Question about Polder Triple Digital Timer Model 891-90
Cannot figure out how to use the product. For example, setting the timer for 10 minutes. Where can I locate a owners manual
Timer is not identified for certain.
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Typical manual with countdown feature:
http://polder.com.p2.hostingprod.com/images/instructions/898_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Aug 28, 2011
Owners Manual appears silent on two questions.
1) Question posted under Jasco GE timers.Timer is otherwise not identified as type, model or brand.Certainly this information shows on product manual.
2) Copy following link to help identify timer and download possible manual:http://waterheatertimer.org/GE-timers-and-manuals.html
3) Upward operational temperature for digital timers usually ranges 120-155 F. So this should not be issue in garage until global warming eliminates all electronic gadgets, batteries, and seriously affects electric transmission lines from power plant.
4) Downward operational temperature for digital timers vary widely by type and model number of timer.Some become unreliable at freezing. Some last 1 month in freezing. Some are rated to zero F. Some rated minus 10-40 F.
5) Smart plan is analog timer instead of digital timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#applianceThis type timer will operate on electric power, and not be affected by temperature fluctuations. However timing is not down-to-the-minute 7-day as with digital timers.Note appliance watt rating before buying timer.
6) Two-outlet plug-in timers are not 2-channel timers or 2 circuit.2-channel timer means that the timer can be programmed for two separate timing programs, with each timer program controlling separate load with separate schedule for each load.
7) Example 2-channel timer: Intermatic 1125 digital timer.Note operating temperature -40F to +155, making this especially hardened timer, with wide range timing applications excluding delay functions, But with 1 year limited warranty as is typical with most timers.
http://waterheatertimer.org/pdf/024_ET1100-sell-sheet.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 05, 2012 | Jasco 15079 SevenDay TwoOutlet Digital...
My timer is set to shut off at a certain time of day, and I want to turn the timer off, but I can't figure out how to do it. Can you send instructions on how to turn the timer off?
Honeywell product is not identified.
More information is needed to identify product. Add a comment with as much information as possible, to help expert locate correct information.
For example Honeywell makes timer controls for boiler and heat-ac units.
Honeywell also makes Aube brand wall and box timers for lights and pumps.
http://waterheatertimer.org/Aube-timers.html
Honeywell has a contact-us page:
https://honeywell.com/Pages/contact-us.aspx
Aug 30, 2011 | Honeywell 24-hour Timer Control 120v Spdt...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Grasslin FM1D20A 120 PLEASE....I need a full programming manual on this unit. It was installed in a brand new Engineered Air rooftop air cycling unit last fall and it is a nightmare to program. It...
FM1D single-channel timer is difficult to program.
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#GM40AVE
http://waterheatertimer.org/pdf/fmd-20-setpoint-programming-guide.pdf
Timer flowchart starts page 3.
First step is to select format and then set current time.
Format is asking if you want 24hour or 12 hour format:
12 hour is am and pm
24 hour is military time where 11pm at night is hour 23.
Current time is simply the time right now.
Next step is to set program 1 thru 20 (P01 P02 thru P20)
Start by pushing +/- until desired program displays
Each program is set for either ON or OFF.
There are 20 memories available: 10 ON and 10 OFF.
Not necessary to use all 20 memories.
You need to set at least 1 ON time and 1 OFF time.
Make chart of on-off schedule to avoid conflicts in programming: For example ON at 7am Monday and OFF at 9am all-days-of-week will cause timer not to function as expected.
Each ON time is set for hour, minute and day.
Each OFF time is set for hour, minute and day
Press menu to terminate programming.
Add a comment for specific help with this timer.
Jul 26, 2011 | Hardware & Accessories
The manual timer in the picture has 120 minutes on it . the discription says it's a 240 minute timer. what is it?
Timer is not identified.
Add a comment with in-focus photo of timer posted on flickr, or describe all details about the timer for possible help.
240 minute timer could be a cycle timer that repeats timing cycle each 4 hours.
Tork 8000 series cycle timers have 6 minute to 1 hour
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
Intermatic cycle timers range from 10 minutes to 4 hours
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/specialty%20time%20switches/c8800%20short%20range%20cycle%20timers.aspx
Adjustable cycle timers, percentage cycle timers have variable time settings that span 1 to 24 hours.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#JW
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=cycle+timer&op=search&Ntt=cycle+timer&N=0&sst=subset
Jul 18, 2011 | Hardware & Accessories
I require ain instruction manual for a delonghi DMX30 microwave
Hard to find, but does this information help you :-
Setting the clock
1. press the clock button
2. press the cancel button
3. press the 1 and 10 minutes buttons repeatedly to set the hour, for example to set to 11 press the 10 minutes button once and the 1 minute button once.
4. press 1 and 10 seconds buttons repeatedly to set the minutes. For example to set to 29 press the 10 second button twice then the 1 second button 9 times.
5. press the clock button again
Feb 24, 2011 | Casdon Delonghi Microwave - Boxed ()
How do i programm 735 t6 timer prince castle timers
A search of prince channel site for 735 timer sent me to the 740 timer >> their other models wer 755 and 840
Here's the prince castle page:
http://www.princecastle.com/products/timers_740series_single-display.asp
Here's the 2 instruction guides:
740 horizontal
740 vertical
The timer is a multi-channel countdown timer which means it can control multiple electrical devices separate from each other
Set the french fry cooker to tun on for 5 minutes
Set the dryer to come on for 10 minutes
Set the blower to come on for 1 hour
Set each item for different lengths of time
The item with least amount of time left shows on the screen
To program timer
Press and hold Prince Castle logo for six seconds
Time displays will change from " ----" to "PROG"
Press timer channel to be programmed
LED indicator light will turn yellow and beep will sound
Current programmed time will display (for example it might show 5 minutes 20 seconds)
Time value will indicate either H:M (hours-minutes) or M:S (minutes-second)
Press SCAN/UP arrow or SCAN/DOWN arrow to change program time
These arrows are located next to Prince Castle logo
If you want H:M instead of M:S, then press and hold SCAN/UP button
When display reaches 59:59 it will automatically change to 1:00 Hour
LED indicator light switches from M:S to H:M
Now you programmed first channel, click next channel and repeat steps above
To FINISH programming, press Prince Castle logo for a moment, and programs are saved
Oct 08, 2010 | Prince Castle 740T2 2Channel Single...
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 30, 2009 | Kitchen Appliances - Others
Polder Triple Digital Timer Model 891-90 Logo
57 people viewed this question
Top Polder Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Polder Hardware and Accessory Expert? Answer questions, earn points and help others
