Question about Whirlpool Dryers
WHIRLPOOL DRYER, NOT GETTING HOT. NOT DRYING CLOTHING.
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Water coming from under appliance
Maybe your dryer is not drying!!!!!!!! Is it getting hot? Heat element ok? Maybe the washer is not doing a good enough job during the spin cycle and leaving clothing excessively wet.
Sep 08, 2017 | Refrigerators
Kenmore 66902691 dryer not drying completely; dryer lid opens up every 2-5 min.
Either the heating element is getting too hot and tripping the cut out or it is over loaded with clothing
Nov 09, 2016 | Kenmore Dryers
WHIRLPOOL DUET DRYER-Line clogged with wet lint from daughter air drying all of her delicate heat shrinking clothing. Dryer quit heating all at once that is when I discovered all of the wet lint in the...
if your dryer does not seem to be drying the wet clothes, first check that it is generating heat. If not, check the vent to make sure it is clear.
If the dryer runs but fails to heat clothing, check the circuit breaker. Most dryers use so much electricity that their functions are divided between two breakers. If one has been tripped, that may be why the heating elements aren't functioning. If the dryer still isn't heating, unplug it and pull it away from the wall. There's a service access panel on the back that should be pried free. Inside, you'll find a small black strip of plastic with two blue wires attached. This is the heating fuse. A replacement part can be had for around $15, and takes a little less than 1 minute to swap out. It's unlikely that the heating element itself, which consists of a few metal coils, is broken. If the dryer still won't heat, you're better off getting a replacement dryer than repairing the old one
Dec 08, 2011 | Whirlpool Dryers
My whirlpool dryer moder ler6620pto gets hot but clothes are taking to long to dry. it seems to be getting hot enough.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 21, 2011 | Whirlpool Dryers
My Whirlpool Dryer (model no. LGR4634EQO) is no longer heating, or getting hot at all. How can I troubleshoot it??
Hello.
suggestions about things they can do to troubleshoot commonproblems.
Instructions
    • 1 Open the dryer door and remove the lint screen ifthe clothes are not dry after a drying cycle completes. Remove the lint fromthe lint screen and replace the screen. The dryer ought to dry more efficientlyafter the lint screen is cleaned.
    • 2 Open your home's breaker box if the dryer is notturning on or no indicator lights are visible on the front panel. If theswitches for the dryer in the breaker box are flipped to "Off," flipthe switches over to the "On" position.
    • 3 Remove some of the clothing in the dryer or drysmaller loads if you notice that the clothing is wrinkled when you finishdrying a load. Larger loads cause the clothing to wrap around one another whendrying, increasing the likelihood of wrinkles.
    • 4
Pull the dryer unit away from the wall and checkon the position and arrangement of the exhaust vent. An exhaust vent that ispinched between the wall and the appliance or an exhaust vent that is kinkedcan't allow air to flow through it properly, making it difficult for theappliance to dry properly.
    • 5
Make sure the door is closed if the dryerdoes notrun. Also check to make sure that you hold in the "Start" button forat least a second. Pressing the button for less than a second may not give thethe dryer enough time to recognize the button has been pressed and that itshould start.
Thanks for using fixya.
Jul 31, 2011 | Dryers
I have a whirlpool dryer and the heating eleiment is getting hot but the dryer inside is barley warm
Inside of the dryer gets warmed up when the drum rotates as there is circulation of air. Hope your clothes are drying. If it takes long time then clean the screen filter as it gets clogged with the flint from clothes. As a matter of routine clean this filter every time you use it before starting the drying process.
Sep 16, 2010 | Whirlpool LER4634J Electric Dryer
My whirlpool duet is not drying....it is not getting hot. It appears to be drying but it is not getting hot. I have to run the dryer multiple cycles.
Check for crimp in your vent line, Check your breaker. It is a dual breaker if one side pops it will run with no heat. Check those first.
Aug 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Dryer not getting hot enough
the heat sensor or spark ignitor is at fault
Feb 28, 2010 | Whirlpool LER4634J Electric Dryer
My dryer is not giving off hot air only cold and so the clothing is not drying
first, turn your breaker off then back on. then try it again. the heating element may have broken or a switch in the dryer could be bad.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 16, 2008 | Whirlpool Dryers
Dryers Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
