I have a Toshiba Satelite 1805-s253. When I turn it on, it attempts to start but then will immediately shut down with the power indicator flashing orange. I check the power supply and that is working ok.
Re: I have a Toshiba Satelite 1805-s253. When I turn it...
Power supply must b okay but the lead connecting laptop may have gone faulty, try changing it, if this is not the reason then some internal hardware problem
Hi, "first," restart the computer, and click on the "Start Button," in the (right pane) select to open the Computer. Check to see if there's a DVD RW Drive (D:) in the "Device: with (Removable Storage) area." If the area is (Blank)? Go to and select All Programs,scroll to find the Media Disk Player. You may need to Setup / Install the player, and "Update the Drivers," when the (install is completed) follow all the instructions. "Remember to always click on the Apply and OK buttons after making the changes, and lastly, restart the computer." "If the problem still exist, try going to the "Device Manager" from the Control Panel, [Roll-back, and or Update Drivers], restart the computer. Next, in a final attempt to fix the problem go back to the (Control Panel), and select from the "Update Options' "Let me Choose... To update the drivers Manually" this will in stall the "original" (Drivers) that came with the computer. "Rating the solution for its helpfulness is appreciated, thanks."
I just replaced my original CD/DVD ROM with a Toshiba SD-R2512 CD-RW/DVD ROM in my 1805-S253 running Windows ME. I used "Roxio Easy CD Creator" for writing to CD's. Everything was "plug'n'play" except the bezel that came with the new drive had to be swapped out. Windows ME recognized the new drive immediately and I didn't have to load any new drivers. This upgrade will probably work on other 1800 or 1805 Satellite series machines.
The RAM may need reseating or it maybe faulty.
If reseating the RAM module/s doesn't work and if you have two RAM modules, then try one at a time.
You could take the RAM to your friendly shop and get them tested or test them in another laptop.
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Not sure if you are up to this but if you remove the bios battery for a minute it will reset you may also be able to search for manual for laptop or you may have one
had same issue - on 1805-s253 - had to replace the inverter - there was a recall from Toshiba on that part for that series - you find sources for the part via a google of '1805-s253 inverter'
Open My computer, then My network places. Then open View network connections. Your connection should say "Local area connection". Right click it and make sure it's set to "Enabled". Then Right click it then select repair.
Does the machine boot to bios? If so, it could be the harddrive. If it won't even boot to bios, try changing or re-seating the memory. These models are a bit buggy.
