Question about Baby Jogger 2 Stroller
Just bought a used one in good shape. The seller didn't tell me that the device to hold the front wheel on was missing, so I don't have that and I don't know where to get it. Also, one of the tubes is bad. Where do I get a new one?
Do you mean the skewer? If so you need to take the wheel into a good cycle shop and ask for a quick release skewer. They should also be able to help with tubes.
Posted on Oct 06, 2010
How do you replace the front breaks on a 1992 ford f250 custom??
take off the wheels one or two at a time,un-pin the middle swivel device that the rim slides over,if there is none then just pull the rim off.Now on the caliper is a retractable pin that is triangle shaped about 3-4 inches long.This pin is what holds the caliper and the pad together!Also dont forget to remove the bolts that hold the calipers in place!Now you should be good,whatever you do,don't remove the brake lines!Good luck,hope this helps!-CB
Dec 20, 2011 | 1992 Ford F250
Need rear wheel for an RST 1000 Aprilia refuses to help, and won't even tell me where the original was manufactured ( they didn't make it for sure). Have been trying to source this part for...
Hi.
You can purchase the wheel here. If you do not live in UK call them to arrange overseas delivery, the part distributors ships worldwide.
Depending on the color the wheel is p.n. AP8108821 or p.n. AP8108965 . You can find more sellers using the part number in Google.
Below also the part diagram. The wheel is part nr.4:
Regards.
Ginko
Aug 19, 2011 | 2004 Aprilia RST 1000 Futura
How are you doing? I have a Whirlpool electric dryer that is not heating. I located the problem in the thermostat and bought a new one but realized when I got home that it didn't have a jumper...
Can you take the jumper off the old part? Or you can take the new one back to the seller and tell them you need the jumper that goes with it.
Jun 30, 2011 | Dryers
Need torque settings for front wheel bearing axle nut
Unless someone else can give you the
correct answer,because we are at home
on the internet as you are. This is not
a data base or business for the most part
I will tell you that the torque will be very close to your
average 1/2" 150# torque wrench
So it won't do you much good,it will be max out
I actually bought a 3/4" drive ratchet & a 40 " bar so
I didn't need a pipe on my tools & ruin them
You will need from 105 to as much as 180
Sorry I don't have the data
Don't use an air gun
That is what ruins new brgs & what the pros use
(go figure,as they say)
May 26, 2011 | Chevrolet Malibu Cars & Trucks
Bought a TRAVEL-MATE SAT NAV on EBAY--Instruction book missing.
Hi Michael
You could try this website ( based in china ) to see if you can get those items but would suggest if the seller isnt willing to help raise a dispute not only on EBaay but also Paypal ( assuming you used paypal to pay for it) Pay pal will reduce his acount abilities as in he will only be able to accept money and not be able to withdraw it or spend it anywhere else until the despute is resolved.
cheers n Beers
Nick G3VCP/ VK4ADQ
Jul 24, 2010 | GPS
Bought this used in good shape cant get the grll to go down and looking for manual
As far as how to lower: Step (and hold down) the foot pedal, while holding the pedal down, push the grill down evenly on both sides at the same time. Let off the pedal when the grill is all the way down. I have two of these grills and love them. One will not stay down and I am working through that now. I'll post if I figure out the adjustment. Happy grilling, Don
Apr 23, 2010 | Thermos Grill2Go Fire+Ice
2000 ford expedition xlt, 2WD. anti lock brake indicator on. fluid ok, brake disk look ok. disconnected battery, still comes on. lines to both front wheels and rear look in good shape , appears the front...
YOU WILL NEED TO HAVE ABS DIAGNOSED. IT IS MORE THAN LIKELY AN ELECTRICAL FAULT OR COMM PROBLEM. POSSIBLY ECU OR A SPEED SENSOR. MOST COMMON TRY TO REPLACE DIFFERENTIAL MOUNTED SENSOR ON REAR DIFFERENTIAL, MOUNTED RIGHT ON TOP OF DIFFERENTIAL,CAN'T MISS IT HAS WIRE GOINF TO TOP OF DIFF AND HAS 10MM BOLT HOLDING IT IN.
Jul 11, 2009 | 1999 Ford Expedition
Stuck in 4 wheel high lock
I had the same problem just yesterday. My shifter lever for the 4x was just flopping around. I crawled under the driver side right behind the driver front tire and there was a lever hanging down with an "L" shape on the end of it and a groove cut all the way around it. That lever is the end of that shifter lever inside of your vehicle. it attaches to another lever "a flat bar with a hole drilled into it and mounted to the side of the transmission. Don't attempt to move the flat bar but do reposition the lever inside the vehicle so that you can put the "L" shaped lever back into the hole of the flat bar. There is supposed to be what they call an "E" ring on the end of this "L" shaped lever that slips over the shaft in that Groove I was telling about. it snaps into place and holds the two levers together. It's missing so go to auto parts store and get a new one. I'm headed there today. Shift your car into 2wd and drive. Then replace the "E" ring that's missing and you're good to go.
Good luck
Apr 29, 2009 | 2000 Dodge Durango
Quinny 3 wheel
From the associated pictures, it appears the front wheel does NOT swivel. Generally jogger strollers do not have a front swivaling wheel because it may cause the stroller to flip while jogging. Jeep makes a stroller that has a front swival with a locking device on the front wheel, they also have these with a built in speaker system to attach mp3, cd players to. Sorry I couldnt be of more help. If you wantn to email me an actual photo of your stroller I will take a closer look and determine if it can swival. Just let me know on here.
Jan 24, 2008 | Quinny Freestyle 3 XL Dusk Jogger
Baby Jogger 2 Stroller Logo
277 people viewed this question
Top Baby Jogger Baby Gear Experts
Lyle Siemens
Lyle Siemens
john h
Are you a Baby Jogger Baby Gear Expert? Answer questions, earn points and help others
