Question about Dell Inspiron 5160 Notebook
Dell Inspiron 5160 screen
The bottom right corner of the screen (near the time) gets hot and turns black after the computer is turned on. The black spot gets larger the longer the computer is on. The metal at the corner is very hot. Is this fixable?
  • Anonymous Mar 27, 2014
    I have a black spot on the left corner of my laptop screen which grows and is very hot, then after awhile the screen totally goes black and I have to turn it off and reboot
  • 3,940 Answers
The only way to fix it is to buy and install a replacement LCD.
LCD's are available for about $100 on EBay, but the you have to know the size a resolution of the screen before buying a replacement. (14.1 or 15 inch, XGA, SXGA+ or UXGA resolution)
Posted on May 15, 2008
Dell Inspiron 5160 doesn't charge
you mite have fried the power supply. or the battery.. try removing the battery and pluging it in,and then power it up
Jun 13, 2012 | Dell Inspiron 5160 Notebook
When booting up the computer, the screen "flashes"
If the monitor works try hit ctrl alt f3. if that works you might have to reset your resolution
Jan 18, 2011 | Dell Inspiron 5160 Notebook
Dell inspiron 5160 is dim.
This problem can also be due to the corruption of display drivers// assuming that you have checked the contrast and brightness do this step:- goto device manager// click on the display adaptar + sign and on the pop-up driver right click and select uninstall//
once the driver is uninstalled then restart the computer and check//
if that doesnot work then you can also upgrage the grafic card by going to the web site// even if this doesnot work then 100% the problem is with the notebook screen// contact best buy or wallmart or the retail store from where you have bought the notebook//
Jul 01, 2010 | Dell Inspiron 5160 Notebook
I have a dell inspiron 5160 and the batery light and the power light is flashing at the same time what will cause this to do that
Hi there, I would like to try and help you solve this, please let me know if you replaced your motherboard. Is your computer turning on?
May 26, 2010 | Dell Inspiron 5160 Notebook
Bottom right corner of the LCD screen is very hot
I would first search the internet and Dells website to see if there is a recall on this item. If there is, they will replace for free.
Changing the inverter in screens always seems to complicate the LCD. I prefer to just purchase a new screen and everything works great. I replaced an inverter on a couple and had to change them again and again do to them slipping.
Replacing the screen is a bit more expensive but will save you time and money in the long run.
Oct 03, 2009 | Dell InspironTM 1501 Notebook
Dell Inspiron 5160 screen is very faint
u need to update ur laptop BIOS or change it
Jul 14, 2009 | Dell Inspiron 5160 Notebook
Screen gets hot and turns black on the bottom right
There are many causes of this. On cause can be the Cold cathode fluorescent
tube itself. This is a grossly misnamed device as the cathodes get very hot
indeed. One of the tube failure modes as they wear out is that the cathodes
can get much hotter than normal, and this affects the screen near it.
Jun 24, 2009 | Dell Inspiron 6000 Notebook
Screen is black
I think its the end of the monitor. I dont think there is anything that you can fix in this.
Dec 27, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Notebook Logo
157 people viewed this question
Alun Cox
