Question about Whirlpool Duet GHW9150P Front Load Washer
What does it mean when it says f 35 and what do we need to do?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
Train left front tire
you need to check tire pressure, spec is in drivers door jam. usually 35 psi. once tires are checked and good drive vehicle over 35 mph and light should go out unless theres a hard fault then you would want to take to a dealership.
Apr 01, 2014 | 2013 Ford Ford Focus ST
I need to find the mean of 6 6 11 and 12 and i don't now what to divide by.
Mean=Average =(Sum of data values)/(number of data in set)
Sum of data values =6+6+11+12=35
Number of data =4
Average =Mean =35/4=8.75
Mar 13, 2014 | Office Equipment & Supplies
Find 100 percent of 35
Percent means "per hundred" so 100% is 100 per hundred. 100% of anything is all of that thing, so 100% of 35 is 35.
Jun 06, 2013 | Air Purifiers
Engine codes for a 1998 plymouth voyager
okay, 1998 voyager these are not obd2 codes, these are genric codes, you used ignition to get these .
these codes are for older models that use codes like these 12 35.
the newwer obd 2 use codes like po 013. i will try to see what i can find, also the engine size is important.
okay here we go, the first code is 12, this code means the battery was dead or dissconnected.
the next code 35. this code means loss of prime, code # 11
means internal transmission failure.
the code 55 means gear ratio error.
these codes would tell me that you have transmission problems. this may mean internal trans failure and a rebuild or replacement transmission is needed or shift pack needs replacing. anyhow i would have a shop check this out, these van are known for transmission problems. hope this is helpful good day
Feb 03, 2013 | Plymouth Voyager Cars & Trucks
I have a 35 gal tank. i need to add a solution to it. the solution calls for a 1 part solution to 100 parts water ratio. how much solution do i add to 35 gal
The solution you have should be more specific with units but I don't believe the units will matter. 1 part solution to 100 parts water, would mean to me that if you have 100 gallons of water you would add 1 gallon of solution...but you don't have 100 gallons you have 35, so take 1/100th of 35 and that gives you .35 parts solution. Adding just between a quarter and a half of a gallon (closer to the half) will be perfect for your amount of water.
Jul 12, 2010 | General Electric GE SmartWater Household...
Bad print head replace magenta (square) what does his mean. Does this stop all communication with the printer
It means that you need to replace the Magenta printhead which goes for about $35. To see what I mean, go to: www.superwarehouse.com/HP_14_Magenta_Printhead/C4922A/p/55741
Each #14 printhead is made to last about 3-4 years or 30,000 prints. But since this is a 5+ year old printer, you will most likely start to need the other three printhead too, and at $35 each ($140 total), you might as well by a new printer. The current model that replaced this one is the HP OfficeJet 6500, MSRP of $150 and $200 for wireless version. Both can be found on sale for $50 off MSRP.
Feb 09, 2010 | HP OfficeJet 7110 All-In-One Thermal...
My check engine is on and the codes that I get are 35 & 55 - what do these codes mean
code 35 is a problemin the cooling fan relay it is either open or shorted code 55 means end of code output,or to say there are no more codes. Ray
Nov 09, 2009 | 1995 Dodge Intrepid
Toshiba Estudio 35 with error 424817
Yes I hate to say it but that is your total copy count. Now the problem is if your system is hooked up to a computer. Yes we need to know!!!! You might need to do a system restore.
Nov 04, 2008 | Office Equipment & Supplies
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
