Question about Sony Playstation 3 (PS3) Console
Wont eject discs or power up. beeps 3 times and red light constantly flashes
    President:
  • 2,923 Answers
Your PS3 is overheating. You may check the link below:
http://www.ylod.org/how-to-fix-PS3-three-beeps.php
Or if not, you may send it to the authorized repair shop and have them fix it.
Thank you!
Posted on Sep 12, 2010
Red light blinks and wont stay on when push power button
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
When turning on my console it wont fire up or eject the disc that is in the machine the Standby light flashes, beeps and then nothing ?
Maybe you have the "yellow light of dead"
You should let it repair, your console is broken.
try putting it in recovery modeHow to Access Playstation Recovery Menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
Flashing red light will not eject game
if you turn it on, and it goes green then yellow then beeps 3 times and flashes red, then your ps3 has overheated and been damaged. you can fix it with the heat gun trick, http://www.youtube.com/watch?v=4_Ic1_TY-GU
but it will only break again.
try flipping the switch in the back, then hold the eject button while you flip the switch back on, that should eject the disc.
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
SYSTEM DOES NOT TURN ON. FLASHES, SHUTS OFF, NO EJECT
Unfortunately, you are going to need to have your PS3 serviced by Sony. To eject your game, flip the power switch on the back of the PS3 to off. Then press and hold the eject button and turn the switch back to on again. This should eject the disc. Best of luck with the repair.
Jul 27, 2010 | Sony Playstation 3 (PS3) Console
Disc will not eject
Disc stuck is not a big issue. Don't waste money to find someone to fix it yet! It may be a minor issue that you can be fixed by yourself.
Remember, you are not the only one to suffer this problem! Because I had help so many people to fix the same problem now. You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the same problems after bought this guide. The author of the book is really kind and helpful to his customers. May be you can buy it and share what you have learned !
PS3 Repair Guide
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
I turned my ps3 on today and the light turned green, then amber and red and the system beeps three times. the red light then just keeps flashing. When i tap it while its blinking it stops but when i do...
i have the same problem but to make matters worse mine wont even turn on now but a bunch of people say you have to take it to sony or i dont know if this works but a bunch of people say is does try turning it on or off (i dont know which one) and press the eject and front power button at the same time hope this works tell me if it does
May 07, 2010 | Sony Playstation 3 (PS3) Console
My ps3 won't load the discs...
Hi, if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Thanks and take
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
Disc wont eject red mains light flashing
Turn off your PS3 entirely. Then, flip the backswitch and Eject button at the same time. The cooling fans will start to blow at max capacity to blow out all the interior dust. even ejects discs
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
My PS3 wont turn on it just flashes a yellow light then red light that beeps cant get disc out
I found a way to eject the disk:
  1. Power off the PS3 on the main switch on the back of the console
  2. Press and hold the Eject button
  3. Turn on the main power switch
  4. The PS3 LED will go green and the fan will spin at max speed
  5. Wait a few seconds and press the eject button a couple of times, the disk should now eject
  6. watch the PS3 die after 30s or so…
This procedure did not fix my PS3 but at least I got my disk back before sending it to Sony for repair.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
142 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
