Question about Casablanca Fan 4645M CAPISTRANO Brushed Nickel Ceiling
How do you remove glass dome from capistrano ceiling fan to replace bulbs. No button nut visible. Does dome trist off? Lower down with tension springs?
I can not remove the glass dome to change to bulb on my Minka Aire 3 blade ceiling fan. I believe the model number is UC7084T
Push up on the glass all around to loosen it (be careful not to break). You could also spray a little WD-40 around the top of the glass. If these don't work, you might have to break the glass. Call Minka Aire @ 1-800-307-3267 and let them know the problem and they might send a replacement at no-cost.
Jan 03, 2016 | Minka Aire Ceiling Fan
How do I uninstall a ceiling fan?
Turn the power off, to be safe i recommend turning it off at the breaker box, there should be a list on the onside of the panel door showing what switches operate what. or you can simply leave the wall switch that operates the fan in the off position if you're sure nobody will turn it on. If fan has a light remove the glass bowl over the bulbs, should be three screws it the top of the glass fixture, loosen them with your fingers, if they are to tighttry pushing up on the bowl from the bottom to relieve pressure off the finger screw. Remove light bulbs then unbolt each fan blade, once the blades are off remove the motor cover should be one small screw at top of the cover close to the ceiling, once the screw or screws are removed if the cover does not come down you may need toturn it using both hands, it only needs to turn a little bit and no need to be gentle. With the motor cover off the mounting bracket should be easy to spot. Some brackets only have one srcew on one end and a tad that slides into a slot on the upper bracket, by removing the one screw this will allow the motor assembly to swing down but still be attached to the bracket for support. Whith the motor hanging the wiring in the fixture box in the ceiling should be visible, pull the wires out of the box so ythat the wire nuts are accessible. there will bee three wires coming from the fan, one screwed directly to the box or bracket, loosen the screw with a screwdriver and pull the wire from the box, the other two wires attached to wires with wire nuts, one at a time remove the nuts by twisting them off with your fingers, pull the wires apart and twist the wire nut back onto the wires coming from the box in the ceiling, the fan should now be disconnected. romove the motor from the brack by turning it 90? and sliding the tab out of the slot in the upper bracket. remove the upper bracket piece from the fixture box. Now that you have done this installing a new light fixture should bea breeze for you.
the video shows a different easier type of fan removal. There are numerous types of fans and how they are mounted, i hope this helps you
Apr 09, 2014 | Dryers
How to change bulb on Casablanca fan 88U95M Scandia. There is no obvious way to remove the globe. Please help.
I believe there are four nuts that hold the decorative wood around the glass that has to be removed first. Then, you probably twist the glass off or loosen some screws. If that doesn't work then call Casablanca @ 1-800-715-0393
Dec 15, 2013 | Casablanca Fan (88U95M) Scandia Ceiling
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
I have a Hampton Bay ceiling fan/lamp where the lamp dome is apparently very tight into the housing. I pressed up and turned in the direction noted to remove the dome. The dome houseing came down and is...
Most light domes twist on or off or have thumb screws to loosen and lower the dome.It sounds like you removed the light kit assembly instead of the dome.Try to put back by twisting in place the light kit assembly and look for screws,or hold back on trim and turn just glass dome do not use too much force .I checked web site but can't find your model.It is unusual to not be able to just remove glass dome.Look closely at how the glass dome is positioned. If no screws are visible either the glass part unscrews or the ring unscrews allowing glass dome to be removed.Good Luck.I have installed many ceiling fans the problem is if you didn't install it your at a disadvantage.GOOD LUCK.
Jan 04, 2011 | Heating & Cooling
How do i remove the glass in order to replace the bulb
Place hand firmly over the glass dome and apply firm pressure and turn the glass dome in a counter clockwise direction.
Jun 20, 2010 | Monte Carlo 5DI52WHD Discus White Ceiling...
Closet ceiling light, simple dome and metal ring,
Hello. There is always a way to remove the dome. If there is a metal nipple in the center of the dome, it will unscrew. Otherwise, the entire glass dome will unscrew. Regards, Joe
Jan 09, 2010 | Dryers
How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
  1. push it up and turn (like when you open a medicine bottle.
  2. try to look for a spring action peg that clicks in automatically around the glass dome that might be locking it...
please comment my solution :) thanks
May 31, 2009 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Mar 30, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Casablanca Fan 4645M CAPISTRANO Brushed Nickel Ceiling Logo
111 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
