Linksys Wireless-G WRT54G Router Logo
Posted on Sep 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Configuration info on a wrt54tx2 - Linksys Wireless-G WRT54G Router
Anonymous
Level 2:
Scholar:
  • Expert 91 Answers
  • Posted on Sep 14, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
91
Questions
Helped
23635
Points
220
( use the computer that can go online wired into the modem )
if your ISP is cable:
open your browser, type 192.168.1.1 on the address bar, type admin on the password field.
on the SETUP page you'll see "internet connection type"
usually is set to DHCP
under SETUP, click on the subtab MAC address clone.
enabled it and click clone that MAC of your PC, save to settings and power down the modem and the router.
please rate me
Hello lost my password to access my zyxel 660hn router and i am concerned about resetting as I am not sure of the info I will have to enter after reset..its in French and German and not english. will the...
If you lost your password to access the router's web interface, then a hard-reset is the only thing you can do. That said, it will configure the router to factory condition. If your ISP requires particular authentication (like a member ID and network password for DSL), then this information WILL need to be re-entered. If your ISP does not require that configuration, then nothing would need to be configured after the hard-reset. Before moving ahead, it may be a good idea to contact the ISP to understand configuration requirements.
1helpful
Message light keeps flashing, but no message- Polycom 550
This is usually a problem with the phone's configuration. Is this phone getting it's configuration from a network server or pbx? If so, find the configuration file for your specific extension and find this location. This example is for a phone whose extension is 2704
msg.mwi.2.subscribe=""
msg.mwi.2.callBackMode="registration" msg.mwi.2.callBack="" msg.mwi.3.subscribe="" msg.mwi.3.callBackMode="registration" msg.mwi.3.callBack="" msg.mwi.4.subscribe="" msg.mwi.4.callBackMode="registration" msg.mwi.4.callBack="" msg.mwi.5.subscribe="" msg.mwi.5.callBackMode="registration" msg.mwi.5.callBack="" msg.mwi.6.subscribe="" msg.mwi.6.callBackMode="registration" msg.mwi.6.callBack=""/>
If you are not using a network-based configuration, the phone's settings can be changed via the phone's internal web server. Open a web browser window and enter the phones' IP address, i.e. http://192.168.1.109. The default user is 'Polycom' and the pass '456'. Go to the links at the top for each line you are using and scroll to the bottom, you will see the voicemail settings there. Use the above info to fill in the correct info, save the settings and the phone will reboot.
I can't find ACER TV info on the web. I'm after
tenho problema de localidade numa tv led comprada na europa modelo AT2058ML que não aceita antenas do Brasil. Gostaria de saber como configurá-la, porque o menu na antena pede outros e código do Brasil, mas não sei como configurá-lo.
Sem mais,
Neori Paim
1helpful
3answers
Cisco VPN doesnt get connected through DI-524UP router. Worked fine until recently for both the laptops we use. Log indicates Receive: Purging stale cached fragment(s). Direct connected on the Motorola...
Cisco VPN
Upgrade your router to the latest firmware. You can download firmware at http://www.dlink.com.au/tech/ .
Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Configuring PC running VPN Client Software:
Step 1 Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
Step 2 Change IP Address to be outside of the routers DHCP Pool (i.e. 192.168.0.99). By default the DHCP pool is 192.168.0.100 - 192.168.0.199.
Step 3 Configure Cisco VPN Client - Connection Properties.
Step 4 Check Enable Transparent Tunneling.
Step 5 Allow IPSec over UDP ( NAT/PAT).
Configuring Router using the Web-based configuration:
Step 1 Open the Web Configuration Page by entering 192.168.0.1 into your web browser. Enter username (admin) and your password (blank by default).
Step 2 Check the Status tab and make sure that you are running the latest version of firmware. If not, upgrade firmware before proceeding.
Step 3 Click on the Miscellaneous button on the Tools tab. Enable both PPTP and IPSec.
Step 4 Click Apply.
Step 5 Click on the Virtual Servers button on the Advanced tab.
Step 6 Enable IPSec from the list and configure as follows:
Private IP: IP Address of the PC running Cisco VPN Client
Protocol: UDP
Private Port: 500
Public Port: 500
Schedule: Always.
Step 7 Click Apply and then Continue.
Step 8 Enable PPTP from the list and configure as follows:
Protocol: TCP
Private Port: 1723
Public Port: 1723
Schedule: Always.
Step 9 Click Apply and then Continue.
http://www.dlink.com.au/tech/default.asp?model=DI-524UP
Netgear WGR814v2 does not see my ASUS 1005HA-P netbook, but the netbook sees the the Netgear wireless network but cannot connect .
To connect into your own Netgear router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Netgear WEB site to download this info.
To configure the Netgear router for wireless you need to connect a LAN cable from the laptop to the router and run your browser with the configuration IP address. for Netgear type the URL address ;-
http://192.168.0.1
the login = admin PW = password
Then configure the SSID and encryption, record this info so you can configure the wireless card with the same settings.
You can also connect to the Internet by using a LAN cable and plug it into the Netgear router without a wireless connection.
Configuration for my motherbaord
Look on the motherboard for all numbers,names and info. This will help ID the motherboard. Then enter info at dell support site search engine that should give you the info you need.
1helpful
2answers
How do my router configure
open your browser. in the address line type in 192.168.0.1
username = admin
password = system
You should be able to make configuration changes there
Jan 14, 2009 • Cisco IOS
3helpful
Counter info print out
Hi Beadworker,
This information can be found by printing a configuration page from your printer. Follow these steps to print out a configuration page.
Printing a Configuration Page
You can print a configuration page from the printer’s control
panel. Use the configuration page to view the current settings,
to help troubleshoot problems, or to verify the installation of
optional accessories, such as memory or an optional tray.
To print a configuration page:
1 In ready mode, press the Menu button on the control
panel until you see “Information” on the bottom line of the
display.
2 Press the Enter button to access the menu.
3 Press the Enter button when “Configuration” displays
on the bottom line.
A configuration page prints out.
Hp3500 finding the volumes i have printed
Print a configuration page using the menu on the printer. Press the check button, then scroll down to the info menu, press check button, scroll down to configuration page, press the check button. The printer will print the page and give the page count for your printer. There is also a "supplies" info page under the same info menu that will give you the levels for each toner cartridge.
Hope that helps you.
Motorola..routers with cieso
sure as long as want to configure them for TCP/IP not sure what else you would be talking about other than maybe VPN. I'm assuming the motorola is a cable modem...not much configuring there... more info would be required to be definitive but overall the answer is yes.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
