Question about Car Audio & Video
The red triangular light on my 1800 watt kenwood amp is flashing and i do not know what to do to fix it. no sound is coming out of my subs
    Sergeant:
    Champion:
  • 324 Answers
I have a smaller kenwood amp but it has the same triangle, i had that problem too, so i ran a ground wire from the battery to the amp, with 12 ga wire, and then i also grounded it with the chassis ground, on the big amps its better to have really good grounds and connections
Posted on Sep 12, 2010
I have a 1800 watt kenwood amplifier an the red light on it blinks when i turn my volume up but i have no sound coming out of my subs an it did this while driving today an all the wiring is fine so idk...
sounds like wiring. could be two much sub for the amp. your sub max power should be less than amp max. from your description its trying to go into protect mode. trace wires, cheking for breaks , loose connections and such. also make sure your fuses are in all the way.
Jan 13, 2011 | Car Audio & Video
Hey i just bought a new pioneer subs 2coils and a kenwood class d 1800 watt how can i connect them to get the clearest sound ?
That amp can run at 1 ohm so if your subs are dual 4ohm then run in parellel. All positives will be conected together and the negetives and then run to the amp.
-please give pos feedback david
Nov 09, 2010 | Pioneer Car Audio & Video
I have a 1800 watt amp but the red light is on but it dose sound like the bass works but not it its prime
the red light is for power in protect mode it should be orange and it will not emmit sound if you think you should have better sounding bass or more bass you can try to play with the gains on the amp or possibly if you have the negative or positive hooked up wrong from a speaker to the amp this will cause the bass to be lower and somewhat distorted double check your positive and negative wires from the speaker to the amp and make sure they are correct
Feb 28, 2010 | Kenwood KAC-9152D Car Audio Amplifier
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
I NEED TO KNOW HOW TO WIRE THREE 3012 THWELVES TO A 1800 WATT KENWOOD AMP
Its hard to tell what you can or cant do without knowing exactly which kenwood amp you are using. Generally speaking though most kenwood amps are stable only down to 2 ohms. you will be better off just using 2 of your 12s wired in parallel- that will give you a 2 ohm load. There is a way to use all 3 simply by wiring them in series, it will end up giving you a 12 ohm load on the amp though which will work fine but you wont ever achieve the full power that the amp can do.
Jan 17, 2010 | Kenwood Kfc-w3012 12" 2400 Watt Car Subs...
Repeated blown subs
Unfortunately some of these speakers today... DO NOT PERFORM up to peak as they should.The on logical reason for this to be happening it that the speakers are NOT very DURABLE and cannot take constant playing. I would recommend to L7 the can take alot more abuse than your average speakers. Good luck and thanks for using FIX YA
Mar 23, 2009 | Kenwood KAC-X401M Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
I need help
Most of the time if the red light is on the amp is no blown but some times it does this cause the subs are hooked up in the wrong way. If the amp is only 2ohm stable and you hook the subs up to it at 1 ohm than the amp will not work so I would check this frist.
Oct 17, 2008 | Kenwood KAC-9152D Car Audio Amplifier
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
176 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
