Question about Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker
One of the paddles froze after baking a bread. I was able to break it free but it is still stiff
  • 433 Answers
Sounds like the sealed bearing that the paddle shaft turns on is starting to fail. Fill the pan 1/2 way with warm water and soak for a few times to see it this helps. If not you should start looking for a new bread pan. Sorry Hank
Posted on Sep 14, 2010
Why does bread deflate?
See if the paddle shaft in the bottom of the pan is frozen. If it is, free it up manually. Then get it good and dry and oil it with cooking oil. After that, every time you bake, put the oil for the recipe in first and turn the paddle until it moves freely. Once the oil is in the bearing, it will keep the water out and the machine will move properly. I have gotten away with this fix for hundreds of loaves.
Jul 09, 2014 | Cuisinart CBK-200 Bread Maker
Can't remove kneading blade
If you baked bread in it and cannot get the paddle free, put enough water in the pan to cover the paddle and let it set for 5 or 10 min to soak the bread crust that formed between the shaft and the paddle. Then take a hold of the shaft on bottom of pan with hand or pliers to hold it still and try to work the paddle clockwise with other hand until it becomes unwedged from shaft. Sometimes it gets wedged on shaft pretty tight due to the beating against dough ball and cooked bread holds it tightly wedged.
Apr 06, 2014 | Sunbeam 5891 Bread Maker
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
I just bought your breadmaker B2200 and i am looking for recipes for a basic white and whole wheat bread.The booklet does not have basic recipes. I am looking forward to baking bread for a long time to...
Basic White
1 1/3 cups lukewarm water
2 tablespoons powdered milk
1 1/2 teaspoons salt
1 tablespoon sugar
2 tablespoons butter or margarine
3 3/4 cups white flour
1 teaspoon yeast
1. Measure ingredients in the order listed into Baking Pan.
2. Insert Baking Pan securely into unit; close lid.
3. Select BASIC setting and 2.0 lb. loaf setting. Choose LIGHT or DARK crust setting.
4. Push Start button. There will be a 15-minute preheat delay before mixing begins.
5. The Complete Signal will sound when bread is done.
6. Using pot holders, remove Baking Pan from the unit and carefully turn bread out of Baking Pan. (Mixing paddle may remain in bread. Remove paddle when load if cool.)
7. Allow to cool before slicing.
Time 3:50 hours
100% Whole Wheat
1 1/2 cups lukewarm water
2 tablespoons powered milk
2 tablespoons honey
2 tablespoons molasses
3 3/4 cups whole wheat flour
1 3/4 teaspoons yeast
2. Insert Baking Pan security into unit; close lid.
3. Select GRAIN setting and 1.5lb. loaf setting.
4. Push Start button. There will be a 25-minute preheat delay before mixing begins.
Time: 4.10 hours
Feb 19, 2011 | Black & Decker Bread Machine
First bread machine, one paddle would not spin, also black gunk accumulated under paddles - great customer service - bread machine replaced. 2nd bread machine, another malfunction - again, great customer...
Hi...The black gunk under the paddle seems to be caused by the sealed bearing located on the bottom of the bread pan. When this seal breaks the lubrication leaks out. It's a problem with the bread pan and not the machine. Seems the new machines cost more and are made with really cheap bread pans. I've had good luck with my Sunbeam and it's warranted for a year. Just my opinion....Hank
Jan 17, 2011 | Black & Decker B2300 Bread Machine
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
Kneading paddle is baked into bottom of bread loaf. Is this normal?
Yes, this is a common occurrence.
Nothing to worry about unless you chow down and forget to remove the paddle(s). :)
Since the paddle(s) stays in the pan after the kneading and through the baking process. The bread can trap the paddle(s) as the batter cooks.
We have gone through 3 different bread machines and over time all eventually did this. A little wear on the spindle will loosen the paddle(s).
Hope this helps!
Dec 26, 2009 | Sunbeam 5833 ExpressBake Bread Maker
Zojirushi bread maker, BBCC-15, Baking Pan,Paddle drive seal
Where can I get replacement parts for the BBCC-15? My keeper clip underneath the baking pan came off and is lost. It holds the wing clip that drives the kneeding blade in the pan.
Nov 22, 2008 | Zojirushi BBCC-X20 Home Bakery Supreme...
I want to smell home baked bread!
Before loading the pan with ingredients, try turning the paddle by hand.  If it's very stiff, perhaps soak in water for a while and see if that softens the hardened dough or flour around the base of the paddle.  That could be preventing smooth turning.
Jul 07, 2008 | Sunbeam 5833 ExpressBake Bread Maker
Blades stuck inside bread
Unfortunately trying to stick the paddles in the pan just tends to leave half the loaf in the bottom with them. The best method i have found is to cut the crust around the outside of the paddles, carefully avoiding the bit where the actual paddle blade is, then you insert a rod into the centre of the paddle and tilt it towards the blade. They normally come free pretty easily. Another method you can use if you are around the machine when it is making bread, is to remove the paddles at the end of the mixing/kneading cycle, just before the baking cycle starts. Most machines have a small pause allowing you to do this - sometimes with a "beep" or screen message to tell you that you can do this. Sorry i couldn't find the exact info for your model, it will vary for different baking programs also. If you check the cycle to determine at which stage it starts actually baking, then you can do this quite safely so long as you are careful of the machine heating up while you are removing the paddles - usually you would have around 20 minutes at least to remove the paddles before baking. Hope this helps :)
Apr 11, 2007 | Black & Decker B2000 Bread Maker
Zojirushi BBCC-X20 Home Bakery Supreme Bread Maker Logo
406 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
