Question about Sylvania 32 in. Diagonal LCD HDTV
Is there a hard reset for the sylvania lc320slx
dsacco86
  • 1077 Answers
SOURCE: cant program direct tv remote with my new sylvania lc320slx
The remote is only programmed with only so many codes. Sadly, It doesn't hold all code for every TV made.
But you can try making the remote search every code stored inside to see if one of them will work.
Here are the instructions form the DIRECTV web site:
You may still find a setup code that works for your device by stepping through the library codes in your remote. The following instructions will help you do this.
StepNSet
  • Set the "Mode Switch" to the desired mode such as TV for a Television.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the code "991" followed by the "device number"
    1. for Televisions
    2. for "AUX 1" devices - VCRs or DVDs
    3. for "AUX 2" devices - Audio
  • You can step through the setup codes for this mode by pressing the "Channel Up" key to go forward through the codes or pressing the "Channel Down" key to go back to the previous codes.
  • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
  • When you've found the setup code that works for your device, press the "Select" key.
Posted on May 18, 2009
  • 10 Answers
SOURCE: comcast remote code for sylvania
I have the same problem. I found that there are many Comcast remotes by the way.
I called Comcast and they had no clue. But I called Sylvania and their reps were FABULOUS!!! Turns out, the TV makers send the cable companies the frequencies for each TV then the cable companies send them to a 3rd party to get the codes written.
This model of TV is new and there is no code written. The rep suggested that we countinue to check back on the Comcast website regularly to see if the code is posted. She said that the sales reps tend to get the info last.
The Sylvania rep anticipates a new code written soon because this is such a prevelant problem.
Posted on Dec 20, 2009
  • 10 Answers
SOURCE: I need the tv code for LC320SLX thank you, Joe...
  • 10 Answers
SOURCE: I need a remote code for my Sylvania TV. LC320SLX
The Sylvania rep anticipates a new code written soon because this is such a prevalent problem.
  • 10 Answers
SOURCE: Changing mono to stereo on Sylvania LC320SLX TV?
I think the issue with mono and stereo here, since it is a built in option, is possibly how the program is broadcast.
You should be able to press the "Audio" button and switch between what is available. If you don't have other options, it may mean that that is not available for what you are watching. If you need more information, it is on page 15 of the owner's manual. Here is a link to where you can view it online - http://www.sylvaniaconsumerelectronics.com/pdf/manual/LC320SLX.pdf
Sylvania LC320SLX television. The volume keeps turning itself down to "0". Happens on all channels/modes and happens with batteries removed from remote. Any idea what it is? Part # would help.
Try a hard reset to this set, and check. If it do not help, its main board is faulty, and should be replaced. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 25, 2015 | Sylvania LC320SLX 32 in. LCD TV
PLAYSTATION 3 NO SEE ON LC320SLX Sylvania TV
Hi there, please try to reset your display by following my guide -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
Apr 02, 2011 | Sylvania LC320SLX 32 in. LCD TV
Need code for sylvania to program remote
Sylvania LC320SLX 32" LCD TV This model does not have a remote code for any universal remotes or cable company remotes.
Feb 23, 2011 | Sylvania LC320SLX 32 in. LCD TV
Need the directv remote control code lc320slx
hi! i have a cople of codes here for your tv, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465, 1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!!
May 16, 2010 | Sylvania LC320SLX 32 in. LCD TV
Sylvania LC320SLX tv with Cox Cable Remote--codes listed do not work. Have tried the Sylvania codes listed for tv (0054, 0030, 0171).
hi! i have here a couple of codes for your tv, just try them, 1046, 1465. hope this helps! goodluck!!!
Feb 04, 2010 | Sylvania LC320SLX 32 in. LCD TV
Cannot get the uverse remote to program for my TV. TV is
hi! i have here a couple of codes for your sylvania tv, just try them, 1046, 1465, hope this helps!!! goodluck!!!
Feb 01, 2010 | Sylvania LC320SLX 32 in. LCD TV
Sylvania 32 in. Diagonal LCD HDTV Logo
563 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
