B.C. Rich Nt Warlock Electric Guitar Logo
Posted on Sep 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ok so i was tuning my Warlock and was tightening my E string when i broke the part that holds the string at the top ( not the tuning peg but just above the neck) how can i fix this or how much will it cost to fix in Canadian $?
Cameron Lewis
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Contributor 64 Answers
  • Posted on Mar 27, 2011
Cameron Lewis
Contributor
Level 1:
Mentor:
Answers
64
Questions
Helped
27126
Points
96
You broke the 'nut' of the guitar. These cannot be repaired, but they can be replaced. Most guitar shops, such as Guitar Center, Sam Ash Music, and Musician's Friend, carry these in stock. They are fairly simple to replace, and cheap to buy. I would get a few if I were you.
They come in quite a few different materials, as well as many different colors. For color, you'll want to go with what matches the rest of your hardware. If you have chrome hardware, a white nut is good. Black hardware calls for a black nut. As for materials, that's up to you. A GraphTek nut, made mainly of graphite, reduces string friction, but costs a lot more than your standard bone nut, and almost a fortune more than a plastic nut. Sounds like you had a plastic nut, which is good for a beginner's guitar. If you can swing it, get a bone nut. It will last longer, and helps out a bit with your tone.
For replacing it, just take your strings off, and swap them out. Some guitar manufacturers glue their nuts into place, so you might have to pry on it a bit. Be careful not to scratch your guitar. It will be easier if you take off the truss rod cover (the triangular looking piece of plastic at the base of the headstock). Then, you can get some leverage under the nut, without scratching an obvious part of the guitar. Still, be careful.
After you get the old nut off, you can either place the nut on there, and string it up, or glue it in. Wood glue is suggested for the second option, but you'll have to clamp it in place and let it set overnight. The next day, you can string it up and play again. Mind you, this option is NOT recommended if your band has a gig either that night or the next day.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Fred Yearian
Level 3:
  • B.C. Rich Master 5,603 Answers
  • Posted on Sep 13, 2010
Fred Yearian
B.C. Rich Master
Level 3:
Answers
5603
Questions
Helped
2248518
Points
16162
The official name of the part the strings run over at the top of the neck before going to the pegs is the "nut". This is the common name for the function on most stringed instruments.
You can buy these at guitar shops and replace your own, but sometimes they have to be adjusted to get the strings at the right height. Take your guitar to a place selling them... they may even be able to quickly change it for you.
I just got two nuts from Guitar Center for a bass and they were less than $5 each.
1 Related Answer
criss_michae
Cameron Lewis
  • 64 Answers
SOURCE: the part that holds the strings under the bridge
The tailpiece, as it's called, can be purchased from various parts shops, as well as online. Check AllParts as well as Warmoth. either one should have what you need. If you don't want to pay shipping, then you may be able to find it at Guitar Center, Sam Ash Music, or Musician's Friend.
If it's a string-thru-body design, then you'll have to take it to a luthier (guitar builder and technician) to have it fixed.
Hope that helps!
2answers
I have a set of 11-48 12string i have never strung a 12string guitar before.can you tell me what string goes in what hole? 48 40 30 26 20 16 14 14 12 11 11 9
the Heaviest string of each string pair is placed at the top (closest to your nose). In fact, if you look at the nut, (the notched thingy that spaces and holds the strings at the right spacing up by the tuning pegs) the notches in nut are wider than the paired string for this reason. That may not be true on all 12 strings but it is on mine. So the typical arrangement is heavy string, matching string. Heavy String, matching string. Except on the bottom 3 pairs where the actual string thickness can be the same. One caution note here....when tuning a 12 string, tune it a whole step lower. So rather than tuning it at EADGBE, tune it at DGCFAD then use a capo on the 2nd fret to bring the tuning up to EADGBE.
The reason for tuning a whole step lower is because on the top 3 pairs of strings you normally tune the thinner string an octave higher to give that 12 string sound. So if you start tuning at EADGBE, those thinner strings for the top EAD strings are going to be pretty tight and they will snap. So much safer to tune a whole step lower and just use a capo!!! Good Luck
Nov 13, 2017 • Music
Tuner Won't Acknowledge Sound
Before turning the unit on, press the calib/batt button to check the battery condition.
The Fender AG6 only responds when the strings pitch is within a certain frequency range. If the guitars tuning is not within that range or if your installing new strings, first connect the guitar to the AG6 with a cord that you know to be in good working condition and turn the AG6 on. Then starting with the low E string (the thickest one), loosen the tuning peg to a point well below the standard tuning for that string. Then slowly tighten the peg as you strike the string repeatedly. When the strings frequency, comes within range you will see the 6E light glow and the needle will begin to deflect. When the needle reaches zero it is in tune. Do the remainder of the strings the same way then go back and recheck each a second time. If you have a tuning fork, you can use it to tune by ear then re-tune and maintain it with the AG6
Remember to always stretch then re-tune new strings several times.
If the AG6 does not respond even after checking the condition of the battery and the cord that connects the guitar to the tuner, the problem could be inside the AG6 with a bad connection on the board. Try moving the cord as you strike a string that you know is close to being in tune. Again a tuning fork would be helpful.
~DrewWatk
Guitar tuning peg seems like it might be broken it will tighten the string to a certain point then it clicks and its completely loose again...I'm new to guitar so I don't know If this is normal
It seems like you wound and tightened your string on the tuning peg loosley. Try wounding the string at least 4-5 times around the peg after you pass the wire though it and then after winding pass it through the hole again. Tighten well.
If that doesn't work your peg might be broken, but looking at it on the video seems that it's not, even though you can't see it clearly.
Try tightening the screws on the peg, since there's a lot of tension on the highest string and it might cause the peg to click back because the tension is too high and it's loose.
Jan 30, 2013 • Music
Broken sitar tuning peg
by now I hope you've bought or made a new peg. with any tension on it, the splintered wood, broken at an angle, won't hold long enough to tune the string. either make one out of a dowel rod, with the tapered end sanded to fit tightly, or use a brand new one made of plastic.
1helpful
3answers
What is the proper way to change a string on a guitar so it doesn't slip?
The first thing to remember is that the strings will stretch so i always over tune it about a turn for small strings and 3 for the big strings. To prevent it from slipping when you are tightening the string pull it tight while turning it and make sure the string has overlapped its self a couple times before releasing it.
I am re-stringing my Fender 140sce and every time I begin to tune a new string up, the peg pops up. Do I keep pressure on it to try and keep it in place until it is fully in tune, or is this out of the...
It is a little tricky, but you have to kind of pre-form the ball end of the string so it tucks under the ledge of the hole it goes into. Then put peg in and as you do pull up on the string slightly so the pre-formed ball end is caught under the ledge. Make sure the slot is toward the neck direction and the string seats in it, Also once the string is seated, kind of preform the string over the edge of the hole as the string is started to be tightened.
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
I have an Ibanez Art 100 and I am having trouble tuning the G string. It seems to sound sour and either a little flat or sharp.
Trace the string from the body to the tuning peg, making sure that there isn't anything rubbing and that the string is routed properly. Compare it's routing to your other strings. When you get to the tuning peg, note how many tines the string goes around the peg. It should go around at least three times (more is better, to a point), and wrap above and below the tail of the string to friction lock it to the peg. If it isn't locked in, the string will loosen itself over a period of time, making it impossible to keep it tuned.
Hope this helps! Regards, --W/D--
1helpful
2answers
Blinking peg white when tightening
idk how i did it. i kinda just clipped the strings a bit more and it worked :)
3helpful
5answers
How do i repair my B.C. Rich guitar??
Guitar manufacturers use generally one of two different knob types: (1) knob has a small set screw of some type holding it on or (2) press fit onto the shaft of the tuneing pot (volume knob in your case).
Now, the problem is if it is NOT a set screw type, it is press fit. You see press fit used most of the time on lower-end instruments (and a few high end). The BEST way to get a stuck volume know off is to get a shoe string, loop part of it under the knob, brace the guitar firmly and PULL SLOWLY WITH FORCE. Realize that it is possible to damage the guitar if you **** on the string too hard.
I have never seen where a stuck know did not come off (or hear of someone breaking their guitar doing it).
I have also resorted to using a small screwdriver: work it way under the know and gently twist it to loosen it so it can be pulled off with a string or your hands.
Be carefull not to scratch your guitar!
Good luck,
-mike
Top B.C. Rich Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a B.C. Rich Music Expert? Answer questions, earn points and help others
