Question about Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher
Elextrolux dishlex DX 302 - not cleaning dishes properly and dishes still wet after drying
  • Electrolux Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on May 14, 2011
Dx 302 wont dry dishes
The model you specified is unknown to me and I'll try to explain how drying works generally in the dishwasher.
Dishes absorbs heat and cools more slowly than a very thin wall of stainless steel.
The consequence is that water evaporates and in accordance with the Mollier diagram begins to condense on the walls of the stainless steel whose temperature is lower due to faster cooling of the dishes.
Now drying can be divided into two categories. Active and passive.
Passive way of drying the natural circulation of moist air and condensation in the condenser, which is usually located on the left or right side of the dishwasher.
Active way of drying works on the principle of forced circulation humid air with fun helping quickly condenses and thus speeds up the drying of dishes.
In passive mode the drying process can speed up the partial opening of the door.
Dado
Aug 08, 2014 | Electrolux Dishwashers
Dishes still wet upon end of cycle
Check if the heater is working. This can be done by checking if the dishwasher has steam and dishes are warm when cycle is complete. Also check if the Rinse aid has not finished. Make sure the Rinse aid dosage is not at too low.
Jul 31, 2014 | Electrolux Dishwashers
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
Dishlex 302 model is displating "i30" error which
Try and remove power for few hours so that the processor resets, check if there is fault in the door switch as the error had come in, check for good pressure at the inlet, and possibility of any fault in the pump. It is best to take a full view of the functioning of the units to ensure that there are no errrors that feed back. Clean and reset.
Sep 29, 2011 | Dishwashers
Not drying dishes
The fact that it does not work on all three settings suggests it's something common to all three. Sounds like perhaps your immersion heater is bad or even worse, some contacts or relay in the control circuitry of the drying cycle. To check the immersion heater will require you to pull out the washer from under the counter & to remove power from the appliance. Looking underneath the unit, remove a power lead from one side of the heater unit. Next, turn a volt/ohm meter to the highest ohms setting, turn it on, and touch the two leads together to make sure it's working. It should show zero no matter what ohms setting you have selected. Next touch each lead to each of two posts on the heater unit. It should show some resistance other than zero if it is good. If still zero, you will need to get a replacement heater from your fav local appliance store or go on-line and order it. Either way, make sure they have the full identification of your washer make/model. Let me know results?
Jan 02, 2010 | Dishwashers
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
Dishlex dx 403 does not dry dishes - fan dry on red led
Ther have been a lot of complaints about the drying performance of these machines. One solution suggested by Electrolux is to use the "anti bacterial" wash mode, as this is a higher temperature wash, therefore dishes dry better. If you are using Eco wash or Quick wash, drying performance is not very good- Electrolux recommend leaving door ajar at end of cycle to improve drying. Also, ensure your Rinse Aid compartment is topped up, as Rinse Aid greatly improves drying performance.
-Please note: these dishwashers will not dry plastics and other items that do not hold the heat very well!!
-Also, you should be able to hear the drying fan running at the end of cycle- if not, then you may have faulty fan (uncommon), or control board (more common).
Good luck!!
Aug 12, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Electrolux 24 in. EDW5500DSS Stainless Steel Built-in Dishwasher Logo
351 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
