumidifier says the bucket is full, when it is empty. the red light flashes and it beeps. I can't get any buttons to work. I have taken the bucket in and out several times. Any suggestions? It did...
First, the unit may need to be cleaned and after that, unit may need to be reset. Turn the Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. Then plug it back in and turn the Master ON/OFF Switch to ON. Set the controls as you normally do. Hopefully, that 12 - 15 minute timeout, allowed the electronics to reset themselves. If this continues to occur frequently, contact an authorized Frigidaire Service Center
Hope this helps you troubleshoot and solve the problem.
May 02, 2011 | Frigidaire FDF70S Dehumidifier
Power lose
I have a 45 pint. I have to slide the bucket in and out of the unit multiple times. Make sure to wait a few seconds after each time to see if it will recognize no water (sometimes the red light comes on, but then changes it mind). Also, I've found that leaving the bucket a little crooked will make it respond. It sucks, I know. Mine is only a year old too. Should not be a problem like this!
Sep 14, 2007 | Frigidaire FDL45P1 Dehumidifier
Dehumidifiers Logo
573 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
