Question about Mtd 22" Yard Machine Push Mower
What is the correct spark plung and gap - Mtd 22" Yard Machine Push Mower
  • Roy Cagle
    Roy Cagle Sep 12, 2010
    Please post the engine manufacturer and the mower model number or the engine model number for more assistance. Most mowers plugs are gapped at .025"-.030" . The spark plug used differs for different engine applications (eg...flathead motor, OHV motor, OHC motor).
  • 252 Answers
0.028 " to 0.030"
but if unit is briggs intek ohv use 0.020 " gap
cheers paul46
Posted on Sep 13, 2010
  • paul nielsen Sep 13, 2010
    if briggs side valve engine use j17lm or rj19lm or equivalent
    if a briggs ohv engine use rc12yc plug or equivalent
    if honda ohv engine use bpr5es ngk plug
    be sure to fit same typeand heat range as what was fitted by oem
Spark plug gap
How to Gap a Spark Plug - YouTube
? 2:57
https://www.youtube.com/watch?v=IuW3svdqKZM
Oct 15, 2012 - Uploaded by ChrisFix
How to correctly gap a spark plug. This is a fast and easy video on how to gap a spark plug and spark plug gap ...
FAQ: Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonFollow this step-by-step image guide to locate spark plugs in different Briggs & Stratton engine types. ... Spark Plug Type & Gap Chart for Briggs & Stratton Engines. Now that you've found the part you'd like to replace, you can use the chart below to identify the genuine Briggs & ...
Spark Plug Gap - AutoZone
Dec 15, 2015 | Cars & Trucks
What is the spark plug gap?
This is the gap between the inner electrode on the end of the plug and the metal part near the electrode attached to the plug housing. There are many different versions of plugs, but this is the most common, and the plug and plug gap must be correct for the engine in which it is installed. In most cases, this gap is set correctly at the factory and may only need to be checked, not changed.
Mar 28, 2015 | Cars & Trucks
Whats the plug gap on 2.4 liter Volvo engin
Turbocharged engines: Correct spark gap: 0.7 - 0.8 mm (0.02 - 0.03 inch)
Sep 11, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
I've been told different spark plug gaps for a1974 Ford F-250 with a 360 engine, which is the correct plug gap for this truck.
U should buy a spark plug tapper u can get them very cheap from a auto parts store n to Find the correct gap just read the galore it will pretty much tell u the correct capping Needed
Apr 12, 2011 | Ford F-250 Cars & Trucks
Misfiring after replacement of spark plugs and wires
If it wasn't misfiring before. Make sure you have the proper gap on the spark plugs. Make sure you have the wires connected in the correct order. If you have the old wires, you may want to end up trying those one at a time to make sure you don't have a defect wire either.
Thank you,
Lee
Mar 04, 2011 | 1994 Ford Escort
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
What is the correct gap for spark plugs on a VW Golf GTi 1995?
For 1995 VW Golf GTi the correct gap for spark plugs is:
Electrode gap = 0,7 mm
Please rate my response. Thanks!
May 30, 2010 | 1992 Volkswagen GTI
Whats the correct spark plug gap for a 1972 honda cl 100. And what is the recomended type of oil to use?
Correct spark plug gap is 0.6 -0.7mm and oil viscosity is variable like SAE 20/30w some thing like this and also depends on weather conditions.
May 13, 2010 | 1972 Honda CB 100
Mtd 22" Yard Machine Push Mower Logo
90 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
