Question about Panasonic sa-ht930 Home Theater Audio System SA-HT930 System
My panasonic sa ht940 is coming up with the fault h01 and it shuts off how do I fix it
appman67
  • 33 Answers
SOURCE: f61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Posted on Sep 21, 2008
  • 4234 Answers
SOURCE: Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
Posted on May 15, 2008
olhonda
SOURCE: Panasonic home theater SA-HT940
I have an SA-PT960 that came up with the same error.
I unplugged it and plugged it back in after 30 seconds.
Seemed to solve the problem.
Posted on Jul 25, 2008
VOTIT
  • 2071 Answers
SOURCE: panasonic sa ht990 fault 61
This a memory problem ,try to look for the reset button and press it . If you can't find the reset button then the other option is unplug the unit for 24 hours the purpose is to dessipate or drain the charged current .
Hope it may help you;
Regards;
VOTIT
Posted on Jan 07, 2009
  • 75 Answers
SOURCE: Panasonic SA-HT940 error F61
Ic STk 470-040 is blown.
Posted on Aug 23, 2010
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
Panasonic SA-HT940 with error code DVD F750. Does anyone know what this code means
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
Dec 23, 2011 | Panasonic Audio Players & Recorders
Panasonic VCR model number NV-HD640B comes up with fault code H01 - what is this and how do I fix it?
You have a Panasonic K Deck Mechanism, you can search for more free info on it via Google. Meanwhile H01 means no drum motor or drive, it's to do with the main VCR head not going around.
Dec 04, 2010 | Panasonic NV-HD680 VCR
Panasonic SA-HT940
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
the best thing you do is set the region to ply coz some of the dvd player need to set the region
Mar 24, 2008 | Panasonic 600W DVD+VCR Home Theater System...
202 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
