Question about Blodgett 1060 SINGLE Gas Pizza Deck Oven 60"
Gas thermostat control not opening - Blodgett 1060 SINGLE Gas Pizza Deck Oven 60"
    Scholar:
  • 195 Answers
If you mean the gas wont turn on after trying to light it could also be a bad thermocouple , it can't feel the heat so it wont open the main gas valve , this is a cheep fix
Posted on Dec 08, 2011
  • 3 Answers
This is due to the capillary of the thermostat being broken and therefore the thermostat needs replacing
Posted on Feb 17, 2011
Piloit light on606 gas water wont satay lit
If pilot light has gas, then ECO is not tripped so water heater has not experienced overheating event.
Remaining suspects include bad thermocouple, bad air quality, not enough air, bad vent, water dripping down vent, backdraft down vent, hot attic with bad ventilation, low gas pressure, air in gas line, dirt water or debris clogging gas control thermostat, bad gas control thermostat, tripped FVIR, dirty pilot orifice, dirty combustion parts, damaged combustion parts from exposure to trace chemicals like bleach and wax.
Suspects include one or more from list above.
Start with thermocouple.
Open following links:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Oct 02, 2011 | Reliance Natural Gas Water Heater Control
Pilot lights but burner won;t ignite.
Problems include: dirty combustion parts, clogged air intake, insufficient air quality, low gas pressure, bad vent, bad gas control valve thermostat.
Excluded are: air in gas line, bad thermocouple, clogged pilot tube, ECO lockout from overheating, FVIR tripped from flammable vapor event.
Open following link for illustrations showing how to clean parts, check vent, plus some reading resources for troubleshooting gas control valve thermostat.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 15, 2011 | Whirlpool Water Heaters
Hi i have a atwood 22.7 litre water heater model mpd93754 . IT ignites heats water, but wont shut off when it gets too hot. could you please help solve this problem . many thanks rod baker.
Gas control valve thermostat might be bad.
The copper cylinder located on back of gas control that sticks into water is the thermostat.
If thermostat is not reading correct temperature, then gas might stay lit.
Usually the gas control will sense overheated water and trip the ECO so no gas will flow to burner.
In any case, the gas control valve is replaced.
http://www.adventurerv.net/images/91601.jpg
Open following links to see typical manuals, service manual, parts link, and other resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jul 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
Automatic restart is not working. Seems to keep saying eco problem...I thinl...the code is four flashes followed by two flashes.
Gas control valve is not identified, so error code is not known.
ECO means energy cut off.
Energy cut off happens when gas control valve thermostat has gone bad, or when gas control senses runaway heating inside combustion chamber.
Newer heaters have resettable ECO for combustion overheat. This reset is typically located on combustion chamber door and is round and has two wires that connect back to gas control. Generally you have to clean combustion chamber and tubes and catch up on maintenance, then reset ECO, then fire up heater again to see if problem is resolved.
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
Newer heater does not have reset for bad thermostat, and in that case you replace gas control valve thermostat.
Older heater does not have reset, and combustion chamber and parts are cleaned, and gas control valve thermostat is replaced.
Your manual is best place to start troubleshoot.
Open following link to help identify gas control valve:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Jul 10, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a reliance power vent heater model 8 40 navto . When the water temp called for the heater to work the solenoid started clicking and when it stopped the pilot flame was out and cannot be relit. The...
First suspect is always to clean combustion parts.
I don't have that specific manual, but assume unit has digital gas control valve thermostat.
http://www.reliancewaterheaters.com/lit/om.html
As a general rule, the gas control thermostat activates the blower and turns on the gas, and controls flow of gas to pilot.
If the ECO is tripped, or there was FV event, or the gas valve thermostat is bad, or the combustion parts and tubes need maintenance and cleaning, then the pilot will not relight.
Open following link for older Reliance troubleshoot manual, plus some troubleshooting resources and illustrations:
Add a comment and say what you did to restore functionality.
Jun 13, 2011 | Reliance Natural Gas Water Heater Control
How to change bad thermocouple on reliance gas hot waterheater reliance 606
it is important to turn off
the gas supply to the water heater at the manual gas shut-off
valve. This valve is typically located beside the water heater.
Note the position of the shut-off valve in the open/on position
then proceed to turn it off.
2. On the lower front of the water heater locate the combination
gas control valve/thermostat. Depress and hold
the lock tab located under the gas control knob on the right.
Rotate the gas control knob on the combination gas control
valve/thermostat clockwise until "OFF" aligns with the mark on
the front of the gas valve. Once the gas supply has been shutoff,
remove outer door. 3. Using a 1/4" nut driver or socket loosen the two screws securing
the manifold door assembly until they are free. Do not
totally remove the screws and plastic retainer washers from
the manifold door. The screws and retainer washers will be
needed to reattach the manifold door. 4. In this step, the thermocouple, manifold tube, pilot tube and
igniter wire will be disconnected from the combination gas
control valve/thermostat. Using a 7/16" wrench
disconnect the thermocouple (left-hand thread) and pilot tube
(right-hand thread). Using a 3/4" wrench disconnect the manifold
tube (right-hand thread). Carefully pull the igniter wire from
the igniter button.
5. Grasp the manifold tube and push down slightly to free the
manifold tube, pilot tube, and thermocouple from the combination
gas control valve/thermostat. when installation is complete and gas is back on, You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Nov 27, 2010 | Reliance Natural Gas Water Heater Control
Thermostat calls and from time to time won't ignite
I would first look at any wire connections both at the furnace and the thermostat. Then I would replace the thermostat. Check the units control board when it does not start for an error code. There should be a small viewing port to look into the furnace cabinet to see the control board.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Feb 12, 2010 | Goodman Heating & Cooling
Shorted out gas heater power getting to box but heater wount startup.
Jump the R and W terminal on the control board. If it tries to start, bad thermostat or thermostat wire. If not, bad board or something else read on for suggestions.
Jan 19, 2010 | Carrier 38CKC036 Air Conditioner
IGNITOR GLOWS, GAS VALVE OPENS & LIGHTS, SHUTS DOWN GAS AND CONTINUES TO TRY TO RELIGHT. RUNS COOL. CONTROL THERMOSTAT GOOD. SAFETY THERMOSTAT GOOD. THINKING THIS IS A TIMER PROBLEM TO THE MOISTURE...
good guess,
but i would check the gas valve coils, they sit right on top on the gas valve, they both open to open the gas valve once you have burn one drops out, from your description, it sounds like your hold coil is bad
and will not HOLD the valve open,
although only one may be bad, I would replace both as a pair, since the bad one does pit extra strain on the good one when the valve opens
so there is no telling how good the boost actual is
since it sounds like you have a good idea of what your doing, you can get the parts at appliancepartspros dot com
type in the model number
and look in the gas control section
hope this help
have a great day
Oct 25, 2009 | Frigidaire FSE748GF Dryer
NO GAS COMING THROUGH THE ORFICES
Might be the high limit thermostat or the control thermostat. Check your gas valve for continuity.
If you have a fuse in line with the control check it for continuity. Most of the time if the pilot is lit you have a bad valve, I would check that first. The valve is a combination gas valve. That means it has the pressure regulator built in. Check out the connection between the gas valve and thermostat. If no continuity between the 2 outer terminals change the gas valve. If the thermostat is open change it out. The high limit will connect between the left terminal shown and the safety magnet. I know this page shows a floor furnace thermostat but a geep fryer works exactly the same with a different thermostat and high limit.
Jun 12, 2009 | Imperial IFS40 Deep Fryer
Blodgett 1060 SINGLE Gas Pizza Deck Oven 60" Logo
174 people viewed this question
Top Blodgett Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Blodgett Kitchen Appliances - Other Expert? Answer questions, earn points and help others
