Question about Vacuums
Vacuum Philips vision Plus Squeal from seal joinining hose to cleaner. Are there replacement seals available/ How do I order one? rodwid@actrix.co.nz
    President:
  • 2,047 Answers
Yes there are replacement seals available. check www.trademe.co.nz ...if you dont get some there contact me for further assistance.
Hope this solution has been helpful?
Posted on Sep 12, 2010
Need an Electrolux agent in Alberton, SA. Need rubber seal for my vacume cleaner
picture is of the v cleaner unit with that model number
cant find a listing that hose seal as such
the hose with the seal as a whole.. is now discontinued
try looking for a used unit or improvise
Jun 18, 2016 | Electrolux Vacuums
How do I restore airflow through floor intake?
Hi Alan, it's Jack at Dyson.
Thanks for the comprehensive information on the issue you're having with your DC25. It sounds very unusual, because if you're getting strong suction through the airway you've labeled in your photograph, there should be nothing stopping the airflow reaching the cleaner head.
It's very important to understand that in order to work effectively, the cleaner head's soleplate must form a close seal with the floor surface. I'm not sure how you're testing suction through the cleaner head, but just placing a hand underneath the soleplate is not an effective way of testing the suction as the soleplate will not be sealed. Therefore the level of suction will feel very different, compared to placing a hand right over the end of the hose.
From what you've described it does sound like your vacuum is working as normal. However for additional assistance, please my colleagues at the Dyson US Support team at askdysonUS@dyson.com - if you can include your serial number and full contact details, we'll be in touch as soon as possible.
Aug 08, 2014 | Dyson DC25 Bagless Upright Vacuum
Squealing noise from the top
Take the HEPA filter out of the ball. Run the machine without it and see if it quits. My guess is that it will. You can get some scissors and cut the rubber seal off the filter and re-install it and you squeal is gone.
Aug 08, 2017 | Dyson DC25 All Floors Bagless Upright...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My vacmaster pro 90 is not vacuuming
please test if the :a) hose is clogged b) bag/tank clogged or full you need replace or emptied
2) test the belt for broken or wonr, and replace.
God bless you
Jul 13, 2012 | Vacmaster Pro 90 Vacuum Sealer
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
Cant get any water to floor or hand dispenser on my bissell power pro steam cleaner
That means that the pump belt is worn or stretched and needs to be replaced. Here is a link to the belt you need and the manual which has instructions:
Bissell ProHeat Belt and Manual
Dec 12, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Melts the bag and won't seal
if your vacuum cleaner gets hot enough to melt it's own parts, i think you have a problem. exesive heat could indicate a serious problem and might also cause a fire. try having it checked by a repair shop because replacing the seal and continuing to use it might be dangerous.
Mar 30, 2008 | Vacuums
Suction problem
sounds like you have a leak in the suction path
look for a broken hose or seal
May 21, 2007 | Dirt Devil M086700 Vision Bagless Upright...
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
