Question about Garden
I was wondering if there are step by step instructions available for brush replacement on my cordless Milwaukee skill saw 6310
  • 1,358 Answers
Ya man check this out clickme . looks like a real fun one, better you than me !
hey if this was of help please tell me so i know i did ya good ?>
remember to buy products made in the good old USA.. THANKS Jay
Posted on Sep 12, 2010
Testimonial: "Thank you, I found this extremenly helpful."
12" Milwaukee. Why does it lose power after it has been run for awhile?
Assuming there isn't some other mechanical problem or the saw isn't being overloaded, most circular saws have motor brushes that can wear out after extended use. These brushes are usually replaceable. When the brushes are worn, they will not deliver sufficient power from the motor stator to the armature (the part that rotates).
Here is a link to a parts supplier. Find your model number and look for brushes.
http://www.ereplacementparts.com/milwaukee-circular-saw-parts-c-131_5128.html
Aug 29, 2015 | Saws
Does 6509-31 sawzall have thermal overloads
No the 6509 does not have a thermal overload.
Start by checking the brushes & brush springs then test the switch & cord
It is possible you burnt the armature out but brushes, switch, or cord is more likely.
Mar 07, 2015 | MILWAUKEE ELECTRIC TOOL CORP Milwaukee...
9200 skill resipro-saw won't run after sitting over the winter
Did it sit outside in the garage? You wouldn't work very well after freezing outside all winter, either.
May 23, 2014 | Milwaukee Tool Milwaukee 6514 20 18V...
My M18 cordless drill overheated and smoke came pouring out
Yes this does have brushes, they are mounted on plastic plate that has to be soldered onto the switch. That noise might be the vanes that have broken off the main rotor. If you open it up you will be able to see. Yes they can be repaired but check with the milwaukee agent for cost. Some times it is more cost effective to buy a body only. Brush card is cheap about nine pound inc vat.
Jun 03, 2012 | Milwaukee Tool Drills
How do I dissassemble the milwaukee model 6266 jigsaw so I can replace the brushes?
unplug tool and there is a screw on the back side that has to be removed. After pulling the cover back you will see the brush springs and brushes. Gently lift the springs so that you can remove/replace the brushes and make sure to replace it on top or it will not work. When finished push the cover back up and reinstall the screw.
Jun 25, 2011 | Milwaukee Tool Saws
Cordless Sawzall #6515-20. Cutting with it and it just stopped. Changed battery no go. tried moving the blade manually and it moved slowly a little and that was it. Took apart and tested the switch with a...
the field unless dropped is a permanent magnet and WON"T fail. I would look at the contacts from the battery to the saw. This battery has a sometimes problem with heating up and makes contact difficult. you can usually see where the housing is distorted in the contact area. if you have tested the switch and sounds like you know how to use the meter check the continuity/resistance across the brush leads and while doing this turn the armature slowly to check for open portions of the commutator. if all good there then your power supply is the area of concern. Let me know if I can help anymore. And did you call the 1-800-sawdust number.
Apr 12, 2011 | Milwaukee Tool Milwaukee Cordless Sawzall...
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
How to replace the brushes on the milwaukee cordless drill 1/2'' # 0627?
Depending on age of tool older models did not have replaceable brushes. Change motor.
Newer models are replaceable , go to a service center and get a brush kit for this model. Or online.
Open tool with # 8 torx. Do not separate motor and gear case ,chuck remove as one unit. Brushes are solder in .De solder used brushes . Replace one side at a time. These kits come with new coil tension springs .
Jul 07, 2009 | Milwaukee 0627 24 Drill Hammer 18V T...
18 volt milwaukee batteries
You could try another battery if you have on(they only last for so many charges) or your charger could be bad. Try plugging it in to another outlet. Good Luck
Oct 15, 2008 | Milwaukee 6310 22 18 Volt 6 1/2 In....
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
