Question about Sport & Outdoor - Others
Manual for the XL Stepper excercise - Sport & Outdoor - Others
My speedometer is buried at 120 sometimes it will go to 60 not working . I love my Yukon and I only have 128,000 on it. sometimes the lock engine light comes on and car won't start, until you wait.
A problem with the instrument cluster gauges is common on your year to 06 . The motors that control the speedometer go bad ! Stepper motors are what they are called . Here is a video on how to fix the problem . How to repair GM Instrument Cluster Speedometer Gauge Stepper
May 20, 2016 | 2003 GMC Yukon XL 1500 SLT
Rpm gauge not working
Could be a bad instrument cluster (bad stepper motor) or the vehicle speed sensor is bad. Does cruise control work, if it does then it is the cluster.
Mar 20, 2014 | 2005 GMC Envoy Xl
Speedometer sticks after turning ignition off
Bad stepper motor in cluster, can be replaced if you are handy. Part is available on Ebay.
Nov 29, 2013 | 2005 GMC Envoy Xl
I have a 2003 yukon xl , the instrument panel on my dash went out causing gauges to be stuck. ie: gas gauge full , mph at 30 , rpm at 1000 . One indicator still comes on when starting the vehicle. but the...
Replace the insturment cluster or fix it ! From 03 to 06 GM insturment clusters had bad stepper motors , this motors control the gauges .
Plus they have silver migration , this is caused by the solder they used . Can cause wierd problems .
Chevrolet Truck Battery Dies Overnight Part II
Jul 07, 2017 | 2003 GMC Yukon XL
No oil pressure on my 2009 Yukon
You need to be careful here. If you are driving your Vehicle with ZERO PRESSURE, you are going to blow up your engine.
There is also one of 2 other scenero's for a GM Vehicle
FIRST: Instrument Cluster STEPPER MOTORS are KNOWN to be going BAD in GM's/. If the Stepper Motor is bad, make sure you replace it with a X27.168
SECOND. Your Sending Unit could have come unplugged or the Unit itself went bad.
I am Betting that your Stepper Motor went bad (Happens that Frequently).
I would put a Gauge on the Motor and see what the Oil Pressure Actually is, if it is Truly ZERO... do not start or Drive the vehicle and take it to a Good Mechanic or if still under warranty.. To the DEALER
Apr 08, 2013 | 2009 GMC Yukon XL
Stairmaster 4400 display went dead and now there is no resistance to the peddles and the display doesn't pop up at the start of excercise.
Investigate the battery on this unit. The machine uses a 6volt battery. If there is no power, there cannot be any resistance.
Sep 24, 2010 | Stairmaster 4400CL Stepper
4-wheel drive does not work
you may need to replace the stepper motor in the 4wd box,they have a bad rep.
Jul 24, 2009 | 2001 GMC Yukon XL
I need to put back together a weider Pro 4900. I
I have it for you for free. Just email me at
ceo@teampar.com and I will send it to you. It is in pdf format.
Jul 08, 2009 | Exercise & Fitness
Stepper motors
good day,
hope this link below will solve your problem.
motors
Oct 24, 2008 | 2003 GMC Yukon XL
Sport & Outdoor - Others Logo
351 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
