Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Loud buzz, soap dispenser pops right open
I have a Whirlpool Quite Partner 1 DU1055XTPQ3, just today as soon as I started it there was a very loud buzz and the soap dispenser popped right open instead of waiting a while. This contines - I close the soap dispenser, shut the door and where I press Start or Cancel, there is this extremely loud buzz and the soap dispenser pops open. Buzzing continues and very little water comes in. Spray arms do not move.....
  • Anonymous Jun 25, 2008
    I Have a Kenmore Ultra Wash (made by Whirlpool I think) and as soon as I press the start button--there is a loud buzz and the soap dispenser pops open. About 20 minutes into the cycle, a loud continuous buzz starts and stays until the dishwasher is done emptying.
wheelshot
  • 102 Answers
SOURCE: LOUD HUMMING AFTER WATER FILLS AT START OF CYCLE
Sounds like you have something in the sump/motor. I could lead you through it on a chat session but too much just to type. Let me know if you would like me to do so.
Posted on Apr 04, 2009
  • 69 Answers
SOURCE: Whirlpool Quite Partner 1 making loud noise
whirlpool.com help
Posted on Sep 20, 2009
  • 64 Answers
SOURCE: how do i remove the upper spray arm on a whirlpool
There is a screw at bottom of arm. Try turning arm before taking screw out. I believe water pressure turns the arm, so if the arm doe not tur while machine is working then you either have a blockage from pump to arm or pump not working properly.
Posted on Aug 15, 2010
KevinWhite
  • 1902 Answers
SOURCE: What year was Whirlpool Quiet
Hello & Welcome to FixYa
Please get back to me with the serial# to know the age of this unit
Kevin
Posted on Mar 06, 2011
Daniel S
  • 4323 Answers
SOURCE: Whirlpool quiet partner I soap
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Posted on May 19, 2011
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Whirlpool quiet partner 1 is suddenly loud
Dear Sir : please see the diagram attached.
May 08, 2012 | Whirlpool Dishwashers
Whirlpool quiet partner I soap dispenser won't close
Hi
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool with loud screech
Most likely the transmission. A costly repair.
Oct 27, 2017 | Whirlpool Washing Machines
Whirlpool Quite Partner 1 - soap dispenser does not open during
I ran it through a couple of different cycles, when that didn't work I closed & opened it several times then rerun the cycle. It opened on its own. I can only assume it had some kind of build-up.
Jan 29, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Dec 05, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
43 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
