SanDisk MP3 player MODEL SDMX1 1024R v2
Would it be possible to get a instruction manual for this MP3 player?
  • valerie923 Jul 19, 2008
    need manual for SanDisk SDMX1 1024R
    valerie923@gmail.com
    Sergeant:
  • 250 Answers
Hello Edwardwf,
It appears that the User's Manual for this particular MP3 player can be downloaded off the Sandisk website at this link: http://www.sandisk.com/Assets/File/tech/docs/dap-user-guide-v2.0.pdf.
Best regards,
Ken
Go Ahead. Use Us.
Posted on May 15, 2008
Need free instruction for SanDick Sansa MP3 player
Your message does not specify the exact model of MP3 player. Sandisk website has downloadable user manuals for the players they show on their support page as well as firmware updates. Try looking for yours.
http://kb.sandisk.com/
Dec 28, 2011 | Audio Players & Recorders
The mp3 player is frozen once it turns on. Keeps on saying refreshing your media.
Press and hold the power button. Hold it long enough (10 to 15 seconds ) it will eventually turn the frozen player off. Press the power button again to turn it back on. You can try formatting the player again either through windows media player or (if a v2 model) through the player's own menu system. Failing that, put the player in MSC mode and format it from Windows Explorer. I would also update the firmware. I have attached the link to the Sansa site to find the firmware and further instructions.
Thanks for using FixYa.
http://forums.sandisk.com/t5/Sansa-e200-series/bd-p/e200
May 29, 2011 | SanDisk Sansa e250 MP3 Player
I erased some things i didn't think i would need from the mp3 player (photo folder, etc.) and now when it turns on it just says "Load main image failed, switch to recovery mode"
STEP 1: Soft Reset
Simply press and hold the power button for 20 seconds. The soft reset would refresh the player. After doing the soft reset, try to turn on the player once more. If this didn't resolve your issue continue to step 2.
STEP 2: Firmware Update
Firmware controls the functions of your device (how your device operates). In cases where the product does not perform as intended, the update fixes the issue by replacing the current firmware with the latest enhanced version.
Please be reminded that for your player to work properly you need to meet the requirements below.
- Windows XP SP2 or higher
- Windows Media Player 10 or 11
To Download the Sansa Firmware Updater, you may copy and paste this link to the address bar of your web browser:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
To Know More on Using the Sansa Firmware Updater:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=306
If you encounter any issues with the Sansa Firmware Updater, we can try to use the Manual Firmware Update.
There are three versions of the Sansa e200 - Version 1, Version 2, and Rhapsody. This can be found by going over to "Settings" if you found "format" then you have a "v2" or look at the back of your player and check the exact model number under the "CE" logo it should say "model:e200" for Version 1; "model:e200 V2" for Version 2; and "model:e200R" for Rhapsody Version. Make sure that you choose the correct firmware version for your device as updating it using the wrong firmware version may render your device useless.
E200 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=15209
E200V2 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=13548
E200R Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200R&thread.id=2280
Dec 25, 2010 | SanDisk Sansa e200 MP3 Player
Just recevied SanDisk Sansa e200 MP3 Player. I thought I could download a pdf file of the user guide. I seems this is not possible. Where can I find a PDF version of the user guide? Mario
You can find the e200 manuals here:
http://kb.sandisk.com/app/answers/detail/a_id/4487#e200
Note that there are two different manuals; one for the v1 model, and another for the v2 model. You can determine which version you have by going to the Settings menu on your Sansa, then "Info". If the number of the firmware version in the top line starts with an "01", it's a v1 model. If it starrts with an "03", it's a v2 model.
Feb 17, 2010 | SanDisk Sansa e200 MP3 Player
Alittle confused about the Sandisk Sansa e260
yes it will still charge and transfer data....but only if it has the same usb type that connects to you mp3 player...
Feb 22, 2009 | SanDisk Sansa e260 MP3 Player
Max. micro sd card size compatible for Sansa C240
It depends on the version. v1 players can support up to 2GB. v2 players can support up to 8GB.
You can find out what version you have by going into Settings -> System and look at the version. If it starts with a 01 then it's a v1, if it starts with an 03 then it's a v2.
You can use a card up to 8GB if it's a v1 player by installing Rockbox on it. It's a 3rd party firmware for some mp3 players - although you should make sure to read any instructions for installing it, as well as read the manual.
-> Rockbox.org
I will stress this again: make sure you know what you are doing by reading installation instructions and the manual.
In order to install Rockbox on your player it needs to be in MSC mode (Settings -> USB -> MSC). If your player doesn't have the USB option in the Settings menu then you will need to downgrade your firmware. There's info on this in the Sandisk forums about how to do this.
Jan 29, 2009 | SanDisk Sansa c240 MP3 Player
Need a manual for a Sandisck Sansa model: m 250
A manual is available at http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Dec 04, 2008 | SanDisk Sansa m250 MP3 Player
Sansa e280
You have a version 2 player. If you look at the back of your player in the bottom right hand corner, you will see v2 in tiny letters after the e280. When the v2 players first came out, they didn't have the USB option. About 2 weeks ago Sandisk came out with a firmware update 3.01.14, which returns the USB option. Go to:  http://www.sandisk.com/Retail/DriverDownloads.aspx  download the sansa firmware updater, follow the instructions and it will upgrade your firmware to get your USB option.
If your have any further questions or problems with your player go to the sansa e200 forum for additional help:  http://forums.sandisk.com/sansa/board?board.id=e200&page=1
Dec 25, 2007 | SanDisk Sansa E280 MP3 Player
1,130 people viewed this question
 Grubhead
Grubhead
