Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I have a 160 GB SimpleTech external hard drive. It no longer shows up as a drive when connected to any computer. The blue light flashes when you plug it in; however, the drive never shows up when I go to "my computer". There is a local drive G that is displayed, I'm not sure if that is it or not. I tried to select that drive, but I get "not responding". The drive is 96200-41002-110.
freetek
  • 5568 Answers
SOURCE: Have a 160 GB ext. Hard drive - no longer made.
Although I have seen it fail often, in your case it is worthwhile to try the 'Add hardware' wizard in the Control Panel. If you have an installation disk of any kind, have it at hand. Let the system look for the drive (plugged in of course) and if it finds it and has no drivers for it, it will ask for the installation disk but you may have to tell Win where to look for it by drive letter. If you don't have an installation disk, you will have to go through the drivers list offered to see if SimpleTech is listed.
SimpleTech still has an active website so I would check there first:
SimpleTech support page
If you have no luck you find no driver, there are several websites that have a huge array of drivers for current and obsolete hardware.
Good luck-
Posted on Feb 27, 2009
spiffyrodent
  • 85 Answers
SOURCE: SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Posted on Sep 10, 2009
  • 788 Answers
SOURCE: simpletech 160gb
I would guess you are useing USB.
If correct, try a differant USB port.
The USB port you are useing may not be configured for USB2 speeds.
Posted on Sep 21, 2009
Gort007
  • 1187 Answers
SOURCE: I can't delete files
Do a "disk cleanup"
Click on [My Computer]
Right-click on the External drive (D?)
Select [Properties]
In the [General] tab, click on [Disk Cleanup]
It will "scan" your drive, but not remove anything... alow it to complete the scan.
Look at the recommended list that appears and accept its findings.
This should remove non-essential files and leave your data intact.
Burn some of your data, especially video content to DVD (make at least two copies) ... then remove the data from your external hard drive.
You may want to purchase another (larger) external drive. You can use two of them or move your data to the new one.
Posted on Sep 30, 2009
Testimonial: "Thanks, it didn't work, at least now I know I need to get a new portable hard drive."
  • 1584 Answers
SOURCE: SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Posted on Dec 23, 2009
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Simpletech external hard drive has a constant red light and is no longer recognized by my laptop
It sounds like the drive could have failed. Try running a test on it using Seagate Seatools:
SeaTools Seagate
Mar 20, 2014 | SimpleTech Computers & Internet
Problems access my My Book External Hard Drive
have you checked you usb connection? try unplugging it then plugging it back in see if computer recognises it then if not chances are your drive has failed
Jul 15, 2010 | Western Digital My Book Premium ES...
Simpletech external harddrive, blue flashing light with a constant beeping
Your drive is not getting enough power. try a different usb cable and a different usb port on the computer
Sep 26, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
Have a 160 GB ext. Hard drive - no longer made. Bought it over a year ago but never plugged it in until two day ago. The red light comes on but it does not show up under"My Computer" Took it to Best Buy...
Good luck-
Feb 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 500G HD
that means system wont support the drive or you are having problem with the detection or driver.
some system wont detect the drive with large size without drivers.
Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
566 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
