Question about Amana AFD2535DES French Door Refrigerator
The refrigerator door makes a "click" when I open and close it. I can't tell what is doing it or whether something should be replaced or adjusted. Bill Ruddy
  • 1,338 Answers
TRY CLEANING AROUN THE LIGHT SWITCH AND YOU COULD TRY A LIGHT COAT OF ARMOR ALL ON THE GASKET
IF I WAS OF HELP PLEASE TELL ME.. BUY PRODUSTS MADE IN THE GOOD OLD USA.. THANKS Jay
Posted on Sep 12, 2010
When I close my side by side refrigerator it makes
Side by side doors have a door closing cam to make sure the doors close. These cams wear out. the door will have to be removed to replace the cam assembly.
Sep 25, 2014 | Refrigerators
Freezer Door
There is usually some adjustment on the hinges. Your is termed buttbound, the door at the hinges is too close so it makes the door pop open. Take everything out of the inside door shelves if there are any. Slacken the mounting screws a little and pull the door away from the frame, make sure it sites square and tight, and then tighten up the mounting screws. With a freezer, i would also suggest fully defrosting it first.
Mar 15, 2017 | Refrigerators
Refrigerator door will not stay closed
HI MANDY.normally the gasket dont go.it's rare.i would think u'll need to check the bottom door bush.parts difficult to get.u'll probably need to get a MANMADE ONE.good luck ali
Jul 12, 2012 | LG LSC26905TT Side by Side Refrigerator
The freezer door opens if the refrigerator door is closed hard
this is quite normal on a lot of fridges ! if it isnt closing again by its self you need to re-level the fridge and have it very slightly backwards . alternatively the fridge is not level side to side !. open the main door a third to halfway open and let it go, it should close under its own weight, if not adjust up on the hinged side leg or down on the opposite side , if the front legs are not not adjustable pull it out and adjust the back legs , a quick fix, is to chock up the front leg and all will be ok ,regards terry ps, clean the seals and the fridge where the seals make contact the seals probably do not need replacing unless the fridge is very very old. a lot of people replace seals when its not needed. regs terry
May 17, 2011 | Frigidaire Refrigerators
Refrigoator door does not vacuum seal tight like it used to when new. Door barely stays closed on gasket.
What I hears sounds as if the refrigerator needs re-leveling. Here are some basic things to do as in this video. Every refrigerator is not always the same but the idea is to cause the doors to shut inward if you should be standing in the front and let both doors loose from your hands the doors should shut inward and firmly if not over adjusted in the final steps. Your model is a nice large model! Here is what one user manual mentioned below.
NOTE: Custom or full-overlay door panels must be installed
before leveling.
1. Open the door and place the level on top of the refrigerator
frame as shown. Check to see whether the refrigerator is level
from left to right.
2. Use the leveling bolts to adjust the leveling legs until the
refrigerator is level from left to right.
3. Place the level(s) on shelf or shelves. Check to see whether
the refrigerator is level from front to back.
4. Use the leveling bolts to adjust the leveling legs until the
5. Be sure that all four leveling legs contact the floor and
support the full weight of the refrigerator.
6. Make final check to ensure the refrigerator is level.
Adjust Door Swing
1. Check that the refrigerator door can open freely. If the door
opens too wide or you are installing full-overlay custom
panels using a Trimless Trim Kit, you should adjust the door
swing.
2. Remove the door stop screw from the bottom hinge.
3. Hold the door open to a position that is less than 90°.
4. Replace the door stop screw in the bottom hinge and tighten.
NOTE: If you are using full-overlay custom panels with the
Trimless Trim Kit, the door stop should be replaced in either
the 90° or 110° position. See "Handle and Door Clearances
for Custom Panel Series."
Install Side Panel
If the built-in area depth is 25" (63.5 cm) or more, the side panels
can be installed inside the side trim or attached to the outside of
the side trim.
IMPORTANT: Thermador is not responsible for the removal or
addition of molding or decorative panels that would not allow
access to the refrigerator for service.
1. For the inside side trim piece, slide the front edge of the
routed side panel into the trim piece.
2. Nail the rear edge of the panel to the support board.
A. Level to check left to right leveling
B. Level to check front to back leveling
A. Rear leveling bolt
B. Front leveling bolt
A. Door Stop in 130° position
B. 110° position
C. 90° position
AB
AB
Thanks, Sea Breeze
How To Level Refrigerator Doors
Apr 21, 2011 | Thermador KBUIT4870A
Gbs20hbsww bottom freezer the freezer gos below 0 but the upper refrigerator stays at 60 I replaced the evaporator fan motor but it will only make 1/4" turns the damper door makes a clicking...
check the damper control on the freezer the refrigerator section gets it's cold air from the freezer sometimes the air damper needs adjusting or replaced
Nov 17, 2010 | GE GBS20HBSWW 30" 19.5 Cu. Ft....
The refrigerator door (not the freezer door) does not close.
Is it closing flush when pushed up or is it not making good contact all around? 2 things can be wrong, the surround needs to be cleaned on the door and fridge and if it still doesn' stick you will need to replace. You can adjust the door slightly at the hinges but only if its loose should you need to. If its tight then it has not shifted and i would focus on the surround clening/replacing first
Oct 02, 2009 | Samsung RS2630SH Side by Side Refrigerator
How to tell whether logic board or rpm sensor is bad
Don't replace anything yet. This is a fairly common problem as the door travel limits go out of adjustment after awhile. On the side of the motor unit you will find the 'up limit' adjustment. Turn this about 2 turns in the opposite direction of the arrow printed on the cover. Make sure you put the wires back on the motor correctly.
Sep 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you adjust the doors to closed completely?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 03, 2009 | GE GSH22JFR Side by Side Refrigerator
The refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Nov 12, 2008 | Refrigerators
Amana AFD2535DES French Door Refrigerator Logo
288 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
